Question about Motorola Canopy 5200SM
How do i connect my computer to Motorola Canopy 5200SM
Connecting to computer
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions
Get Support
Mark
Motorola Support
Posted on Jan 17, 2015
To access canopy via laptop
Go to your main router's page and look for a section that lists the connected devices. The canopy should be listed there.
Mar 11, 2014 | Motorola Canopy PTP 54300 Wireless Bridge ...
My motorola canopy cannot detect LAN Destination Host Unreachable?
Sir raymond, how can i access my Motorola canopy? when i upgrade the firmware to the latest version and didn't specify the correct IP address of canopy instead of example: 10.223.41.42 i used the 169.254.1.1 in CNUT after upgrading the version my PC LAN card cannot detect anymore the canopy. canopy lights still blinking inside but in PC LAN card not blinking and its says network unplugged. how to fix the problem.. please send me the step on how to fix it.. here's my email add: amanics007@hotmail.com waiting for your response. thanks!
Apr 20, 2013 | Computers & Internet
I have a set Motorola Canopy 2400BH but i forgot ip address and username and password, how can i access it for using.
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug: 1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable. 2. Pin out all 6-pins. 3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to anything. The result should be as follows: Pin 1 ? white / orange ? Pin 1 Pin 2 ? white / green ? Pin 2 Pin 3 ? white / blue ? Pin 3 Pin 4 ? green ? Pin 6 Pin 5 ? blue ? Pin 5
Regaining access to the module To use the override plug 1. Insert the override plug into the RJ-11 GPS sync port of the AP. 2. Apply power to the module through the Ethernet cable. RESULT: The module reboots with the default IP address of 169.254.1.1, password fields blank, and all other configuration values as previously set. 3. Set passwords as desired. 4. Change configuration values if desired. 5. Save the settings. 6. Remove the override plug. 7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
Apr 30, 2011 | Motorola CANOPY 2400AP (2400APBC)
HI. I cannot access my Motorola Canopy 5440BH with its IP address
There is a great article at Working with Windows Wireless Networks
If you need more help post back! Thumbs and testimonial are welcome!
Jan 12, 2011 | Motorola CANOPY 5.4GHZ OFDM 21MBPS...
Connection between 2 back-Holes 5.7Ghz canopies 4000 feets apart
www.acq.osd.mil/osbp/sbir/solicitations/sbir022/word/army022.doc
Aug 02, 2010 | Motorola Canopy 5.7 GHz Wireless Access...
Im using Motorolla canopy 5.4 and 5.7, both ,they are confiruged whith ip addresss in the range of class A, my problem is that in lot of them i cannot access thru web page, what should be wrong on this...
I would advise you to be sure that your routers are MDI/MDIX Compatible, (i.e it can allow you to use either a straight-through or cross-over cable).
If not, then try using a cross-over cable when connecting the routers together.
Also, try making your router's LAN configuration to be DHCP and the one for your Wireless Access Point Static.
Then make sure that they are all in the same Subnet. This is also very important.
Try out these few troubleshooting steps first and keep me posted about the problem.
Hope it helps.
Goodluck
Nov 14, 2009 | Motorola Canopy 5.2 GHz Wireless Access...
Frog canopy removal
Pull gently on the plastic arches that support the canopy (on either sides - where they connect to the stroller) and slide the canopy off.
Nov 05, 2008 | Bugaboo Frog Stroller
Motorola canopy
Just go to the configuration tab then QoS (quality of service) and set your sustained up and download links at 20,000 each. that will open you up to all thats available.
Sep 24, 2008 | Motorola Canopy 5.2 GHz Wireless Access...
Not connecting to internet
When you power down the canopy, what happens is you also do a hard reset which from your post re-establish the connection.
One of the many possible causes is that the canopy is loosing its DHCP lease on its assigned IP add. This may be a security feature/measure of your ISP limiting assigned IP add through a DHCP server for only a couple of hours to clients such as yourself. If this is the case then you have to bring this to the attention of your provider;
Another that you can try is to telnet to the canopy interface and check its settings. Its IP add is 169.254.1.1(255.255.0.0). Newer versions uses the 10.X.X.X (255.0.0.0) series, pls check which one you have.
Alternately, what can be done is to do a soft reset (not powering down/hard reset). Right click on your Networking icon in the System Tray and click on "Repair".
Other areas you can check/try are your router settings (if you are using one), settings of HTTP1.1 through proxy connections in IE, fix DNS (you can get them from your ISP). If you are using XP, there is also a registry tweak for DNS errors resulting to no connection (winxp_dnscache.zip).
Hope that this be of some help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Dec 31, 2007 | Motorola CANOPY 2400AP (2400APBC)
Computers & Internet Logo
54 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
