Question about Nordic Track NordicTrack A.C.T. Elliptical
Shuts down in middle of program
I was just working out on a 25 min weight loss program. At about 17 minutes in the program stopped and went to the start up screen. When I go back in it makes me start all over. What can I do to fix this?
Does diet pill work for loss weight?
Yes! They are safe to use. But, choosing a correct weight loss supplement is very necessary.
There is one weight loss supplement which I m using is- Phen-Q. It has all the features and functions of weight loss aids. I had chosen these supplement because of the positive reviews of PhenQ. I m having a great experience of weight loss with it. It does not have any side effects.
Feb 19, 2017 | Health & Beauty
What are some natural ways to speed up the weight loss process?
Today, everywhere you can see companies promoting products for losing weight. Everyone promises to give better result and that too with a herbal product. But it can't be effective at all.
They also have side effects. Therefore it's better to use a well-planned diet plan for losing weight instead of trying anything else.
It will give you expected result at the same time safety also.
Avoid heavy diet and drink plenty of water, prefer light exercise.
A dietitian can be consulted or can be done yourself by following 2weekdiet for burning calorie and reducing fat.
Diet requires a lot of patience and motivation. Because it takes more time to give the positive outcome.
Mar 30, 2016 | Weight Loss Apps How to lose weight
My razor mx500 just instantly stopped running when I was riding up a hill, it was on a full charge could it be a blown fuse or multiple blown fuses?
weight always play a role when a rider is going up hill. If the rider is over the weight limit or near the weight limit, the motor works very hard and need more power/electricity from the battery, for which the motor runs hot and the 25 to 30 amp fuse would break, shutting down all power instantly.always check the fuse first when all power is lost before anything else....
Mar 13, 2016 | Motorcycles
My cam only records 17 min of footage at a time???
This sounds like it's one of two things: 1 - it's an over heating issue. This is to ensure than nothing gets damaged on the mother board or inside components - this most often found in Canon products. This is a very good feature. 2 - since you said it doesn't stop recording, it's merely make a cut point, it's more than likely cutting the footage to fit the FAT32 hard drive rules of not exceeding 4.4 GB of date for a single file. This is to help with post production work flow so you can edit easier and your system won't be as bogged down. All around this is a good feature. Helps in post production greatly.
May 09, 2014 | Sony Handycam HDR-CX160 Camcorder
How can I stop myself from regaining all the weight I previously lost?
Maintaining your health is a one really important task.It needs to be done with real care and attention. As I was obese and took a break from my office to go for some weight loss treatments, I managed myself to lose weight after one month. I was quite happy with the weight loss that I had undergone and I wanted to remain the same for the rest of the days too. So I was thinking of ways to maintain my weight loss, and not to add on or put on any weight. I went to the pharmacy and they suggested me the Best Weight Loss Pills 2018, to be consumed on a regular basis just after my treatment of one month. Though I was not sure of how it is going to work for me, I started using it and found that this was just the correct product for me. It really helps me a lot and I am happy to maintain my health using these pills.They have given me good results and have never disappointed me so far.
Feb 20, 2013 | Health & Beauty
Projector shut down
happened to me something similar to what reported, only the small fan sometimes went off within minutes and sometimes seemed to work for hours
The room temperature was around 20 degrees, so the problem was software or hardware, but on the internet I did not find other people with this problem or fix
I did not update the firmware for the loss of the warranty, which I am thinking of claim
Feb 12, 2013 | Optoma ML300 Multimedia Projector
How much weight will I lose using an exercise bike?
Exercisebikes are a really good way of losing weight without having to show up at thegym! It depends on your weight etc but on average, 15 minutes of cycling withburn about 170 calories. But an effective routine should last around 45-60minutes.
Jul 30, 2012 | Exercise & Fitness
Mitshubishi VS-6041 No picture, sound ok
It has been my experience with that model mitsubishi that the usual culprit is loss of vertical sweep. If the beams in the picture tubes stops moving up and down this is detected by the micro processor and the video is blanked, but the set is not shut down. The usual cause of loss of vertical sweep is bad solder connections on the deflection yokes or a failed vertical output IC.
May 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Pc stuck in sleep mode...
You will need to replace the hard drive which has any version of windows operating system, or you will have to re-install windows xp on that computer. Assuming if the computer has a green light and monitor has an orange light. I've encountered this problem where I work at.
Nov 06, 2007 | Dell Dimension 5100 (D51L1) PC Desktop
Nordic Track NordicTrack A.C.T. Elliptical Logo
27 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
