Question about Vehicle Parts & Accessories
My vw lt40d only runs when I put the fuel pipe direct in the petrol can
9vw v
    New Friend:
    Problem Solver:
  • 8 Answers
The fuel filter probably needs replacing, or the fuel line will need replacing.
Posted on Jan 25, 2015
Air in the fuel system
can be a tricky one, here some steps to try. if its a petrol vehicle try disconnecting fuel pipe closest connection to carb or injectors and put a cloth over and gentle suck on it. if diesel you can bleed air out of the injector pipe by slightly loosening no1 injector pipe. open fuel lid and blow into tank(with compressed air if available) and will start spitting air and the fuel will start coming out reconnect pipe tighten properly. opening the tank and using compressed air can be used on petrol or diesel. try rapping a cloth round air nozzle to close for air escaping. when putting in the tank. let it release from time to time otherwise it mite damage a pipe. good luck.
Jul 06, 2016 | Miscellaneous
My 2005 kia optima LX ran out of gas and now it won't start, put gas and new battery but still won't start . please help
Paul is on the right ball - it sounds like fuel - turn over the engine with the pipe disconnected until the fuel comes through - if you don't succeed, consult a reputable shop - you need someone that knows what they are talking about to physically look at the car to solve the problem - this will save you a lot of time and expense. ?
Jul 08, 2014 | 2005 Kia Optima
Holden barina carburettor problems
feed line blocked from petrol tank test to see if petrol is coming through , replace feed pipe also check carb float chamber needle could be bent thats why its not drawing petrol through hope this helps
Feb 07, 2014 | Garden
I have been told that my 1999 Cadillac Deville may be experiencing hesitation and rough running because the fuel filter may need to be replaced. Are there any instructions for that?
First we need to check if really fuel filter is at fault for rough running. Open the bonnet and pull out fuel pipe from the engine. Put this pipe in a clean and empty clear bottle (so that you can see the pipe) and now switch on the ignition but do not start the car, just turn it on. See the flow of fuel, if its constant then rough running is due to something else and if your fuel filter is really clogged then petrol flow will not be constant. To change the fuel filter, get under the fuel tank and locate a plastic cylindrical component with two fuel pipe connected to it. This is fuel filter. Buy a new one and replace. Make sure you check the pipes for any fuel leakage after you have connected the new fuel filter.
Aug 17, 2011 | 1999 Cadillac DeVille
Not getting gas in the carb. changed pump. poured a littlr gas in the carb good compression but dies when gas runs out
get a oil can the thumb operated type and squirt some oil down the petrol pipe and make sure pipe is upwards so the oil runs into the pump then leave for a while to wet the valves in the pump then crank engine to make sure petrol comes up or just refit the pipe and pour some petrol down the carb and watch it go
Aug 16, 2011 | 1986 Dodge Ram 50
I have a ford focus 1.8 diesel x reg 1999 girlfreind put petrol in it about 3weeks ago we have drained it all re fueled it and it started and run but now it wount start
poss the fuel filter has petrol in it,replace filter,turn engine over with fuel line unattached to clear lines then fire up,should be fine.you may hve a hot start problem for awhile but fill up with diesel at 1/2 tank to dilute any petrol left.in 32 years in the trade i have put petrol in so many diesel cars,and as long as it starts,keep it running,and start only when cold ish.
Apr 24, 2010 | 2000 Ford Focus
I have a vw sharan v6 dual fuel but will not run
The fuel system is switched from L.P. to petrol by use of a solenoid.
The soleniod is operated by a relay.
The relay is electrically protected by a fuse.
Check all 3 starting with the fuse and checking back.
Please let me know what you find.
Feb 10, 2010 | 1997 Volkswagen Eurovan
How to drain ford fusion fuel tank
The "MOST EFFECTIVE
" way is to REMOVE The FUEL TANK and DRAIN it By Tipping it over to Pour From FUEL INLET HOSE. Im Sure you Dont want to Here this as it Requires Much WORK . , BUT It IS The MOST EFFECTIVE Way to EMPTY The TANK.
Oct 31, 2009 | 2004 Ford Fusion
78 VW camper has Gas leak after filling tank, other side of the
I had the same problem as this. There is a pipe that runs from the petrol tank around and up into the air inlet shaft under the spare wheel well. I am not sure exactly what it does I think it has an expansion valve on it. There is a join in this between two tubes that join. This is a simple piece of fuel tube with an internal dimension of say 5mm. If you feel your hand into that air shaft there, locate the fuel tube feel your way along the pipe, you will find the join. Just pull the old one out and put a new piece in. Very simple. really
Sep 05, 2009 | Volkswagen Camper Cars & Trucks
1996 VW T4 2 litre Petrol Transpoter, fuel mixture problems
usually black smoke is a good indication of a blown head gasket check the oil to see if it look milky will look kinda brownish like chocolate milk or cocoa
Apr 11, 2009 | 1996 Volkswagen Golf
Vehicle Parts & Accessories Logo
35 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
