Question about Rowenta DG5030 Iron
On off switch is not working on my rowenta DG5030
The switch wont turn on or off
4 Suggested Answers
SOURCE: Need a cap gasket for a Rowenta DG5030
I showed the part to my husband. He took it to our local Aubuchon Hardware and bought the same size gasket for 59 cents. I just tested it out and my iron works just fine now. The one from the hardware store is black, vs the Rowenta one which is green. Who cares what the color is, no one sees it anyway. However, if you have to send your machine for repair for something else, they may not honor your warranty as you've now added after-market parts. Just thought I mention that. Good luck.
Posted on Jan 23, 2009
heatman101
  • 43501 Answers
SOURCE: Rowenta Steam Iron DG5030; Iron drips water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Posted on Jul 14, 2010
SOURCE: my rowenta dg5030 is leaking at the cap
My question is what is Rowenta doing about the gasket problem. Where is the replacement.
Posted on Nov 08, 2010
I HAVE AN OLD BLACK AND DECKER 300 QUICK AND EASY IRON. DOES IT CONTAIN MERCURY?
I just looked up the manual. Unfortunately the best way to find out is to contact B&D.
This is from a recycling website.
Purpose of the Mercury: The reason that mercury tilt switches were widely used in irons and other appliances was because of the conductive and liquid-like properties of mercury. In a mercury tilt switch, as the switch is "tilted" the mercury flows with the switch to complete the circuit by conducting electricity and turning the appliance on or off. In irons the mercury switch controls an electronic shut-off timer, constantly resetting the timer when the iron is in motion. If a person leaves the iron turned on and motionless, the automatic shut-off timer turns the iron off after a certain amount of time, reducing the risk of a fire. If an iron falls, this feature will also prevent it from continuing to release heat potentially causing a burn or fire.
Potential Hazards: As long as the iron remains intact, there is a low probability that there would be a mercury release.
Recycling/Disposal: There is no easy way to identify whether or not an iron contains a mercury tilt switch. However, if the iron is more than 10 years old and it contains an automatic shut-off, consumers should assume that it contains a mercury switch and dispose of it properly.
Unfortunately, they keep referring to 10 years old, but it doesn't say when this information was written up. If it was written in say 2006, then it would be referring to 20 year old irons.
Jul 28, 2016 | Irons
Switch not working hoe can i replace
Good evening Melinda!
You can look here for replacement parts
Rowenta DG5030U0 B80 Pro Master Iron Parts , (amongst others), and a closer look at the 'Housing, front complete'
Housing Front Complete shows it includes an on/off switch.
It's not a 100% match, but this video showing dis-assembly / troubleshooting another Rowenta iron will probably get you to where you need to to replace the part (and might allow you to see if it's just a disconnected/broken wire and save the $17 for the part!)
Hope this helps, and good luck!
D
Nov 19, 2015 | Rowenta DG5030 Iron
My rowenta dg5030 will heat but the water will not heat
The Boiler unit is not working have it repaired, or get a new one!
Jul 26, 2014 | Rowenta DG5030 Iron
Steam comes out the filler cap on the water base on my Rowenta DG5030
WIre brush the caps screw threads and replace the O Ring ASAP.
DOn't use the iron until you get a new O ring and they need to be the orange/red rubber ones they are able to withstand the hot steam black o rings at home depot won't last.
Jul 24, 2014 | Rowenta Pressure Iron and Steamer DG5030
Fix rowenta dg5030
Send it in for repair.
Google Rowenta Repair Center
Jul 22, 2014 | Rowenta DG5030 Iron
Why wont it work
Possible that the lead wire, the mains plug, the thermal switch of the heating element is faulty.Unless all these are checked one by one , the fault cannot be confirmed.
Jan 09, 2012 | Black & Decker Irons
My iron will not turn on....what's wrong?
Welcome to Fixya. If the iron wont turn on it can be caused by a faulty cable, a busted Fuse, transistor, capacitor, switch problem or the main board of system. If you have warranty then you can have it checked an repair for free or if you have knowledge with electronics then you can open the iron and check hte part that is bad
Thanks
Jul 29, 2011 | Rowenta Power Duo Iron
My rowenta dg5030 is leaking at the cap
Oct 14, 2010 | Rowenta DG5030 Iron
Rowenta DG5030 Iron Logo
359 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
