Question about Samsung R610-64G Laptop
The space bar is unattached on one side.. - Samsung R610-64G Laptop
    Sergeant:
  • 268 Answers
You will have to getto rig something to fix it or replace your entire keyboard
Thanks, Frank
@Tech
http://www.attechcomputers.co.cc
3868607368
Posted on Jun 19, 2009
When I hit the spacebar it jumps 2 spaces
Look closely at the space bar. try to lift it on the right side and on the left. The bar may have popped out of place. Specifically a metal rod that holds the space bar in place. Or the space bar is not resetting fast enough, ( soda, honey, something sticky) causing the bar to reset slowly.
Nov 01, 2013 | Lexmark Wheelwriter 10 Series II...
I have an Acer Netbook and the space bar will not work unless you hit it very hard.
Turn it upside down and tap it.There may be some thing caught under the space bar.If not then gently pry the space bar off and clean it.It may be sticky.
May 12, 2011 | Computers & Internet
My dog knocked over my Compaq keyboard. Now the divided spacebar is opposite what it should be. Instead of spacing on the right spacebar I have to hit the left side. How do I fix this?
Pull the space bar off by using your fingers. Underneath, you'll find a metal rod. Take note on which way it is facing, and how it fits. Make sure nothing in broken under the space bar, then put the space bar back on making sure it hooks in correctly.
Mar 08, 2011 | Compaq Keyboard
My spacebar key is no longer working properly. I have an acer aspire laptop 5735Z . I deliberately pulled the key off to clean underneath and then just clicked it back on, thinking it would work normally....
There is usually a metal piece under the space bar, if it isn't seated properly the space bar will teeter. Try to remove again and see if they metal bracket is seated correctly.
Oct 18, 2017 | Acer NSK8458AN Keyboard
Craftsman 19.5 42 lawntractor, steering started clicking, then would nto turn wheel. Bar underneath unattached hitting ground. Do not know where it goes. How can I fix.
not a expert just trying to help,,sounds like you have two or mor problems,, first the bar will only go to one side of the front wheels,if it does not snap into place,you will have to replace the joint.,, the clicking sound maybe the steering unit sliping,,look down from steering wheel follow the shaft down to the steering gears,, they might be worn out.. hope this help you
Feb 15, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Space bar does not work
Hello, Thomas.
I'd suggest flipping your notebook on its side and then over, lift/pull the space bar slightly with a flat screwdriver or other thin, flat object. First shake, then spray compressed air in the area.
Hopefully, something is lodged (like a paper clip or other small object) and will be removed.
If not, the space bar cannot be replaced, unlike other keys. So, you would need to replace your keyboard.
Hope this helps.
Hope this helps.
Dec 22, 2009 | KDS Valiant 6480iPTD Notebook
Space bar, left-side enter key and backspace do not respond.
Try buying a can of compressed air and cleaning around those areas if you have spilled liquid on them ,that could be the prob as well
Jul 21, 2009 | Logitech S 510 (967555) (DH967555)...
Left side space bar does not work
The space bar on any PC is a single button you may need to make sure your keyboard is clear of any debris If that doesn't fix issue you will probably need to replace keyboard which is very easy to do. techsupport@grindstaffscomputerservices.com
Mar 18, 2009 | Acer Aspire 5735 Notebook
Left side of space bar on Dell XPS M1330 difficult to use
I had the exact same problem and contacted Dell support. They sent a tech to swap out just the keyboard. I have a feeling these keyboards are not of the highest quality as I do have some issues with the Ctrl key now. But it's much less annoying than the broken spacebar.
Feb 28, 2009 | Dell XPS M1330 Notebook
Headrest pice (attached to the top of the back rest of stroller) has become unattached
We just fixed this issue tonight! We had to realign the bar (the silver bar you described) into the correct slots. One curve sits in the headrest piece, and the other curve slides into the seat back. If you hold the headrest in position, you should be able to see the slot at the same location as where the curve hits the seat back. Slide that curve into the slot from the side of the seat back.
Then align the 4 or 5 headrest tabs BEHIND the seat back, and the bar should position itself across all the "hinges". It takes a little force (or a flat head screwdriver) to push that bar back into the the "hinges", but once in it should work just fine.
g'luck!
Mar 03, 2008 | Graco Quattro Tour Travel System
Samsung R610-64G Laptop Logo
67 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
