Question about Tools & Hardware - Others
Pin loose & spring fell out
Reassemble proshooter all In 1
4 Suggested Answers
comax
  • 154 Answers
SOURCE: Transmission fell apart. Looking for blueprint to reassemble.
The transmissions come as an assembled unit and there are no drawings for the internals. If you can find an old drill that is no good, use it as a guide.
Hope this helps
Posted on Apr 14, 2009
Richie_asg1
  • 1036 Answers
SOURCE: a pin and spring fell out of the drivers side
This is probably at the door check area. Compare one side with the other side door.
To refit the spring, you may have to take the whole inner door card off just to get to it, but if it came out, you may have a good chance at replacing it.
Normally there is a screw retaining these that may be missing also.
Posted on Feb 16, 2010
SOURCE: to replace the fuse in
Garmin 650 not allow to type password and open. What to do ?
Posted on Sep 12, 2011
KitchenaidKsm6573CER1 the shear pin retaining fell out
If you are referring to the pin that holds the stand-lift lever to the stand-lift mechanism, then you'll have to remove the Motor Housing, remove the motor and the three screws below it. Then you'll want to seperate the Column from the Base by removing the three screws at the bottom of the Base. You can then access the lift assembly and all you need to do is reassemble the lever and the plastic hitch (forgot the specific name) to the bar with the spring and nut on the bottom, then secure it in place with your shear pin. (The pin may have to be re-bent into shape with needle-nose pliers, and I also advise putting "Locktite" onto the threads of the six screw that are used to secure the base and column to the lower gearcase.)
I hope this helps!
Nov 23, 2014 | KitchenAid 6000 HD STAND MIXER 6 qt BIG...
Pulled the wrong plug spring and pin fell out, pin goes in larger rounded in first or smaller end?
I have a 2005 Suzuki dr-z125 I puld the wrong plug and a spring fell out what do I do?
Jun 11, 2012 | 2007 Hyosung GT250R
Clean 45 acp 1911 handgun
Are you asking how to clean an ACP 45, 1911 style? If so, its just a matter of removing the clip. Removing the slide, then removing the barrel and spring.
1) MAKE SURE IT IS UNLOADED!!! (cycle the slide several times)
2) Remove clip and Cycle the slide again to verify empty!
3)There is a pin just above and forward of the trigger mech on the frame of the pistol. One side of the pin will be rounded and protruding from the right side of the gun. On the left side of the frame will be a small flat arm that is connected to it the pin. Push the body of the slide towards the hammer (approx 1/8-1/4 of an inch) and you should be able to remove the pin out of the frame (towards the left side of the frame), it might take a bit of wiggling to get it out. All the while, continue with backwards pressure on the slide.
Once the pin is out the slide can move forward and can be removed from the gun.
4) At this point the barrel/ spring and trigger mech will be exposed. You can remove the barrel and spring for proper cleaning of the frame, trigger, barrel and spring. Then relubricate all components.
5) Reassemble in reverse order.
Good Luck
Jun 04, 2012 | Heating & Cooling
Left rear spring fell out of car. What could
the shock may have broke or came loose or the spring broke and fell out,take a look at the springseats at the top and bottom to make sure they are not rusted or broken then look at the shock if nothing is broken or missing bolts then the spring just broke and fell out,
May 10, 2010 | 2001 Volkswagen Beetle
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
May 09, 2010 | Braun Silk-epil 3370 Epilator
Removed water pump on 1995 maxmia tension spring fell into engine
Take a pin magnet and reach down in there and get it. Good luck.
Jan 20, 2009 | 1995 Nissan Maxima
LG wd8013F bowl support plastic pin fell out. I turned machine upside-down, replaced plastic pin, now doesnt wash or spin.
(A) Set-up
1) The inner bowl is supported by (2) heavy springs at the top, plus (2) telescopic shock absorbers beneath the bowl.
(B) Observed Problem
1) Inner bowl was missaligned, causing out of balance knocking & banging, also drive belt was squealing from misalignment.
(C) Remedy:
1) Disconnect power from outlet.
2) Remove (4) screws from back plate, remove back plate.
3) Bowl is suspended on (2) heavy springs from top, and (2) telescopic shock absorbers below bowl.
4) Inspection showed plastic pin retaining shock absorber end to frame had fallen out.
5) Place old carpet or whatever on floor, invert washing machine.
6) Re-align end of shock absorber into housing piece.
7) Re-insert plastic pin (about 2 inches long x 1/2 inch diameter) securely into place.
8) Re-assemble.
Also:
a) It could be one of the top springs as per (B)1 above may have broken or become loose.
b) In this case the top cover plate is easily removed from machine by removing (2) screws at the rear top of cover.
This gives access to the (2) heavy springs, which are easily repaired.
Note:
Sometimes the machine will not re-start again following out of balance problems.
1) Turn power off again, re-boot like computer.
2) There is also a re-boot procedure similar to Alt+Ctrl+Del on computer.
3) Use three buttons simulateously, Start+spin+option buttons or similar.
4) I fiddled with these until all lights lit up, then after a while the machine worked satsifactorily.
Cheers
Nov 06, 2008 | LG Washing Machines
1471 Pfaff sewing machine will not reengage needle
Possible solution...when you reassemble, the spring needs to lie flat in the channel under the center black slide. When you put the cover back on,the pin or post that sticks up on the black slide has to be in the curved cam slot on the inside of the cover. If it isn't the slide won't move in and out of the slot to engage the main drive.
Jan 25, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Tools & Hardware - Others Logo
15 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
