Question about Motorola MR350R Two Way Radio
. Keeps shutting off
Everytime I press the PTT button it turns the walkie talkie off. It is not new but I have others that are working fine. Plus it still receives messages just cant answer without it shutting off.
  • Motorola Master
  • 1,654 Answers
This is a sign of a bad or low battery. Try swapping batteries with a known good unit to see if the problem is solved. It takes more energy to transmit than to receive, so as you described a radio can receive messages, but then when you go to transmit and use more energy the battery will not have enough power to do so.
Best regards.
Posted on Jan 06, 2015
zeusfaber
  • 247 Answers
SOURCE: pick up other walkie talkies
Should do. The available channels are defined by the regulator rather than by the manufacturer. Only thing to watch out for is similar looking devices designed to be sold into different markets (for instance, radios made to the European PMR446 standard work at a slightly lower frequency than those intended for sale in the US). A.
Posted on May 31, 2007
Agent Ken
  • 250 Answers
SOURCE: T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Posted on Jul 03, 2008
eradiostore
  • 1654 Answers
SOURCE: The battery is fully charged
Your batteries are either no good, or not charged. When you press the PTT button it takes more energy than being in standby mode. If you have a battery problem it will fail quickly when the PTT is pressed.
Rechargeable batteries last approx. 18-24 months. Check your battery for a 3-digit date code. It is usually a 3 digit number followed by a couple of letters. The numbers tell the date of manufacture. The first number is the year, followed by the week of the year. 025 would be 2010 the 25th week. (or if very old it could be 2000 the 25th week.)
If you feel age is not a problem, you might check your charger(s) to see they are fully powered, and clear of debris on the contacts (and the radio contacts as well). Clean with a pencil eraser if needed.
A few tips: Be certain when placing your radios on the charge they are turned off. Check your wall outlet to be certain it doesn't get shut off with a light switch. Expect to replace your batteries every 2-3 years.
Best regards.
Posted on Nov 10, 2010
eradiostore
  • 1654 Answers
SOURCE: When I place the walkie
Generally when a radio shuts off when you press the PTT button it is a sign of a bad or poorly charged battery. It takes more energy to transmit than to receive. The fact you have a charge which the light does not come on indicates you have a bad charger or bad connection between the radio and/or battery and the charger. Clean your battery contacts (on both radio and charger) with a pencil eraser and see if it clears up the problem. If not, you have either a battery or charger problem.
Best regards.
Posted on May 26, 2011
SOURCE: Motorola Walkie-Talkie will not turn on.
The same thing happened to me, all you have to do is put it on charge for 20 mins, then take it out, keep on pressing the on button, leave again for 5 mins and then click the on button and it should turn on. It just needs a boot or a jumpstart if you have not used it for a long time like me :) Hope this helps
Posted on Nov 11, 2012
My binatone mr200 walkie taklkie's talk button wont work how do i fix it
Spray "CRC 2-26" into the PTT button;then press the PTT button 10 times.Do this without the battery connected,then wait for 10 minutes for the solvent to dry.
Nov 07, 2014 | Binatone Walkie Talkie Handsfree Headset...
Shuts off immediatley after pushing PTT button
sounds like your batteries are shot and not able to supply enough power for transmit
Jan 10, 2014 | Motorola Walkie Talkie 2-Way Radio
Want to know how to make old nextell / boost Mobil phone walkey talkey or chirrup work for free
Yes it is free, You should have a walkie-talkie ID number. Friends of your walkie talkie also have ID numbers install number to Your contacts scroll down on contact to (Options)D C. From there follow directions try to make a walkie talkie contact by pressing the side (PTT) or push to talk button , It a cinch. This may only work 4 sprint
Jan 22, 2013 | Cell Phones
When I press PTT the walkie talkie turns off
Dead, shorted, not fully charged, bad battery connection, or bad battery.
Jun 15, 2012 | Radio Communications
When I place the walkie talkie in the charger base, the light indicator does not come on. I've put new batteries in the walkie talkies. Also, on another walkie talkie, it constantly shuts off when I...
Best regards.
May 25, 2011 | Motorola Walkie Talkie 2-Way Radio
The battery is fully charged on the walkie talkies and all are on the same channel, however out of 12 walkie talkies only 2 will work. When ever you push the push to talk button the walkie talkie shuts...
Best regards.
Nov 09, 2010 | Motorola Walkie Talkie 2-Way Radio
Cx80 stuck in rx mode , power cycled, swapped batteries, changed channels, will only swtich to tx when ptt button pressed, otherwise always in rx mode, other radio from package works fine
But thats how a walkie talkie works, it stays in Receive Rx mode UNTIL you press the PTT button,, then it Transmits Tx, and when released it goes back to Rx, receive?
Feb 18, 2010 | Radio Communications
Eddie Bauer EBC 530 walkie talkie. What do the
The PTT is your Push-To-Talk button.
Oct 22, 2009 | Radio Communications
The power button on the talkabout is jammed into the on position so the walkie will not charge or turn on. How can we fix this or where can we get it fixed?
Please open the set with the help of screw driver , & check for functionality of switch , & remove any particle that is jamming PTT button . You can check the functionality of walkie talkie by pushing the PTT inner switch with the help of a screw driver.
Sep 02, 2009 | Motorola Walkie Talkie 2-Way Radio
Motorola MR350R  Two Way Radio Logo
217 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
