Question about Arietta 30 in. Wall Mount Decorative Range Hood Dekor Glass 30
My Arietta Hood Fan comes on by itself, even when not using the stove, and then it won't shut off.
The fan comes on by itself ( when oven not in use ) then I can not shut it off. Nothing on the control panel will respond, we have to go out to the electrical panel to cut off.
Is there an online maual
Arietta DKW001MX 30 Manuals
www.manualslib.com > Brands > arietta Manuals > Ventilation Hood
Arietta DKW001MX 30 Pdf User Manuals. ... We have 1 arietta DKW001MX 30 manualavailable for free PDF download: Use, Care And ... Arietta Range Hood.
Oct 15, 2015 | Arietta 30 in. Wall Mount Decorative Range...
Fan comes on by itself and won't turn off.
Is it a micro hood? If so, and you're cooking on the stove below, it may be that the microwave is getting too warm. Some of them have an automatic fan the comes on when you're cooking below them - especially when boiling potatoes or something else steamy.
Feb 01, 2015 | Goldstar Mv1502b Microwave Oven mv1502b
Have Kenmore microvave and the vent starts on its own
Actually, that's a feature! If you cook much on the range (stove) beneath the microwave, the heat will cause the microwave bottom to heat up quite a bit (just touch it!), and the microwave will turn on it's exhaust fan in an attempt to save itself from burning up. It will shut off in about 15 minutes after you turn off the source of heat.
But if the fan comes on by itself even when the microwave is cool (or at least not hot), then you probably have a defective fan thermostat. This thermostat is located behind the control console on the inside bottom of the microwave.
Aug 27, 2014 | Kenmore Microwave Ovens
I have a Kenmore microwave. The vent will just start on its own and can't shut off
Fan on microwave
The "hood fan thermal cutout" is designed to turn on the hood vent exhaust fan if the stove top temperature gets too high.
If that fan comes on and stays on, the hood fan thermal cutout may have shorted, needing to be replaced, or its driving relay on the control board may be shorted.
If that's the case, we regularly repair such control panel assemblies nationwide for $39.95 postpaid.
You can find the Frigidaire manual that may help you here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Mar 14, 2010 | Frigidaire FMV156DC Microwave Oven
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
Sharp Microwave Oven over stove fan goes on by itself
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a
NEW question, and please include your brand name and the full model number from the tag in or on the unit, as well as the answers to these questions:
Which fan is it?
The
internal cooling fan, which comes on automatically whenever the unit is microwaving?
Or the hood vent exhaust fan which you can turn on and off manually?
Or the convection fan, if it is a convection model?
When is it coming on?
Is it coming on whenever you cook on the stove top?
Thanks!
Oct 09, 2009 | Sharp R-1870 Convection/Microwave Oven
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
GE Microwave Profile Spacemaker Runs on its own
Your microwave turning on by itself is a "self preservation feature" of the GE Profile Advantium and maybe some other models. Read the manual, When your over the range oven gets warm enough, for whatever reason the venting fan comes on until a satisfactory oven temperature is reached. You are not permitted to shut the vent fan off. Also it seems a temperature near room temp must be achieved before it shuts the fan motor off, it is very annoying. We had to return our Advantium because of fan noise. I configured the ovens vent fan to the recirculate direction because we do not have a vent duct that exits the house over our range. When the vent fan acting as the ovens cooling fan automatically turned on we would have to leave the house to hear each other talk. Too bad we really liked the oven other than that major problem. G-Man
Apr 19, 2009 | GE Profile Spacemaker Over-the-Range...
The fan starts up and runs on its own and we are cooking
That is a normal safety feature.
That's only covered in a very subtle note in the hood fan section of your owner's manual:
NOTE:If the temperature gets too hot around the
microwave oven, the fan in the vent hood will
automatically turn on at the HIGH setting to cool the
oven. It may stay on up to an hour. When this
occurs, the fan can not be turned off.
If for some reason you don't have your owner's manual, you can download it here.
Enter your model number as MV1610ST with no spaces.
You will need the free DJVU viewer to view or print your manual.
Dec 14, 2008 | Goldstar MV-1615 Microwave Oven
Arietta 30 in. Wall Mount Decorative Range Hood Dekor Glass 30 Logo
97 people viewed this question
Top Arietta Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you an Arietta Kitchen Range Expert? Answer questions, earn points and help others
