Question about Briggs AND Stratton Intek Briggs & Stratton 385447-3075-g1 Gas Engine,21 Hp,3600 Rpm,horizontal
21 hp engine starts but only runs for few minutes
Engine starts but shuts down after 5 minutes with a lot of blue smoke
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Briggs AND S... Master
  • 1,917 Answers
Rebuild the carb it has a dirty fuel jet
Posted on Dec 17, 2014
21 horsepwer enine smoked and then stopped running
Check the oil is it low...some engines have a low oil shut down...and will not start or run when too low Good luck
Aug 04, 2015 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
I have a craftsman yt3000 21 hp briggs and straton platinum engine. Its about four years old. The tune up kits have been used at the beginning of every season. It has started emitting blue smoke from...
Blue smoke usually indicates burning oil. There may be some residual oil in the cylinder that burns off when the engine is started. Do you use much oil when the engine runs? Keep an eye on the oil; level.
May 24, 2014 | Garden
The oil was low in my Cub Cadet SLT 1550 so i filled it up, and after about 5 minutes the engine started smoking blue, smelled like oil and after a few seconds it turned really cloudy white
remove the spark plug and try and crank it over see if oil spits out you might have dumped it in to fast and it went threw the breather
Jul 10, 2012 | Garden
516 Cdi sprinter sudden blue smoking for few minutes and after OK
somthing in the ignition is causing a weak spark--or fuel inject circuit is running to rich----------all causes improper burning---------get a computer diagnostic done
Apr 07, 2012 | Cars & Trucks
Model:31P977 Type: 0635-E1 Code:070510ZD Just bought this used. When they showed it to me it did not smoke. I started it up in the yard and after a few minutes...blue smoke started coming out of the...
I would say that you have worn or cracked piston tings and perhaps in need of a new head gasket. After you have had it running for awhile and then shut it off for a short period and restart it does it smoke as much as it would after waiting for an hour?With any sort of luck maybe your engine has not seen much use and will straighten up.You might try some sea-foam in both the gas and crankcase to help clean up the engine.You can get this product at most auto parts store.I have been using it for thirty years in all my engines small and large and think it's an excellent product. Best of luck and thank you.
Aug 29, 2011 | Briggs & Stratton Briggs Stratton Intek V...
Lawn Boy pushmower blew out lot of whitish-blue smoke after starting (has not run in 110 days). Checked oil level, was to high, so removed some oil, after thar ran fine but after 10 minutes, same...
Hi, change the oil and your problem will be solved. Basically it was over full because fuel has by-passed the carby needle and leaked into the sump while its been sitting idle. Regards Phil.
Aug 14, 2011 | Garden
Honda GX390 engine on Citation pressure washer: less than 50 hrs on pressure washer worked fine last year and was winterized all start settings correct; had to use starter fluid to start this year and...
Did winterising the engine include pouring lots of oil into the intake of the running engine until it choked and died? That is the classic method of winterising...
Heavy blue smoke is burning oil.
I expect the spark plug fouled in those few seconds. After winterising the spark plug usually needs cleaning several times before there is a reliable start and continued running.
Sep 28, 2017 | Motorcycles
Smoke problem
hey
there are couple of smoke type.blue smoke is oil, black smoke is fuel, and white smoke is water, if it clears after starting and running a few minutes it's probably your valve guide seals leaking oil down on top of your pistons, causing it to smoke until burned off and foul your plugs.
Jun 28, 2008 | Peugeot Liberte Cars & Trucks
Readyheater portable forced air 170,000btu/hr
reset switch my heater did the same thing after 5 sec of running
Dec 20, 2007 | Reddy Heater-170,000 BTU Kerosene Deluxe
Briggs AND Stratton Intek Briggs & Stratton 385447-3075-g1 Gas Engine,21 Hp,3600 Rpm,horizontal Logo
188 people viewed this question
Top Briggs AND Stratton Intek Garden Experts
wadingriver
wadingriver
roeb
jdthefixer
Are you a Briggs AND Stratton Intek Garden Expert? Answer questions, earn points and help others
