Question about Nakamichi Car Audio & Video
Nakamichi power button light blinking
Display is on
Going on standbymode and power green light blinking TA4 nakamachi
I'm not familiar with this product, and there the best I offer is that you consult the user guide (which you probably already have)
http://www.ps2netdrivers.net/manual/nakamichi.ta-4/#manual
or (buy) a service manual (which it seems includes a troubleshooting guide) from any of a number places, two are given below:
http://www.manualszone.com/en/nakamichi-service-manuals/62888-NAKAMICHI-TA4-service-manual.html
and
http://www.nakamichi.owner-manuals.com/TA4-service-manual-NAKAMICHI.html
All three manuals/guides are available from
http://www.hifiengine.com/manual_library/nakamichi/ta-4.shtml
There other websites where you an download the service manual (I don't know if the are the 'official' service manual, or different ones that have been written by different people).
If you are really stuck contact Nakamichi through www.nakamichi.com or (what appears to be a more friendly site) http://www.nakamichi.co.uk/support
24.August.2014
Aug 24, 2014 | Audio Players & Recorders
Nakamichi ta3a
the audio amplifier ic is faulty. replace... should be replaced
Apr 02, 2014 | Audio Players & Recorders
My Sound Space12 powers on but there's no display and no manual or remote functions to operate the discs or the other functions.Can you provide a answer.regards
If the system is connected properly and the main tuner power is on you will see the orange standby light on in the front of the main diamond shaped control unit. If that light is not on, you have not connected the system and power cables properly.
If the standby light is not lit, press the power on/off button in the middle of the rectangular processor/tuner to turn it off and unplug the main power cord from the main tuner/processor from the wall. Next, ensure that all of the power, video and audio cables from the diamond shaped control unit are properly connected to the large tuner/processor. Since you are there, check any other av in/out connections.
Now that you have checked and adjusted the cables between the controller and the tuner, plug the tuner back into the wall and push the power on button. Now check the standby light again on the diamond shaped controller unit.
Once that light is lit, press the silver, horizontal on button in the middle of the diamond shaped display unit, or the Power Standby/On button on your main remote control and you are operational.
Mar 05, 2011 | Nakamichi SoundSpace 12 System
I'm trying to program my Dish Network remote to my Nakamichi AV-8 and can't seem to make it work. I know I'm doing it correctly because I've tested it with another receiver. Any ideas on which code I...
We would be happy to help with that. Here is a list of someof the codes that we have for your Nakamichi Receiver: 671, 748, 750, and 649.
Press and hold the AUX mode button until all mode buttons at the top of theremote come on, then release. Enter the number 2 then one of the codes for your Nakamichi Receiver provided above. Press the pound (#) button, the mode light should flashthree times. Check that the code works by trying several different functions onthe remote to make sure it will properly operate your Nakamichi Receiver. Keep in mindthat some codes may not be compatible with your equipment. If this is the case,please try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps you, and thank you for being a valued DISH Network Customer!
Phillip Chang
DISH Network Customer Service Representative
May 27, 2010 | Nakamichi AV-8 5.1 Channels Receiver
The power button is not working it blinks a green light
Disconnect the display from the Computer and remove its power plug. While the display is turned off, press and hold the power button for 30 seconds. After two minutes connect the power cord and the display cord to the Computer and the power source and turn it ON.
If the power indicator on the display keeps blinking, then it's required to open it up to repair it.
Feb 26, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Circa 1980 nakamichi tuner amplifier TA-3A
Hi jac48k
Anything branded Nakamichi is worth repairing in my opinion. The problem may be something quite simple, or worst case a blown output stage. First check that there are no problems with the speaker wiring or speakers. This can be done quickly by disconnecting the speaker wires and see if the unit fires up correctly. If it still shows the protection mode by blinking power light, then it will need some repair work done. If you are not versed in electronic repairs, fault-finding or soldering, then i suggest looking fpor a repair guy. Contact your local HiFi specialist retailer, They always know who you can trust to look at it for you, if not take it on themselves. Good Luck.
regards
robotek
Sep 01, 2008 | Audio Players & Recorders
Change the time
make sure the time is displayed and press the "set" button. once the time starts flashing use the "preset" buttons to set the hour and the "volume" buttons to set the minutes. press "set" again when done.
Mar 14, 2008 | Nakamichi SOUNDSPACE 1 CD Player
NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Dec 06, 2007 | Audio Players & Recorders
Car Audio & Video Logo
26 people viewed this question
Top Nakamichi Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Jaime Hernandez
Michael Galve
Michael Galve
Are you a Nakamichi Car Audio and Video Expert? Answer questions, earn points and help others
