Question about Miele W310 Front Load Washer
Rinse light flashing
The rinse light is flashing
4 Suggested Answers
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
SOURCE: Flashing rinse light
this looks like your problem - my solution is here too.
Good luck with it.
http://www.fixya.com/support/t845361-washing_machine_problem
Posted on Aug 08, 2008
ercupa190
  • 12223 Answers
SOURCE: Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Posted on Jun 25, 2012
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Mar 11, 2015 | Samsung DMT400RHS Builtin Dishwasher
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol ABOVE the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the SANITIZE button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
Novotronic 1918 front load washing machine- not spinning 1st and 2nd rinse lights flashing
the flashing lights mean it's "disabled". You need a qualified repairman to service it further.
May 06, 2012 | Washing Machines
Kitchenaid dishwasher KUDS01DJ Rinse only light is flashing. control panel is frozen with only rinse only light flashing. does not respond to pressing of any buttons. I flipped the breaker switch,...
Ok, Turn breaker off at breaker panel. Just off then on. The rinse only light should be on.....not flashing. Now press the start button first and hold; then press the cancel button. That should cancel all lights. Then press wash button then start. If the light is still flashing after you turn off breaker....you might have a bigger problem. May need new control panel.
Aug 19, 2011 | KitchenAid KUDS01DJ - Multiple Color...
Flashing clean light and wont start. Is there a sequence of buttons to reset the switchboard?
sani rinse---heated dry---sani rinse---- heated dry.. all the lights on console should light then close the door, let run for 20 -30 secs, and cancel the cycle, if the problem happens again yo need t call a servicer. 1 time maybe a fluke but to happen again indicates a heating, issue somewhere(or a lack of heating)
Mar 04, 2009 | KitchenAid 24 in. KUDU02FR Built-in...
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
MY G892SCUPLUS MIELO DISHWASHER LIGHTS AND CYCLES ARE STUCK.
The rinse aid light means you are out of rinse aid. The salt light means you have to add salt to your built in water softener. If the drain/intake light is on, that is when you have a problem. It will flash when there is a problem. You have to count the flashes and that will tell you what the error is.
Sgt 48
Jun 01, 2008 | Miele 24 in. G892SCU Plus Built-in...
Miele W310 Front Load Washer Logo
139 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
