Question about Cannon i70 Printer
Paper wont feed
Paper starts initially to feed then stops, makes loud noise then yellow light flashes
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
Could be a piece of paper stuck somewhere, open all access areas and check carefully, sounds like an obstruction somewhere
Posted on Jan 31, 2015
Paper will not feed
Check inside the machine at both ends of the cartridge carriage path i.e. far left and far right. Check for scrunched up paper and note, if it is there, it will likely be black with ink. If found please remove. Next take the back off the machine (there is usually a removable plate there to get to paper jams) and remove anything you find there. Also look right through towards the front and see if the little drop down paper feed sensor arms are all visible and swing freely. If not, fix them as you can. Once you have done these things, put everything back together and leave the printer powered off for 30sec. Power it up and see what happens. If you are still no go, either take it to a service tech or check to see if your insurance covers printers being beaten to death with a 4 pound hammer.
May 14, 2015 | HP Office Equipment & Supplies
Paper won't feed yellow light flashes on my hp deskjet f4440. Followed every instruction I could find without improvement...
I had same problem. It ended up being a paper jam altho I could never see anything jammed in the paper paths. Perhaps it was a tiny piece of torn paper that I couldn't see. Anyhow, I fixed it by taking a piece of 8.5x11 cardstock and manually pushing it into the paper feed path in between the rollers. It did not go all the way through so I pushed it in and pulled it back out a few times. Apparently it dislodged whatever was causing the jam and the doggone yellow light finally stopped flashing!!! good luck.
Sep 17, 2010 | HP Office Equipment & Supplies
The paper feeder wont do it's job,will not feed paper . Makes loud noise but no action, then screen asks to load paper.
The feeder on this model has 1 weak mounting place for the gears that drive the feed roller. The plastic stud that holds the gear will break off of the frame and cause the noises you hear and no paper feed. The only fix is to replace the sheet feeder assembly, about $30.00 for the part.
Feb 21, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Stops feeding paper at start of printing and repeatedly states there is a paper jam. why wont it feed and how do I get paper out as it is a sealed unit. initially paper was feeding too far thr so printing...
With out knowing the make and Model of the copier it can be difficult!
Suggest that you clean the rollers that pick up the paper with a clean lint free cloth and water.Ensure that you unplug the machine from the power point first.
Dec 06, 2009 | Office Equipment & Supplies
Paper light flashing popping noise
The problem sounds like the rear paper guide of the paper tray is too tight aginst the paper. Back the guide off about 1/16 of an inch and see if that helps. You may also want to check and make sure the tray is set for the correct paper size of the paper you are using. Good luck!
Oct 09, 2009 | Brother HL-5240 Laser Printer
My printer thinks it is out of paper when it
please try to set it to manual feed
with manual paper feed it wont search for a paper and wont give an error
Thanx and i hope this helps
PLease rate this solution
Jul 16, 2009 | Epson Stylus Color 777i InkJet Printer
Cannon pixma mp 610 printer paper feed making loud noise no feed
Replace the pickup rollers and check the Gears if they become bad.
Best Regards
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Mar 11, 2009 | Canon Office Equipment & Supplies
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
Paper will not feed after initial start. Gives jammed paper read but cannot see any paper inside ink compartment. then makes a lot of noise and stops with paper feed just starting in.
Since you did not specify a model I am going to assume you have a top feed model.
Remove the paper, flip upside down and shake.
Does anything seem to be in there rattling or fall out?
I had somebody bring in a printer for servicing because paper would not feed, turn out her kid was eating while standing over the printer. A half a pretzel came out...
But then this could have nothing to do with your problem
Oct 11, 2008 | Lexmark Office Equipment & Supplies
Not printing
There is probably a paper jam in the tray feed path. The other situation is that the tray paper pick up roller has become hardened/polished, or the paper tray paper is greasy. First step, take the paper from the tray, and fan it out, so each sheet is separated from the next. try it with jut a dozen or so sheets, change the paper.
Thoroughly check the paper feed path.
If not working, then check/clean the rollers.
Jan 20, 2008 | Kyocera FS-720 Laser Printer
44 people viewed this question
Top Cannon Office Equipment & Supplies Experts
Iqbal Husain
Iqbal Husain
Victorman
Victorman
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
