Question about Mtd Garden
Lawnflite 404 won't cut grass
Deck lowers but grass does not cut
  • 97 Answers
SOURCE: The highest deck setting cuts my grass down to one inch.
leveling bolts hang from each side deck by frame...tightened up and level...will give you some more room....be sure the blades are not bent.
Posted on Jun 14, 2009
  • 32 Answers
SOURCE: How do I get my mower deck set properly? Any tricks?
check your front tire air pressures
Posted on Jul 26, 2009
woobie dog
  • 1273 Answers
SOURCE: 42" deck not cutting level
I had a similar problem, and the problem was fixed by airing up one of my front tires. This may not be all of the problem, but you should eliminate this before you go adjusting.......
Just a thought, --W/D--
Posted on Aug 05, 2009
  • 138 Answers
SOURCE: 2003 DLT3000 Craftsman riding mower. Air in tires
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Posted on Aug 26, 2009
  • 66 Answers
SOURCE: my 603 lawnflite ran over a man hole cover and
Should be just behind the dash
Posted on May 30, 2010
Testimonial: "Hi thanks will check it today,i also need a workshop manual for the 603 lawnflite 30" cut,would a manual from another lawnflite model be the same?,also has anybody else heard of the lawnflite 603 model or others, sucking manhole covers into its cutter deck,beware all lawnflite owners,this has happened to me on its second cut from new,i have cut our lawn with a westwood tractor for the last 26 years,and never had any trouble with manhole covers!!!!!!!!"
I would like a manual for a Lawnflite 404 please can you help?
Try Googling (lawnflite)(404)(manual) without parens.
Apr 24, 2017 | Garden
My John Deere D110 is cutting the grass to short on the highest deck level. How can I fix it.
level the deck off as a tilted deck will cut lower on the low side
adjust the deck mounting bars or deck pilot wheels
check that the cutter/pulley spindles are in good condition and not falling down
Sep 15, 2016 | John Deere Garden
John deere d110 not cutting grass
check belt and pulleys --if belt to loose wont turn blades to cut the grass
Aug 31, 2016 | John Deere D110 42 in. 19.5 HP...
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
Yard works 4.5hp 42" cut lawn tractor cuts fine when mower deck is up on 4, but when it is lowered it cuts out and won't cut the grass.
4.5 hp will not power a 42 inch deck any way you cut it quite likely the blades need sharpened real bad .motor needs to run fast when tryng to cut also as that throws the grass out of the deck
May 27, 2015 | Garden
I want to set the wheels for the deepest cut. In what direction should the wheels be adjusted-up or down?
If you move the wheels up, thereby lowering the cutting deck, it will cut the grass shorter on each pass.
If you move the wheels down, thereby raising the cutting deck, it will leave the grass longer on each pass.
May 04, 2011 | Garden
Where can I find the diagram for the cutting deck belt routing for an MTD Lawnflite tractor mower 13AA478E678
Hi go onto the powerhouse site below, put in your mower details and you will see the plans for the deck.
Geoff
www.powertoolspares.com/...lawnflite.../906-13af765n611-1998-576/
Oct 19, 2010 | Garden
Uneven grass cut, makes the lawn look striped.
First make sure all the tires have the same pressure of air.
Then I would measure how much the one side of the deck is higher than the other. Then I would look under the tractor and there should be a horrozontal bar atatching to the deck and a bar coming down from the mower into this bar. usually there is a nut on the bottom than can be tighened or loosened to raise or lower the deck on that side.
There might also be a nob on the tractor that shows a picture of tall grass being cut, if you turn that that might also raise or lower the deck on either side.
Apr 22, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
57 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
