Question about Craftsman 25cc Gas Line Trimmer
CRAFTSMAN 2-CYCLE TRIMMER MODEL NO. 316.711190 WILL START BUT WILL NOT RUN UNLESS CHOLE IS ON.
WILL START BUT NOT RUN UNLESS CHOKE IS ON.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
OK, lets slow down a bit. First look at the primer bulb of the carb. Depending on the type, there should be 2 or 4 screws right by the primer bubble. Carefully, remove the screws. The top section with the bubble and one fuel line will come off. In between them is a gasket and diaphragm. Look at the lower half and you will see a very small screen. Get some carb cleaner and spray by the screen but not too close. This is where most of the dirt collects. You might need to remove dirt by hand. Then close the carb. back up. Place gas in the tank, but leave the cap off, so you can look inside while you press the bubble slowly. You should be able to watch gas flowing back into the tank at a steady stream. Then place cap on and follow the start up instructions. Get back to me when you can.
Posted on May 16, 2014
SOURCE: replacing fuel line
Have you removed the carb. and tried to clean it? If not, get the numbers off the carb. and pick up a repair kit for it. Dismantle it, clean all orifices, remove the low and high speed needles (may only have one and count number of turns each one is at by screwing in until lightly seated then remove ) and clean passages with carb. cleaner. Reassemble, install, adjust initially with original settings and start. Adjust from here. Little carbs. are very "touchy" when adjusting.
Posted on Mar 13, 2009
steve_lima
  • 181 Answers
SOURCE: repair a weed trimmer, How to remove the starter clutch
down in the center of the clutch there is a screw that holds everything to gether.usualy it's a torx head screw.some are reverse thread so be careful.hope this helps,let me know
Posted on May 13, 2009
#1 Taper
  • 1040 Answers
SOURCE: The weedwacker dies when I squeeze the throttle trigger
You need to clean the carburetor. Remove and disassemble carb. Use a den Tek Brush, (used to clean between teeth), to clean the small portals in carb. Use a carb. cleaner while cleaning. Make sure the small screen in carb. is free of debris. The smallest of paticles can cause the carb. not to run right. Reassemble the carb. and try starting. If there is no change, then you will need to buy a carb. kit for your trimmer. Replace all appropriateparts: gaskets, diaphragm, needle valve, and the small screen.
Jim
Posted on May 31, 2009
#1 Taper
  • 1040 Answers
SOURCE: Trimmer wont run when i take it off choke
No, it will not. Don't take the fuel mix screws out, it's not necessary.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Posted on Jun 15, 2009
  • 168 Answers
SOURCE: Craftsman 32cc Trimmer Runs with choke at idle, then stalls
Sounds like somewhere you have a air leak. Most likely it's somewhere near the carburetor intake or maybe the carb itself. Could be a line from the primer if it has one and i do believe it should that could be leaking or loose. Good luck.
Posted on Aug 02, 2009
What will cause newish sears 27cc string trimmer only run on full choke?
If the trimmer has been sitting for a long time it is probably the carb needs to be rebuilt. Before doing that check the plug and be sure you are getting fire. Be sure nothing is blocking the fuel filter in the tank. Be sure exhaust or muffler is not plugged, with only 5 hours on the trimmer I wouldn't think that is the problem. Sound more like something in the carb. You can look on you tube to see how to rebuild the carb if you have not done it in the pass it is fairly simple to do.
May 31, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
I have a craftsman 4 cycle engine model 143.814032. I can start the engine and it will run for about 30 seconds and stop. I have check air filter, choke,new gas new plugs . I have taped on the bottom...
Clean your carb for starters. Sounds like you have a fouled carb inside. If this is a trimmer you might need to just buy a carb rebuild kit and start fresh. Good Luck...
Aug 31, 2011 | Craftsman Garden
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
I bought the machine about 3 weeks ,use it 2 times and know it would not start. craftman 2 cycle
Spark plug gap or fuel mix either or and when you try to start ,start it with trigger fully engaged and alternate between full choke and half chke and no choke till you get a response.
Jan 12, 2011 | Craftsman 25cc Gas Line Trimmer
Weedeater is usable and ready, don't know how to start it
I hope you have fresh gas and 2-cycle oil mixed up! They always seem to start strong and explosively cut on good, fresh fuel. :D
1:Choke on.
2:Push the primer bulb (rubber ball by the side of the air filter) 3 times.
3:Place trimmer on ground. Grasp the handle, squeezing the throttle fully in left hand. Kneel and give that starter a crisp, sharp tug with your right hand. If the engine "hits", then push in the choke until off. Goto step 4.
If it does not give a hint of life, repeat the tug on the line 2 more times. If it STILL does not start, check for a distinct odor of gasoline. Likely, at this point, it is flooded, proceed to step 5.
4: With choke now off, continue to depress the throttle fully and give it another sharp pull on the starter. If it starts and revs? Let it idle for a minute to warm up, then go to work!
5:With choke OFF, press and hold throttle at full. It may take several pulls on the starter rope to see any life. If after 10 pulls and there is still no life, and still smells of gasoline - time to see the Ex about getting the trimmer looked after for some TLC. :D
May 08, 2010 | Craftsman 25cc Gas Line Trimmer
Weedeater will not run with choke off
Check your carburettor mounting screws,they might be loose and it would mean the engine is
getting to much air and it would leak gas. Stephen
Sep 06, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
529 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
