Question about DCS 36-6-1 Gas Kitchen Range
Replacement jets for an old DCS36-6-1n
I wish to convert it to LP gas
How do you convert from gas to propane ?
You need to change the jets , different gasses have a different size hole in the jet.
The manufacture supplies other jets, if the appliance is designed for both gasses.
LP (propane) jets have a smaller hole than Natural (Methane) Gas.
The pressure of LP gas is higher, to be able to suck in more oxygen.
Jun 23, 2014 | Amana Ovens
Parts gl38lkec
call me. converting a barbecue is simple; the kind of job a tech will get while still in training. The LP hole is smaller than the NG becuse of mass and air-mixture in NG so the orifices have to be plugged and re-drilled or replaced with new LP orifices.
Nov 07, 2013 | Sunbeam Grill Series 550
Rangemaster 110 on lpg wish to convert to natural gas
You must get a tradesman or technician who is qualified to convert a gas appliance, your local gas fitter or plumber should be able to help with this. the regulator needs to be changed the jets also need to be swapped out for the type of gas to be used. normally from lpg to Natural gas the jet size needs to be increased by installing new jets or by drilling out the old ones
Hope that helped
Oct 22, 2013 | Rangemaster 110 (Gas) Kitchen Range
Convert new Weber gas grill from natural gas to LPG. Can it be done safely by a gas pro? Who can provide needed parts, i.e. gas injectors?
Click on the Weber link below for customer support and the nearest location that can service your grill. http://support.weber.com/
Oct 15, 2013 | Weber Grilling
Can a weber spirit e210 natural gas grill be converted to LP gas? I won the grill but don't have natural gas at my home
Weber sells conversion kits. Basically, you need a new regulator and manifold to accommodate LP instead of the existing regulator/manifold setup for natural gas. Unfortunately, Weber does not sell their parts online. Their parts phone # is: 877-731-8081
Apr 27, 2011 | Weber SPIRIT E-210 (NG)
Where can i buy the fitting (converting kit)for weber e 310 ng to lg
Sorry, but there are no conversion kits available for Weber Grills. They were no designed, tested or approved to be converted from one gas type to another.
For confirmation of the this, see FAQ link to Weber, below.
http://help.weber.com/faqs.aspx
Apr 17, 2011 | Weber Spirit? E-310 Propane Grill
I have bought a natural gas hotplate. The problem is that in the hills we have not got natural gas this is why I have to convert this hotplate to lpg gas. Please tell me how it should be done.
at the end of the pipe that loosely goes into the burner assembly, there is a nut or metal part that has a small hole that the gas goes through ... that is the "gas jet" .. they have different size holes for natural and lp gas .. the manufacturer should have both .. usually it just unscrews and the new one screws in its place .. there would be one for each burner .. if there is only one burner then you need just one replacement jet with a hole size suitable for Lp gas .. you might be able to get the new jet from a local hardware store if you take the old one with you so they can get the size and style right ..
Oct 09, 2010 | Heating & Cooling
Want to convert from LP to Natural Gas
Typically, the only thing required is changing any and all jets since energy content and pressure are different. The only source for these is probably the manufacturer; check their website.
May 20, 2009 | Grilling
Accessing burner and installing LP conversion on Maytag Bravo
you need to obtain a jet (orifice) of the correct size for the gas you wish to use. remove the burner and, replace the existing jet; that is all there is to it.
May 19, 2009 | Maytag Dryers
Jenn Air 740-0141 LP to NG Conversion
If the grill can be converted, it's usually a matter of providing a source for the natural gas and then changing the gas jets for the burner(s) and possibly a regulator, depending on your model. Some grills may require changing the gas burner valves themselves. Kits are usually available from a dealer unless the unit is old.
The natural gas jet will be slightly larger than the propane jet because natural gas doesn't have as high a heating value as propane.
If you do this, check your new conversion for any leaks using a soap solution in a spray bottle.
Just be aware that the grill may not get as hot with natural gas and cooking could take a little longer, but should still work just fine.
Your natural gas line should typically be about 1/2" unless it's huge or is over 50-60 feet away from the grill location. If so, use a 3/4" line. Piping material and methods are usually governed by your local building codes.
Mar 17, 2009 | Thermos Stainless Steel Gas Grill
DCS 36-6-1 Gas Kitchen Range Logo
62 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
Paul Carew
Sal De
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
