Question about Audiovox Televison & Video
My Audiovox PVD80 will not play. It says that there is no disc. I have tried using new disc and cleaning lens and nothing has worked. What do I do?
SOURCE: used lens laser lens cleaner & now player won't play.
Hi Mollins, did you ever resolved your DVD player issues. I have the same problem and I dont know what to do.
Posted on Mar 14, 2007
  • 78 Answers
SOURCE: Disc won't spin,
If your PS2 slim console is chipped for playing fake games then try it by replacing the modification IC otherwise replace the lens with new one and your problem should be solved.
Posted on Aug 22, 2007
DoctorLes
SOURCE: DVD player
DO NOT LOOK AT AN OPERATING LASER INSIDE A CD PLAYER OR DVD MACHINE; DOING SO CAN DAMAGE YOUR EYES!
ANY OF THE BELOW DESCRIBED PROCEDURES MIGHT DAMAGE YOUR EQUIPMENT MORE THAN IT IS, SO PROCEED AT YOUR OWN RISK SO I AM NOT ACTUALLY RECOMMENDING THEM :
Often, in cases like this, the focusing lens for the laser is dirty or out of alignment. I don't know how good you are with tools and electronics, but one often has to take out the dvd player to reach the lens directly to clean it. You'd have to be very careful not to scratch the lens or leave any lint, even a tiny hair; you can also knock the movable trolly out of alignment.
I've had good luck with a bit of 90% rubbing alcohol and a cue tip, but some say you need special cleaner. Sometimes a blast of compressed air from one of those cans specially designed for cleaning electronics parts is enough to do the job.
If you can see the lens and you have a long enough red plastic tube that comes with the can you may be able to blast it clean without disassembly. Note that there is a focusing lens and a laser with a lens on it; both often need cleaning, but the lower lens is generally inaccessible without significant disassembly.
Lastly, there are a number of good DVD and CD repair hints for this exact problem because it's fairly common and the fix is generic. You can find these on the web with Google, Just type in key words like " DVD Can't read disc error", or something similar.
GOOD LUCK!
Posted on Jan 20, 2008
SOURCE: Will not recognize dvd discs
Welcome to the sansui got ripped off club...c-104 is more common than rain in washington...no disc? thats what the unit finally displays when it has taken a thorough dump. Give your sansui to someone you don't like, and go buy a panasonic.
Posted on May 11, 2008
  • 814 Answers
SOURCE: Audiovox pvd80 region problem
Audiovox code hack For DVD player D1210
1. power on
2. SETUP
3. in setup digit 9653
4. go to new menu VERSION
5. in region use UP/DOWN to change region
6. power off and power on
7. Enjoy!!!
I hope this information helps you with your problem
Posted on May 30, 2009
Player stays in loading mode never finishing and playing the dvd
see the causes and fix it: God bless you
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Clean with disk cleaner the Lens +OPU
Jul 21, 2012 | Audiovox D1812 Portable DVD Player
It won't press the button even though the power is on
Since you don't indicate what you mean by "won't work", let me provide a few possibilities:
1) You close the door and you can hear the DVD spin, but no reaction on the screen other than some type of "loading" message. This indicates that the optics are attempting to read the DVD but are having difficulties. The operation may ultimately be successful and the DVD may start, but the movie will be unwatchable because of freezes etc. In this case, try cleaning the lens using a cotton swab and alcohol. A dirty lens can cause this.
2) You close the lid and do not hear the DVD spin. In this case, the optics can not even determine that a disc is in the machine. Again attempt to clean the lens. If that fails to at least cause the disc to spin, the optics have failed and need to be replaced.
3) Try a music CD. If that plays OK, but a DVD does not, then the optics are defective and need to be replaced. DVDs require a more powerful laser and will typically fail sooner than CD levels.
Hope this helps,
Dan
Jul 10, 2008 | Audiovox Televison & Video
When i put a dvd in player tries to load but then it says no disc. model hrdv700m audiovox
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Apr 21, 2011 | Audiovox Televison & Video
My JVC HX-Z1 cd player not working, no sound when disc is playing
Please try another good disc on your player. If nothing change , get your lens cleaned by cd lens cleaner. Repeat cleaning 2-3 times and retry it back. If still problem , please replace your lens with new one.
Regards, Jay
Feb 02, 2011 | JVC HX-Z1 CD Shelf System
Dvd player stopped working. I put dvd in and it starts turning and says loading and then says no disc & stops turning.
Hi there
Two things can cause the problem you are experiencing,
1.the dvd you are trying to play is bad or
2. the lens of your dvd player is bad
What you should do is to try playing several dvd's to see if they work,if they all do then the particular dvd you are trying to play is bad
If some do not play then the lens is bad ad you should open up the dvd player and clean the lens with a cotton wool dabbed in a little bit of methylated spirit
after cleaning,test the dvd again to see if it plays.
If the problem occurs again,the best solution is to replace the lens of the player because it has become too weak..
Jul 04, 2010 | Audiovox D1718PK Portable DVD Player with...
DVD not playing
Try a cleaning disc the lens maybe dirty. It can't read the DVD. How long ago have it been since you used it last? The lens could be dusty.
Jul 22, 2009 | Audiovox D1710 Portable DVD Player with...
Audiovox pvs69701 trouble shoot. When I insert a DVD the unit begins to read the DVD and then then says ''no disc''. It has worked well in the past and I have tried many different DVDs to see if it the...
Open the casing, check the following and follow the instructions.
1. Clean the lens using cotton or cotton cloth.
2 Take extra care not to touch the lens with bare hands.
3. If the player displays "no disc" right after closing the tray then
check capstan motor if it spins smoothly.
4. Replace capstan motor if it cannot spin smoothly or if it seems it
cannot spin the disc.
Jul 17, 2009 | Audiovox Televison & Video
Head spins and say "Loading" but then says "No Disc"
I cleaned the lens, but I also tip the play upside down with the disc in it and it seems to work.
May 27, 2009 | Audiovox D1917
1. power on
2. SETUP
7. Enjoy!!!
Mar 31, 2009 | Audiovox D1210 Portable DVD Player with...
No longer loading dvds
You may have a bad laser. First, make sure the laser assy. travels back and forth easily, then make sure the table the disc sits on spins freely. If it still isn't reading, load a disc and immediatly flip it over to it's top and see if it works. Working or not, still a bad laser.
Feb 12, 2009 | Audiovox D1708 Portable DVD Player
Televison & Video Logo
103 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
