Question about HP PSC 2355 All-In-One InkJet Printer
Paper feed problems
I load paper but when printing starts, it takes the paper in too far, as if it's going to start printing halfway down the page!  Then the printer says it has a paper jam.  It's as if the printer is set for a piece of paper 1 1/2 times the size of A4!!
  • 1 more comment
  • kalamity Dec 09, 2007
    I have the same problem and just cannot get a sheet of paper to feed.
  • alispeny Dec 28, 2007
    I have exactly the same problem. Any answers?
  • heljohnson Jan 07, 2008
    After 4 days of emails back and forth between myself and the HP Support Team, I took it to an engineer who declared it dead - it wasn't financially viable to fix the machine so I bought a new one.
    Master:
  • 619 Answers
Set your printing job in print preview you can adjust inexact spaces in four corner of sheet of papers./ do't print w/out prvieew
it will wasting ink and papers.
Posted on Jan 07, 2008
My HP 4ML has been printing fine until recently. Every print job, big or small, the first couple of pages print the pages mostly black, then start to fade the more pages I print in the same print job. ...
You didn't say that you swapped out the toner.
Let's come back to that point later.
Put paper in the manual feed tray.
Print something.
As soon as the paper feeds halfway into the printer, open the top cover.
Pull out the toner, look down at the paper. Is it mostly black?
If the answer is yes....replace the toner.
Vacuum out the inside of the printer and print again.
I think you have a bad toner cartridge
Feb 01, 2011 | HP LaserJet 4ML Printer
Leaving black streaks down paper? Ink cartridge
If this started after cartridge was replaced, then it is probably defective.
Take the cartridge out and take a look at the print head. Clean the print head.
Put the cartridge back in
Try and feed paper (not printing anything on it, if you can not get it to just feed paper, print a blank page) and see if it still has lines. If so, you are probably going to have to clean ink from inside the paper feed area. If not, try using it for a while and if it starts again, get a replacement cartridge. You might want to save some of the bad prints to show the clerk and try to get the new cartridge under warranty.
Mar 18, 2010 | IBM Infoprint 1612 Express Printer
HP Photosmart C6280 Will not feed paper correctly
Please onsult this HP support article and follow the steps outlined there to clean the rollers, etc. Frequently this roller cleaning and possibly a reset is all that's required to clear the jam error. (If you have access to compressed air, you can gently blow air throught the printer to clear out paper dust and debris from inside.
Also be sure to follow the instructions in the manual or here to load the paper correctly, fan sheets before loading, and if the problem continues, try flipping the stack of loaded paper upside down and reloading, or try another kind of paper..
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 03, 2009 | HP Photosmart C6280 Printer
Paper not loading
Most of the Lexmark printers (including the Z- and X- series) pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print the self test page.
Please follow the steps given below to perform the self-test:
1. Turn the power to the printer off by pressing the “Power” button once.
2. Press and hold the “Start” button and the “Power” button.
3. Once the screen will display “Mfg Menu Enabled” release both buttons.
4. Press the “Mode” button 3 times. All of the indicator lights will go out and the screen will display “LCD Button Test.”
5. Press the “Up” arrow button two times. The screen will display “Single Test Page”.
6. Press the “Start” button once.
7. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridge installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without the cartridge installed, run the self-test again with only a color cartridge installed. If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Apr 10, 2009 | Office Equipment & Supplies
Rolling halfway down the page
is the form tear off on?
if it is try changing it to off
Dec 03, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Paper feed problem
Try changing the bottom margin in your print software.
Oct 25, 2008 | Samsung CLP-500N Laser Printer
Won't take paper
Clean The Paper Feed Rollers Using The Unit's Operation Panel If the paper feed roller is dirty, paper is not fed properly because the paper feed roller slips. Cleaning the paper feed roller could resolve the paper feeding problem. Please follow the instructions below to clean the Paper Feed Rollers directly from the unit. Caution: Since the cleaning process wears down the paper feed roller, perform this procedure only when necessary and no more than three (3) times.
  1. Ensure that the machine is powered on and remove any paper from the auto sheet feeder or the cassette.
  2. Use the <Feed Switch> button to select the paper source where you do the paper feed roller cleaning. Click for additional information.
  3. Press the <Menu> button.
  4. Use the right / left cursor button to select [Maintenance/settings] press the <OK> button.
    Note: This procedure is skipped if your machine is in Scan mode. Proceed to step 5.
  5. Use the right / left cursor button to select [Maintenance] and the press the <OK> button.
  6. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  7. Use the up / down cursor button to select [Yes], then press the <OK> button. (The paper feed roller cleaning starts.)
  8. To check if the rollers are clean, load a sheet of Letter-sized plain paper in the same paper source you selected in step 2, and press the <Open> button.
  9. Use the up / down cursor button to select [Roller cleaning] and press the <OK> button.
  10. Use the up / down cursor button to select [Yes], then press the <OK> button. (Paper will be fed.)
    Note: If paper is not fed properly, repeat steps 4 through 10 above up to three times.
Paper Source
Press the <Feed Switch> button to switch to toggle between the Automatic Sheet Feed (ASF) or Cassette. The light will come on when the <Feed Switch> is set for that paper source.
ASF
Cassette
Note: When printing from the computer, if paper does not feed from the source you have selected on the operation panel, check Paper Source setting in the printer driver. If the option is not set to 'Paper Feed Switch', paper will feed from the source selected in the driver.
Click to return to step 2 above.
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
Paper Loading Problem
rollers can use a little cleaning sounds like..
Mar 23, 2008 | Lexmark X3350 All-In-One InkJet Printer
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
HP PSC 2355 All-In-One InkJet Printer Logo
175 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
