My wireless printer connection does not respond
My Dell w/Vista laptop wireless connection is set up but will not print from one room to another.Wireless Light on printer is on but the que just sits & does nothing. What do I need to do to be able to have the printer respond from my laptop when in another room?
  • 253 Answers
You need to enter in the correct network settings into the printer for it to work wirelessly, such as WEP/WPA key, IP, etc...
Posted on Jun 15, 2009
Describe your 946 All-In-One InkJet Printer Problem I'm running windows 7 on a Gateway laptop and managed to get it to print at one point but then installed some other items to get it to recognize...
This printer is not a wireless rpinter, so I guess you were trying to attach it to a print server of some type.
Try using these Recommended Wireless Router Settings,I use channel 11. I would make a new SSID to make connecting easier.
If your computer came with Windows 7, then follow the procedure below. If you upgraded your computer, the did you install the chipset drivers first. If using a Dell Computer that was upgraded, the desktop/notebook system utility and the chipset drivers need installed first or the rest of the drivers will fail to install. How to Download and Install Drivers in the Correct Order
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 946 Photo All-In-One Printer owners thread (W7)
Virus programs and firewalls will block communications.
If you need more help, please post in the Dell Printers Forum
Rick
Aug 24, 2011 | Dell 946 All-In-One InkJet Printer
Wireless printer
the printer needs to be connected to your wireless network.
the easiest way to do this is by running the install cd temporarily connected the usb cable and transfer the network settings
Mar 27, 2010 | HP Office Equipment & Supplies
I have a Dell desktop running Vista 64 Home Premium with a Lexmark P6250 all in one hooked to it via usb cable and shared on my home network. I also have one dell laptop and one HP laptop connected to the...
The printer drivers must be installed on each computer. If computer A runs XP, you must install driver for XP on computert A; If machine B runs Vista, then you must install printer drivers for Vista on machine B.
Hope it helps.
Sep 11, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Windows Mail (Vista) quit printing body of E-mail to my printers.
Check the email print settings. If settings are ok, do a repair for your software using the control panel->add/remove programs.
Thanks
Jun 24, 2009 | Microsoft Windows Vista Home Premium with...
I can't connect wirelessly with my printer since I got Uverse
i work for att tech. support .. but for DSL
yeah we dont configure printers....
but what you can do is go to the modem interphse
URL....only type in 192.168.1.254 ENTER
and go to FIREWALL then SETTINGS
select DMZ modem or allow all applications
give that a shoot might help.
then see under HOME NETWORK if you see the printer
Jun 21, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Dell 3300 Printer Adapter and Vista
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device.  Assume the printer is connected locally to the machine.
Feb 01, 2009 | Dell Inspiron E1705 Notebook
2WIRE wireless router/DSL from AT&T
unless this is a wireless enabled or lan RJ45 connectable printer you cannot, the pc that the printer is connected to must be on at the time of the printing.
Wireless printers have their own arial and allocated ip address, Lan RJ45 connective printers can be connected to the router.
Sep 15, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Setting up a wireless printer
Hi Rob,
The situation seems very vague, First off, you have to identify if you're using this for a corporate environtment usage or are you using this on a home network? Next question would be,if the network you're connecting the dell wireless adaptor to has reserved the ip address for the allocation of the printer. If not, then there are a few possible reasons for your situation:
  • IP Mismatch. If you're connecting the dell wireless adaptor directly to your printer and network, ensure that the IP ADDRESS of the printer is matching that of the ipaddress of the printer driver in your computer (Control panel>Printers>Right click printer>properties)
  • Driver Error. Download the latest driver for your model printer and install it on your notebook. Once this is done, make sure you are able to "see" the printer by printing a test page.
  • Not conencted to the netwrok. Sometimes, this happens when you're not connected to the netwrok (but you think you are just casue you see a "connected" icon). Make sure you're conencitng to YOUR network everytime you reboot and not mooch on some other netwrok.
Hope this helped. Please do let me know how it goes. Thank you.
- Technomancer
Jun 03, 2008 | Dell Inspiron E1705 Notebook
No connection at all
hmmm...ok..need computer and printer make, please, and operating system would also be of some value here..
Feb 21, 2008 | Office Equipment & Supplies
272 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
