Question about Kenmore Refrigerators
Kenmore freezer keeps opening
We have a Kenmore top freezer refrigerator. The freezer door opens when we close the refrigerator. Is there an easy fix. It's annoying to have the alarm go off all the time, although I'm glad it alerts us that it is open.
    Scholar:
  • 72 Answers
Could also be that the unit is not entirely level and the shock from closing the fridge is releasing the air seal in the freezer and making it pop open.
Posted on Jun 15, 2009
  • 105 Answers
Tweak the hing locations on the freezer side to make it swing closed. sounds like it is tweaked to the other way.
The bottom freezer door on my Kenmore refrigerator 795.7900 pops open each time I close the top door. I have tried adjusting the leveling screws and it hasn't helped. Any suggestions?
Glen you keep adjusting but before that try to find this unusual problem. On its own, doesthe freezer door close witha thud? If not it needs adjustment otherwise other problems could surface.
Mar 03, 2014 | Kenmore 72912 / 72914 / 72919 Bottom...
Kenmore smart reach
What is the model number on the model tag?
Feb 13, 2014 | Refrigerators
The top freezer door opens slightly and then reseals whenever the lower refrigerator door is closed
The lower section is connected to the top section through a common opening in the freezer floor. Shutting the bottom, being it is larger, will force air to open the top door. I installed a roller for a cabinet on top of my fridge to keep the door from pumping open. It is used to keep children out of cabinets. It is a roller wheel mounted on a spring loaded arm. It keeps the freezer shut until we open it. Some times the pumping action will force the door open enough it will not shut and things get soft. Hope this Helps Fix Ya up.
Jun 27, 2011 | GE PTC22SBMR Top Freezer Refrigerator
I just bought a new Kenmore fridge and everytime we close the fridge door the top freezer door pops open. I notice there are a couple of complaints about that. Can this be fixed?
THE UNIT HAS TO HAVE A GOOD TILT TO THE BACK,, THIS HELPS THE AIR BEING PUSHED THROUGH THE FREEZER WHEN THE DOOR IS CLOSED, AND IT HELPS WHEN THE UNIT GOES INTO DEFROST, IT HELPS DRAIN THE WATER ,, ALL NEW TOP MOUNT REFRIGERATORS THAT I HAVE CAME ACROSS DOES THIS IF IT IS NOT TILTED BACK
Jan 19, 2011 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Freezer door opens each time we close refrigerator door
This is an easy one to fix - at the bottom of your unit you have 2 adjustable wheels you can turn to raise or lower the unit. What you need to do is turn those clockwise which will raise the front - what you want is to have it slightly tilted to the back. As a test you can open your door 45 degrees and leave it - it should be able to close on its own.
Sep 25, 2009 | Kenmore Refrigerators
Freezer door not sealing
replace the seals and / or have the hinge adjusted
May 01, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Moisture
Are the air vents blocked in the refrigerator? Remove any
objects from in front of the air vents. See "Ensuring Proper Air
Circulation" for the location of air vents.
Are the door(s) opened often? To avoid humidity buildup,
try to get everything you need out of the refrigerator at once,
keep food organized so it is easy to find, and close the door
as soon as the food is removed. When the door is opened,
humidity from the room air enters the refrigerator. The more
often the door is opened, the faster humidity builds up,
especially when the room itself is very humid.
Feb 19, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore - over under
Adjust the feet to raise the front of the frige, which should be higher than the back. Therefore the weight of the door will keep it shut or at least cause it to shut itself if it pops open.
Jul 08, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
138 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
