Question about Dryers
Leaving black marks on clothes kenmore 80 series dryer
Black marks on clothes
Master_Tech
  • 770 Answers
SOURCE: dryer
nothing in the dryer i.e.crayon left in pocket?? there is no black grease used in the unit only White lithium style.. I dont think it came from the inside of the mach ...Best bet is to clean the tub out mild soap and a damp cloth it should go away. if not the peice maybe stuck in the baffles manually spin the drum do you hear anything rattling around?? Let me know
Posted on Jan 26, 2008
SOURCE: Dryer Noise & Black Marks On Clothes
Most likely the front drum bearing part number 5303937139 needs to be replaced. Instructions come with the kit.
Posted on Jul 17, 2008
SOURCE: dryer is leaving black marks on cloths.
I have the same problem. We think it is because the barrel is out of balance and the clothes are getting stuck between the barrel and the housingand the grease is causing the black marks. But I dont know how to fix that.
Posted on Jan 02, 2010
ftw1952
  • 10319 Answers
SOURCE: I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Posted on Feb 04, 2010
  • 273 Answers
SOURCE: Dryer leaving black marks on clothes
Sounds like the drum rollers are shot and/or the drum bearing is shot. I believe this dryer also has a front bearing ring that might be bad.
If the drum is tilted because of either or both of these things, clothes can get pinched between the spinning drum and the stationary surrounding areas, resulting in streaks.
As for whether it is worth having someone fix it, prices vary greatly from one repair company to the next.
Dryers are probably the easiest appliances to repair by a do-it-yourselfer. Here is a slideshow on how to open the dryer up if you want to try to fix it yourself:
http://www.applianceaid.com/slidewpdry.html
There are many online parts stores to check prices of these parts.I have found that repairclinic.com is the best place for do it yourselfers.
http://www.repairclinic.com/Kenmore-Dryer-Parts
Posted on Apr 07, 2010
Testimonial: "Wow! Fast, informative response and great links to help. I'm thinking I need to try and repair this myself, now. Thanks much!"
Kenmore 500 series dryer is eating clothes, clunking and leaving black marks. Clothers are getting stuck in the drum in back of dryer. Any suggestions?
It sounds that the rollers a roller went bad and or the front/rear seal now has seperated, your drum now misaligned. Depending on model.
Dec 28, 2011 | Dryers
Dryer drys great. is leaving black marks on clothes
Are the black marks a result of an ink stain in the drum or is the black marks coming for the dryer seal?
If they are coming from an ink stain then alcohol or hair spray with paper towels will normally get them off the drum.
If the black marks are coming from the seal, that means that the seal is not positioned correctly and would require that the dryer be disassebled and a new seal be installed.
Jun 18, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
Depends on age..its the bearings that gone, normally a felt bearing seal the drum and wears after about 4 yrs.parts cost about.£18..plus labour..so you decide. please leave feedback
Apr 07, 2010 | Dryers
Dryer is leaving black marks on cloths.
was a pen or crayon placed in the machine by mistake ? You will need to
remove the residue, use rubbing alcohol on a rag for marker or pen ink , crayon use a razor scraper and then clenser and scrunge pad.
Oct 26, 2009 | Fisher and Paykel DE06 Electric Dryer
The dryer is squealing and leaving burn marks on the clothes
Squeak is caused by a worn out roller rolling metal to metal - Most dryers have rollers, felts and drum slides to balance drum rotation:
When rollers wear off, black powder leaks to rear felts and black marks are left on clothes.
Same thing happens when drum slides wear off (black marks are left on clothes)
Aug 15, 2009 | Frigidaire Dryers
Kenmore 80 Series Washer/Dryer
I HAVE SEEN MOST MARKS COMING FROM THE DRYERS. AS THEY AGE, THE FELT AIR SEALS ON THE DRUM DETERIORATE AND THE CLOTHES GET PINCHED BETWEEN THE DRUM AND THE BULKHEAD AT THE REAR OF THE DRUM. OTHERWISE CHECK THE HOLES IN THE WASHER TUB IF YOU HAVE A PORCALIN ON STEEL TUB IN THE WASHER.
Jan 26, 2009 | Washing Machines
Kenmore Dryer - Series 80 - Model 96586200
the brown streaks are from the seals most likely from the front seal ... if your handy it will be an easy fix..
Oct 12, 2008 | Dryers
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
May 31, 2008 | Frigidaire FDE336RE Dryer
Dryers Logo
18 people viewed this question
Top Dryers Experts
