Question about IVINA BulletScan S400 Sheetfed Scanner
PAPER JAM - KEEP GETTING THIS ERROR, EVEN WHEN ONE SHEET GOES THROUGH CLEANLY
Even when Scanning just one sheet, I get a paper jam error. It won't let me save the scan, and I have to open the scanner door and close to clear error.
Why does my hp laserjet 1020 keep printing 4 blanks after each printed sheet? HELP!
My solution already posted in FIXYA.. for the same complaint earlier.pl go through..
http://www.fixya.com/support/t10478324-printer_taking_two
You need to clean the paper pick up solenoid located at down right side ...gently remove & clean it as shown..best of luck..
Aug 20, 2014 | HP LaserJet 1020 Printer
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
I keep getting a paper jam error
Hi M,
It usually means there is a "PAPER JAM" Check in paper feed that there is not a small torn piece of paper still in the printer. The sensor will still recognize this as a PAPER JAM even though there does not appear to be a sheet of paper in the printer. Good Luck.
Jack :}
Nov 17, 2012 | Office Equipment & Supplies
A sheet of paper keeps getting jammed - we remove it and try again but it keeps jamming. We have cleaned the rollers inside where the cartridge goes and it did not help
If the first sheet of paper is correctly feeded and it shows up after fusing unit and that happends every time, then probably you have damaged exit paper sensor. It have to be replaced with new one.
If the paper feeds only few santimetres then you have to replace paper feed roller
pifonski
Feb 23, 2011 | Samsung Office Equipment & Supplies
Error code 3528 keeps coming up,telling me to remove back cover and remove paper jam then replace back cover.there is no paper jam,checked printer heads no paper anywhere?
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Sep 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error 3, paper jam
use an antistatic vaccum or canned compressed air to clean the interior of the printer.this problem may cause by dust and debris inside the printer.inspect for any broken part in the paper path.if u find any u will have to investigate repairing or replacing the printer.
try using different weight paper .some printers work best with the particular weight of paper and if you use paper too thick or too thin jams can usually occur.thanks
Apr 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Dr 5010c feeds one to five sheets, then stops
Clean the rubber rollers (pickup and ******) with a damp cloth, loosen the papers to be scanned. Clean all the rollers in the scanning path. What is the eror that is displayed? Download the user manual from this site http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2341&modelid=11293 (5010um.pdf). Change the rollers if they are old.
S. Mohan, Chennai, India
Apr 16, 2009 | Canon DR-5010C Scanner
It keeps saying paper jam then please wait keeps blinking
Did you check in the back where the multiplexer goes? The paper turns around the drive rollers back here and can jam up. If you didn't notice a full sheet missing, you probably just need to pull the rear cover off and clean it out a little bit. Totally unplug the printer too, it should clear any error codes that just turning it off won't.
Jan 04, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson R300
Make sure the photo paper is not curling when it goes in. I had same problem before, with paper jam error even though the photo paper did not appear jammed. I noticed the photo paper was slightly curled, so I flattened it out and that solved my problem. Also, if you are loading multiple sheets at one time, try just loading one sheet and see if that fixes it.
May 11, 2008 | Epson Stylus Photo R300 InkJet Printer
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
IVINA BulletScan S400 Sheetfed Scanner Logo
73 people viewed this question
Top IVINA Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an IVINA Office Equipment and Supply Expert? Answer questions, earn points and help others
