Question about Electrical Supplies
4 wiring device
I have 2 black wires, 2 white wires and a copper wire coming out of a core. I also have another copper wire coming from the wall. I am trying to hook it up to a gcfi/ddft/icta receptacle, please help....
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
If you can see which pair of black and white wires belong to eachother it will make things much easier. take a volt meter and test which black wire is the one coming from the breaker box. the white wire that is paired up with the black are the feeding wires to that outlet box those wires will go on the "LINE" side of the GFCI receptacle. The other black and white wires go to the "LOAD" side. (silver screw for white and brass screw for black) the two copper wires should be connected to the back of the outlet box and if so, take one of the wires and also connect it to the green ground screw on the GFCI plug. if they are not connected to the outlet box, be sure to connect them securely
Posted on Apr 08, 2014
5 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: wiring a leviton 5625-W switch receptacle combination
You cannot replace the switch with a switch/receptacle combo because there is no neutral wire. The black and white that you see are both used as hot wires. One is the Line and the other is the Load.
You have to install another 2 wire cable or replace the existing with a 3-wire cable. A 3-wire cable has a black, red, and white, plus the bare ground wire
Posted on Sep 02, 2009
heatman101
  • 43501 Answers
SOURCE: I can't figure out how to wire my cooper wiring
Take the black going to the light off the center and hook where the white going to the light is now....then hook the white to the light with the other white and you will be good to go...You almost had it right...
just a couple of adjustments....:-)
heatman101
Posted on Oct 11, 2010
SOURCE: pass and seymour ws 3000 Hooking up to basement I
You're right, green goes to ground.
Black wire connects to Hot wire from breaker box
Red goes to Load (fan, light, motor)
Ok which wire on the switch goes to the Load?
And which goes to Hot from breaker box?
You can test or you can simply hook up the device. If it doesn't work, swap the two wires.
It just won't work until the 2 wires are correct.
Posted on Oct 24, 2010
SOURCE: My out let has 2 black wires and 2 white wires
You purchased a GFCI outlet.
You posted under GFCI combo switch and receptacle.
If you have different device, then add a comment.
On back of device are markings that show Line and Load.
These markings are associated with screws on device.
Black Hot wire connects to Brass-colored Line screw.
White Neutral wire connects to silver screw located opposite Line screw.
If you don't know which wires are Hot and Neutral, the testing steps are shown at bottom.
Your other two wires evidently go to a light, fan, or motor that is operated by the switch.
This is where the two wires that stick out of GFCI device are used.
Your Black Load wire connects to one wire, and your White Load wire connects to other wire.
Finally there are 2 screws left on GFCI device.
These screws are used if the Hot and Neutral wires go forward to another switch or receptacle box. This would require another Black and White wire in the box, and all devices from the GFCI forward would be protected by the GFCI.
As you know, the way electric circuits work is a Black Hot and White Neutral leave the circuit breaker box and travel to a junction box. From the junction box, the Black Hot and White Neutral travel to the next box, and then the next box, and so on until the last box is reached. Each box contains a switch or plug or combo device or a light fixture. In your case, the Black Hot and White Neutral may not send power forward to another box, and may just be a switch box that has a single wire to the light fixture, and that is the end of the circuit.
How to test for Hot and Neutral wires:
Separate your 4 insulated wires.
Turn power ON.
Test each wire to bare ground wire.
Tester will light up on Hot wire.
Now Hot is Identified.
Test Hot wire to each other wire in box, except bare ground.
Tester lights up on Neutral wire.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks to you via phone while you test the wires and wire the device.
Posted on Jan 04, 2011
Wiring Diagram
Are you replacing 3-way switch?
EJ351 is single pole
You have to test these wires to see what each one does.
Two of the black-white wires will be Hot from breaker box... other wires will go to lights or forward to another switch or outlet box
The black hot wire will connect to one of the wires on timer....
The hot wire will also feed into the black wires that go forward to other switches and outlet boxes.
http://waterheatertimer.org/Basic-house-wiring.html
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Gene
Water Heater Timers Save Money
Jun 11, 2015 | Hardware & Accessories
Ceiling fan wiring diagrams
Most usually you will have four wires. One raw copper, one white. One blue and one black. The raw copper would mount to the casing (usually to a green screw) this will be what is called an earth ground. It will divert any stray voltage to the outside ground rod. The white wire is called a neutral ground wire. It goes to the white wire in your casing of the fan/light. This wire goes to your breaker box ground terminal. The blame wire will be your positive (hot) wire to your light section. Connect it to the black wire coming from the ceiling box. Do not put your wire nut and or tape on yet. Connect the blue wire to the black wire connection. The black wire that is in the ceiling box is the positive (hot) wire from your wall switch which comes from your breaker box. Occasionally you may find two switches on the wall, one for the light and the other for the fan. In this event you will have two sets of wires in the ceiling box. Use the black one on one of the black fan/light wire and the other black wire in the ceiling box connect it to the blue wire. If there is another white wire, connect it to the other white wire. Do the same with the raw copper wire. NEVER CONNECT A WHITE WIRE TO A BLACK WIRE. OR A RAW COPPER WIRE TO A BLACK WIRE. THIS WOULD CREATE A DIRECT SHORT AND ELECTROCUTION COULD OCCURE. Turn your power back on when you have completed your job and check each switch. If the switches are not in the location you prefer, turn you power back off and either reverse the location of the switches in the wall box or you can reverse the blue and black wires in the ceiling box.
Aug 06, 2014 | Canarm Ltd HLW-HL50-09 2" Insulated...
Wiring Hunter ceiling fan into old house. My house was built in the 60's an the wiring is confusing. I removed an old chandelier and I am putting a new ceiling fan in it's place. When I removed the...
Your copper, green wire are the ground. I beleave that the white is the power, and the black is your neg. to make sure i would use a wire tester to determen the power. From there white goes to white, black to black, and green to copper. I am not sure on the white/black wire it maybe another power. Look at your instalation manual it should tell you.
Hope this can help.
Mar 20, 2012 | Hunter Dryers
GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Sep 25, 2010 | UPM Programmable Wall Switch Timer
I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
I need to install a kenmore range. the wires coming from the range are red, white, black, and green. The wires coming from wall are black, white and copper. How do I connect the wires?
Hello, Here's how to hook it up:
Black from wall to black at stove.
White from wall to red at stove.
Copper from wall to white and green at stove.
Hope this helps. --W/D--
Jul 31, 2009 | Kenmore Kitchen Ranges
Wiring a ceiling fan w/light
To add to red54's comments:
This is what I believe you have:
- one source in the ceiling box (black & white)
- one donwline circuit in ceiling box going to another wall/ceiling box (black&white)
- on switch wire in ceiling box coming from your wall switch (black & white) -- this is the white wire which will be hot when the switch is truned on
Here's how it should be connected:
- all 3 blacks in ceiling box connected together -- no other wires in this bundle
- white wire (which is hot when switched) coming from switch connects to the black/blackwhite fan wires
- connect all reamining white wires together in bundle
- connect all ground wires together
It's that simple. Trick is figuring out, of the three cables in the ceiling box, which is source, which is downline, which is switch.
Maybe red54's procedure can help you figure that out.
May 09, 2009 | Hunter 22890 52'' Low Profile Plus Antique...
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Electrical Supplies Logo
53 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
