Question about Canon Office Equipment & Supplies
E020 0189 ci + error cod 020 0189
Error 020
Error 020 means its a problem with the main board(hardware) on the printer. you should contact printer manufacturer.
***If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
Mar 19, 2013 | OKI B4350 Laser Printer
Forgotten unlock code nokia ci-01
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Default 6 Digit Security code: 000999 or 1122
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
OR:
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Aug 23, 2011 | Cell Phones
What is No CI Module ?
Hi
CI stands for common interface, there will be a slot on the side of your tv for a CI Module to be inserted, this allows you to view encrypted channels (such as ESPN) that you have to pay for using servces such as topup tv (uk).
It sounds like you have being trying to watch a encrypted channel without a CI Module inserted, this would most likely be the cause of the error message you are receiving.
Hope this helps
Mar 07, 2011 | Hyundai T236W LCD TV
Fatal error 020: oki c5450
As far as 020 error is concerned it is the TNY on the controller board. If you take the controller board out (it's the board that the usb/network cable plugs into). You find 2 banks. Ones for memory, the other bank is your prom board they refer to as a TNY.
Aug 18, 2010 | OKI C5400 Laser Printer
I just changed the toner and I now have an error code 020
020 is a CU rom error... check that your memory and PS cards are fitted into the main PCB properly, if not remove the PS card and try it. Beyond that you might have a faulty main board
Sep 08, 2009 | OKI B4350 Laser Printer
Getting Fatal error 020 on my Okidata 7300 printer. How do I fix.
You could take the controller board and reseat the dimms. But the Rom Dimm is usually bad and needs to be replaced.
Apr 15, 2009 | Office Equipment & Supplies
Script compile error
Is this COD??
If so back up your gamesaves from COD to a meme stick.
Then put COD in and see what happens.
If it works then the game save was corrupt.
And yes you will have to start again.
Feb 25, 2008 | Microsoft Xbox 360 Console
Service Call 020 Fatal Error
Error 020 is a ROM dimm error, could be as simple as reseating/replacing Rom Dimm or a expensive main PCB, you need to get hold of a oki dealer, contact oki to find closest OKI repair agent.
www.oki.com
Jan 08, 2008 | OKI C9300 Led Printer
OKI C7300 Printer
moz-screenshot-1.jpg Unfortunately it's a Hardware problem.
If you bought it from a dealer, contact them.
Error 020
When an error has occurred in the controller board (CU) or the program Rom.
Resolution:
Replace the Rom Dimm, see chart below for the correct part number. If the Rom Dimm does not correct the issue, then replace the (CU) controller board. Please refer to the service manual for (CU) part number depending on the printer revision
Dec 01, 2007 | OKI C5300n Led Printer
27 people viewed this question
old marine
old marine
