Question about Pioneer AVIC-F900BT Car GPS Receiver
Unit shutting on and off only while driving.
Did anyone find out how to correct this?
I had the same problem. Shop had information from Pioneer to send it to pioneer. The solve the problem by make some hardware updates, so they say. And really, I don't have the problem since.
(solving the problem in nov. 2008 till now)
Papapeer, The Netherlands
Posted on Jun 19, 2009
Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
When checking ensure that the drive belt and belt tension are okay as this can cause this error.
  • Check tacho resistance
  • check tacho placement
  • Check wiring for shorts
  • Check wiring harness connections between motor and main controller
  • Check drive belt for damage and tension
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
May 26, 2015 | Whirlpool Washing Machines
1989 trans am gta, 5.7 ltr tpi, replaced my battery with brand new gell cell, as soon as I connect positive cable ican hear fuel rails prime and continue, started car and after shutting off ignition
If the Oil Sending Unit becomes defective, it often keeps the fuel pump running even after the car's engine is shut off. Replacing the Oil Sending Unit should correct the problem. Believe it or not Pontiac uses the oil sending unit as a back up to power the fuel pump.
Nov 03, 2014 | Cars & Trucks
My True 23F has had extensive work performed since I bought it used. On two separate occasions, it worked well for a month, then shut down. At this posting, the compressor will not come on at all. ...
http://www.truemfg.com/pdf/InstallManuals/T-SERIES/t_series_english.pdf
this should take you to their site for a manual on your freezer. I has info on the time clock and how to set it.
First, be sure it has the correct power to the unit. I would then check the temperature control. Be sure it is sending power to the compressor unit. If a contactor is used, is the coil on the contactor getting the correct power? Start there and let me know if we need to go further. Good Luck
Sep 12, 2010 | True 23 cu. ft. / 651 liter Commercial...
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Nov 24, 2017 | Kenmore Dryers
A/C unit turned off- didnt realize we had a mat covering the unit
If the breaker had tripped, you'd detect some looseness in the trip switch, even though it may not appear to be tripped. Once you have identified the correct breaker, trip it to OFF and then back to ON. Also check at the unit; it will either have a service disconnect, a fused disconnect or a circuit breaker at the wall. Compressor units have a thermal relay that causes them to shut down on high temperature. Let the unit cool down thoroughly. If this is the issue, and you are standing close enough, you may hear it reset when it cools. Usually, cool down occurs in 30 minutes or less. Try it again, but don't leave it unattended until it has made it through several cycles and you are confident that the unit is back to nornal. If any further issues develop from this incident, shut the unit down, trip the circuit breaker for the unit to off and call a serviceperson.
I hope this gets you going again!
Best regards, W/D
Jul 11, 2009 | Amana Heating & Cooling
HP PAVILION DV 1000 WONT DO ANYTHING .
dont worry dude. seems tht u need a free diagnosis of ur system. the below mentioned link will help.
http://tinyurl.com/m7ghqz
Jun 17, 2009 | HP Pavilion dv1000 Notebook
Error code f 06???? anyone???
f 06 Drive Motor Tachometer Error (The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high speed spin, the door will be unlocked after 3 minutes.
* Check wire harness connections between the Drive Motor/Tachometer and the Motor control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
* Check the Drive Motor
*Check the MCU
*Check the Wire Harness
I got this information off a website after searching for a F 02 error.
May 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Right at the end of the wash an F17 code appears
F7
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Generally if everything checks good, you'll want to replace the MCU because it's not reading the motor correctly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 17, 2009 | Kenmore Elite 45986 Front Load Washer
Pioneer AVIC-F900BT Car GPS Receiver Logo
768 people viewed this question
Top Pioneer GPS Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
