Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman evcon model DGAT070BDF
Blower will not shut off, have digital thermostat, lowered settings, blower still going off
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 23 Answers
Open hi temp limit switch or fan limit bad
Posted on Jan 15, 2015
2 Suggested Answers
  • 2463 Answers
SOURCE: I have a coleman evcon model dgat070bdf furnace.
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Posted on Feb 05, 2010
Coleman Evcon DGAT070BDF
Does the fan switch turn it on/off?
Apr 01, 2014 | Tools & Hardware - Others
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Coleman evcon presidential heater won't kick blower on.
Sounds like the automatic fan control is not working it cuts in on temp rise . It may be dirty on the back of it as you said you had a smell of dust burn
Jun 17, 2017 | Coleman Heating & Cooling
Coleman evcon four flashes on indicator...fans work... won't fire
Hi it could be the pressure switch clean the back of the fan control sensor, and the flame sencer
Feb 19, 2010 | Tools & Hardware - Others
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Feb 05, 2010 | Coleman Propane Forced Air Heater...
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Coleman evcon blower not working properly
My Coleman Evcon ac unit,heater and blower does not work.not even the outside condenser comes on.Any ideas on what is the problem?
Jun 22, 2009 | Coleman Heating & Cooling
Furnace blower not working how it should
first off buy yourself a honeywell stat, in my personal opinion lux stats are garbage, I have run into so many that are bad stats !!! but as far as your fan not shuting down, sounds to me like your fan center on your circuit board is bad and will not shut down the fan when needed, you will have to replace the circuit board, as the fan center is a part of the whole of the circuit board, hope that helps
Jan 19, 2009 | Coleman Propane Forced Air Heater...
Coleman Evcon no fan when in heating mode
Sounds like your flame proving device is not proving the flame. It is located on the last burner looks like a piece of thick wire sitting right beside the last burner. To Save you about 50 bucks service call take some steel wool and very gently clean the carbon that has built up on the surface of the device. Should only take 4 or 5 strokes.
Main blower will delay when in heating mode as to allow the heat chamber to build up enough heat to trigger the fan switch.
Nov 30, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
96 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
