Vizio tv gets hot only on the edges on the right side of the tv
Izio tv gets hot only on the edges on the right side of the tv
2 Suggested Answers
sams_trix
  • 93 Answers
SOURCE: Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
Posted on Aug 30, 2009
We have a 50" Vizio plasma TV with a persistent blue, sometimes white, pair of vertical lines on the right side about 1/4 from the right edge.
if those problems were present when you got it back from repair, then, the guy didn't fix it fully.
if those are new problems - then you are now finding out why electronics and plasma displays wear out after ten years, replace the unit, don't pay to 'get it fixed' as the rest of the parts are old and about to also fail.
Mar 25, 2018 | Vizio Televison & Video
I have a Vizio m70-c3 led tv. I started to get vertical lines on the right side of the screen. I researched and thought it was a t-con card but the issue is still there. I also swapped the cables to see if...
Vertical lines are always the result of the LCD panel failing. You may be able to locate the issue by pressing around the edge of the screen at the location of the lines. The problem is usually caused by edge soldering connection failing. They can be repaired by using a heat gunn in some cases or forcing pressure on the edge with tape or shims.
Mar 07, 2018 | Vizio Televison & Video
Vizio VW46LFHDTV10A vertical lines on either side of the screen. I tapped screen and left side lines disappeared.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 27, 2016 | Vizio VW46LFHDTV10A 46 in. LCD TV
How to fix vizio tv that turns on but no picture
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen ... Was working fine and now blank ...
LCD Easy Fix (sound but no picture) - YouTube
? 4:52
https://www.youtube.com/watch?v=IBRE1Dcyxp4
Jan 13, 2012 - Uploaded by Clay Whitehead
My tv stopped working, it had the sound but no picture, so I did a little research and fixed it. ... vizio E701i-A3E ...
Vizio LED TV Repair - TV Has Backlights but no Image on ...
? 5:06
https://www.youtube.com/watch?v=fSCf1xxLjNA
Aug 27, 2015 - Uploaded by ShopJimmy.com
Basic Troubleshooting Help if your Vizio LED TV has a blank screen and no ... It is on an UPS but turned off ...
Dec 10, 2015 | Vizio M3D650SV 65 inch Class Theater 3D...
How to remove stand from 47 inch izio
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations
Aug 25, 2014 | Vizio SV472XVT 47 in. LCD HDTV
How to change batteries on VIZIO internet qwerty remote control
Get yourself a thin flat-head screwdriver find the logo on the bottom side of the remote that says "Vizio" You will see the edge of the battery compartment, use your flat-head screwdriver and carefully find that edge, right below the word VIZIO, use your scerwdriver underthe "V" and under the "O" stick your screddriver in and gently push up on these 2 spots till the cover pops, then slowly remove, so you don't break the little parts holding on the cover..
17912129-4302-414a-ac68-bc6289672349.jpg f7d8b044-a3a9-4b77-ba86-c6b7fd71b392.jpg
Jul 03, 2014 | Vizio BRAND Original XRT302 Qwerty dual...
I DON'T HAVE A REMOTE AND I CAN'T GET ONE HOW DO I CHANGE CHANNELS
Sometimes there are buttons on the back side close to the edge, I have a Samsung and the buttons are on the right side back towards the bottom edge.
Apr 09, 2014 | TruTech PLV16190 Television
LCD TV Has Sound, Backlights Work, but No Picture
I have been having the same problem with my LG. people say there are bad capacitors on the power supply board. I don't have the know how to replace them and don't have the money to pay. I can get mine to work by blowing hot air with a hair dryer into the back of my tv through the vents over the board. Heat it up for a couple minutes and turn it off and then back on and the picture comes back. I just never turn the set off now.
Sep 08, 2012 | Vizio M550sv 55 Inch Class Edge Lit Razor...
Need Vizio VO320E code to program AT&T remote
hi! i have here a couple of codes for your tv, just try them, 1343, 1489, 1004, 1429, 1433, 1439, hope this helps!!!! goodluck!!!!
Jun 06, 2010 | Universal Remote Control BW056D Remote...
Televison & Video Logo
Top Televison & Video Experts
