Question about Casio Privia Keyboard Case
My privileg freezer is showed me red light and no ice it doesn't make pls what is the problem
Red light and no ice
On my fender blues deluxe, there is a red light which is usually off. I get intermittent loss of sound, and when this happens, the red light comes on. Any ideas what's wrong? Many thanks Brian
Hi.
If the red light is coming from a tube and you notice a loss of sound when it lights up, try reseating the tubes. You have to make sure that the amplifier is cool and is not plugged in to any power source when you do this and you have to be very very careful with the glass tube as well.
If the red light comes from an LED, it may be an indication of a bad wiring. Check if all wires are in good condition and are soldered correctly.
I hope this helps. Thanks. :-)
Apr 28, 2011 | Fender Hot Rod Deluxe Guitar Combo...
The red and green control channels are linked. When I bring up just the red channel on the light board, both red and green channels move together. Same thing happens when I move just the green channel. ...
It appears from the manual that 00 is 100% full intensity just as you are observing... I can understand how you would be confused by the way it is written in the manual...
It also looks like you have to set chan 1 to be between 0 to 29 to select the RGB mode...and ALSO those color intensity values are "upside down", that is, 00 is full on for each color. and 255 is off.
These manuals can really be confusing.
Mar 08, 2011 | Chauvet Led Colorsplash 200b Dmx Wash...
I just bought a Deluxe VM .... when I plug it in, the red delay light is on....and everything has delay on it. When I press the little white button on the amp in or out, the red light on the amp still...
i guess the switch is broken - if you are not experienced fixing those problems better bring it to a shop and tell them about the problem - i guess they will be able to fix it easily
Feb 25, 2011 | Fender Deluxe VM Tube Amplifier
When i play a bit loud (not too much though just when the light blinks red on the hard play) the sirquit closes the amp for two seconds.can you healp me on this ?thank you very much
does your bass have active pick ups?
do the ratings on your amp match the ratings on your speaker?
are you using a pedal?
does your pedal have an output adjustment?
have the ground on your bass checked.
make sure you're using the right kind of cable.
and be sure that the outlet you're using is grounded.
Feb 08, 2011 | Ibanez P500H Promethean Bass Amplifier...
All the channels shows the Clip red light on the Peavey PV6 6 channel mixer and I´m unable to use the device ...Whats is the solution??
It is likely there is a failure of one of the power supply voltages. The solution requires troubleshooting that is NOT DIY unless you are electronically skilled.
Oct 26, 2010 | Peavey 32fx USB 32 Channel Mixer
Power indicator light is red and the system does
It is an indication of a bad speaker cable providing a short. If it stays lit with no speaker cables plugged in it is an indication that it needs to be serviced.
Oct 17, 2009 | Fender Passport Deluxe 500watt Sound...
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
Casio Privia Keyboard Case Logo
29 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
