Question about Sharp AR-M317 Black and White Copier
Toner on paper
Black Toner Dust All Over copies
    Scholar:
  • Sharp Expert
  • 120 Answers
If it's really gritty, that's not toner, that's developer (iron oxide). It may be time for the routine maintenance kits.
Posted on Apr 07, 2014
Bubbabear64
  • 2794 Answers
SOURCE: black lines running vertically through resulting copies
Clean the scanner glass. a small particle will cause this to happen.
Posted on Jun 06, 2008
Cogz
  • 1326 Answers
SOURCE: black lines across copies
Question dose it only show up when using the adf/ doc. feeder? Also, dose it show up on both the copy board glass and adf? If it is just the adf, you need to clean the adf slip glass. The small piece of glass next to the copy board glass. If that is not the fix, it could be the Drum Unit or the Fixing unit..
Posted on Aug 20, 2008
checkitright
  • 1362 Answers
SOURCE: Copies have black lines on them after i replaced the toner
does the lines come when doing copies in the doc feeder only? or on the glass also?
if only in the doc feeder lift up doc feeder and clean the small strip of glass
Posted on Oct 30, 2008
  • 255 Answers
SOURCE: after changing toner on my sharp, SF-2022 copy
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Posted on Nov 20, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: toner on the side of paper when copying
If you are using refilled toner cartridges then your toner cartridge may be leaking or the waste toner tank on the toner cartridge may be leaking. The other cause and more likely is the drum cartridge is leaking toner. I would recommend removing both cartridges. Then hold each 1 at a time over several sheets of clean white paper. Tap on the cartridges and see if any toner falls out of them. These cartridges are normally sealed and should not leak much if any toner. If toner falls out of either cartridge you will need to replace that cartridge.
Good Luck and Thank You for using Fixya.
Posted on Mar 27, 2010
Black smudges from one tray only
Dust, dirt, toner, in paper path, clean. This paper hits portions of the printer diff. than 20lb and grabs toner where thinner paper does not. -Carl
Apr 17, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
Black streaks on paper
its either your heater is full of toner or your copy glass is full of dust either way you just need to clean it from the inside
Apr 27, 2012 | Konica Minolta PagePro 1350W Laser Printer
I JUST BOUGHT A SHARP AR-5127 COPIER..WHEN IT COPIES, IT BRINGS OUT BLANK PAPER. I REMOVED THE CATRIDGE AND IF I TURN IT UPSIDE DOWN,SOME BLACK DUST COMES OUT...PLEASE SOMEONE HELP ME
Hi iheanyippaul,
I see you concern, I believe you will need to check your toner if it is placed properly inside the machine seems that it is not locked/latched in its place to be able to print properly reason why you get a blank paper and black dust when printing.
Remove the Toner and re insert it again making sure the toner is set properly inside and also make sure the correct toner cartridge is installed, an incorrect or incompatible toner can cause issue of not getting to print anything on the paper or possibly not fit inside the machine correctly.
I hope this helps.
Have a nice day,
mvincentc
Jul 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Just copy file..always jam..messagge"papper jam
Causes for paper jams in Printers are given below:
* Dust or debris
* Rotating drum problem
* Toner or fuser complaint
Dust or debris
One of the main causes for paper jams is the presence of dirt, dust, or debris in your toner cartridge. The paper coming into the cartridge would get stuck. So clean your printer regularly. Remove the dust from the printer. Also find out whether any jams occurred in the sensor hole in the upper part of the rotating drum. Do not touch the roller while cleaning. If the oil in your body gets into the roller, the printing media cannot roll over it properly and you can't get rid of the printer problem.
If there is no direct symptom of paper jam and still you cannot do printing properly, find whether it is because of drum problem. If the paper gets into the end gear of the rotating drum and gets stuck there, you cannot access the printing function. Switch off your printer and check the plastic arms of the printer drum. If there is any paper piece jammed in any of the arms, you can't continue printing. Here also cleaning is the best method to solve the problem. While cleaning, check the arms of the rotating drum.
Toner complaint may also cause paper jams. It can be solved only by replacing it. When you switch on the loop back plug in, two flash lights appear; then it indicates paper jam. The oil spillage in toner can cause this problem. If the toner cartridge is not functioning properly, the same problem would be the result. The diodes or transistors in the fuser unit of the printer may get damaged and this can lead to fuser complaints. To solve this problem, you should replace it.
Feb 22, 2011 | Office Equipment & Supplies
How to open H.P laserjet 1020 for cleaning the powder dust in printer
The only part of the printer that you ned to get at is under the toner cartridge. Open door, remove toner cartridge and vacuum dust. If you are referring to black toner dust on the fuser roller ( where paper comes out of printer ) that is alot harder job.
Feb 19, 2011 | HP LaserJet 1020 Printer
My NP6012 stops and paperjam light comes on. Paper not being fed.
Pick up wheels can be full of dust due the time storage.Keep on trying to make copies,the paper will clean the rollers every time it try to feed.
Jan 28, 2009 | Office Equipment & Supplies
OKI Laser Printer C5300 printing on paper with black flecks
IF you are using after market black toner then we found your problem. Putting a real toner on now wont help cause dodgy toner is now in the drum, you need to replace Black drum and use real toner. If you are using gen OKI toner, then just replace the Black (K) drum.
Clean led head and these printers dont need a teco, they are designed for wearing parts to replaced by operator ie Transfer belt, fuser, drums and toners.
Nov 20, 2008 | OKI C5100n Laser Printer
Black Copies
is there toner in the machine ? ( toner spill)
check the manual for the location of the glass, in the maintenance section, if it has toner on it copies will be black or dark, other wise the scaning glass is bad
http://www.retrevo.com/s/canon+7000+manual
Dec 31, 2007 | Canon LaserClass 7000 Plain Paper Fax
Sharp AR-M317 Black and White Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
