Question about Brother MFC 8950DW
Blurred lettters, no sharpness in printing
New machine printed sharp, crisp output, but over a short period of time, the printing became fain and blurry with no sharp edges or contrast. replacing the toner cartridge and drum did not help at all.
  • 26 Answers
SOURCE: double print or a shadow print
You have probably been using non genuine toner, some kinds of this toner is not the same quality as Brother toner and just chews you drum out before its due to be changed. Change the drum and use genuine toner.
Posted on May 20, 2007
jaylex
  • 417 Answers
SOURCE: Toner life end
There is no reset code the likely thing is that you have a faulty toner cartridge. Put another new one in and check the machine then.
Before you try the above shake the toner cartridge and tap it some more as it may also be the toner inside have become solid and needs breaking up.
Hope one of the above works for you
Thanks J
Posted on Jan 08, 2008
bowdo
  • 78 Answers
SOURCE: Brother Intellifax 2820 printing problems
If it is on copying it can be a build up of ink on the scanner glass. Open the cover in which the the original is scanned. There will be glass strip that can be cleaned also check the white plate that sits above the scan glass.
If it is recieved faxes and prints as well the problem is going to be the drum has worn out. You have two machines, try interchanging the drums to see if the lines that are present on one machine travels to the next. That way you can see if it is definately the drum. If so change the drums on the machines and they should be fixed.
Posted on Jan 31, 2008
  • 116 Answers
SOURCE: Continue to get a message to change drum soon. Changed drum already. Print quality is still not good.
your drum unit which you have replaced have still not detected by the fax machine.you have to reset the machine when you change the drum.or replace the drum and insert the new drum in the OFF mode so it will not know if any thing changed in the machine and mostly should work as normal.
please keep updated.
Posted on Oct 07, 2008
  • 105 Answers
SOURCE: Had toner life end message. Replaced toner and
To reset the sensor after installing a new toner cartridge follow these steps.
1. With unit powered On, open the front cover.
2. Press the "Options" key. Display will show "Replace Drum?"
3. Press "Start" key.
4. Press 1,0 .
5. Display will show "Accepted" for approximately 2 seconds. Then display will change to "Cover Open".
6. Close cover and see if Toner Life End error message has gone.
Please note that this must be done with a new cartridge so the unit will see that there is toner in the cartridge.
Posted on Aug 03, 2009
How do I get my Canon Pixma ip7220 printer to stop printing blurred lines?
Hello, my name is Steve.
This is an early sign of print head failure.
Soon it will give you an error code on display or ill be observed on your computer. The print head nozzles are not firing correctly. The only way to remedy this is to:
1. Have the printer serviced and cleaned ( the cost of the new print head and a cleaning and servicing of the printer
2. Order the print head online and install it yourself. The wonders of the internet can find an give you a video of how to do this.
The part number is: Canon QY6-0082-000 Printhead (Canon QY60082000 Printhead) I hope this helps, Steve
Jul 29, 2015 | Canon PIXMA iP7220 Premium Wireless Inkjet...
Great pictures look flat and dull when sent as e-mail attachments
probably is the computer,get one of your photos developed from a machine and see if it comes out well,then you'll know if its the camera or the computer.
Mar 18, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
Changed the print head in my Canon MP760 but now printing is blurred and very faint
Try cleaning the felt pads where the print head would rest when not printing. They get full of ink and cause more printing problems. I use water to clean them.Don't loose them, they are needed to keep the print head from drying out.
May 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Audio fades then stops after a few minutes of power
I had this problem on a sharp flatscreen lcd. the audio output i.c. was a surface mount chip-had to change complete signal board assembly,
Mar 09, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
Will not print
It was a warm up problem. When the machine is down for an extended period, it takes about 10 minutes for it to warm up properly and the light will go off.
Dec 08, 2008 | Sharp Office Equipment & Supplies
Only top quarter of page is printed
How can a get the # recalled of a document was fax to.
Sep 02, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Errors??
Sounds like the printwheels are out of time. Sorta of major repairs. gears on side of printer have to be lined up in proper areas. there are small black arrows on the gears. Best bet is look at a working machine and try to line up. Machine may not be worth the time unless you jsut want to try it. Sharp uses the same printers in many different models.
Jun 21, 2008 | Sharp EL-1611P Calculator
Blurred printing
Check the toner motor! it maybe broken or not working.
May 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Brother MFC 8950DW Logo
37 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
