Question about Stanley 31164 Indoor Wireless Remote Control with Single Transmitter, White
Transmitter not working and has a new battery.
Not turning anything on.
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
Hak 735 helicopter
Usually synching requires one device started before the other, meaning that you may want to power on the transmitter, then turn on the heli and try the heli first, then the transmitter second if that doesn't work. Otherwise there's usually a small button that is pressed to get the two devices talking to each other.
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
Changed battery and it doesn't detect transmitter. Everything else works and the transmitter gets detected by our treadmill, so I know it works.?
Transmitter Battery
The estimated average battery life span of the transmitter is 2500 hours of use. If you suspect that the transmitter battery
has run out, contact your authorized Polar Service Center for a replacement transmitter. Polar recycles used transmitters;;;
Dec 28, 2013 | Polar F6 Wrist Watch
Plugged in charger and got not light on charger for transmitter. Replaced rechargable batteries with AA's turned on transmitter not lights on transmitter. Rechecked polarity on batteries and they were in...
what charger?
it needs to be designed for that particular transmitter, four cells, reverse polarity to Futaba and Hitec
http://www.rcgroups.com/forums/showthread.php?t=839823
Apr 05, 2011 | Spektrum Dx5e Dsm2 5-channel Air Radio and...
We just got a new Weather Channel wireless temperature sensor 9245. It seems that the transmitter isn't working. We followed the directions and put new batteries in the transmitter first, then the...
The new batteries could be defective or installed incorrectly. Remove all batteries and start over again. Be sure to let the transmitter initialize and begin sending data before you install the batteries in the receiver. If you can't receive a signal, the transmitter may have failed.
I have an Oregon Scientific receiver that is within line of sight of the transmitter and receives nothing......
May 17, 2017 | La Crosse Technology WS9245UBKITCBP...
The remote start works (starts the vehicle) only when the fob is very near (inside) the controller.
First check the battery voltage. A good new battery will be about 3 volts. If it is significantly less, get a new battery and retry. Examine the battery contacts since you have the remote apart to ensure that they are clean and shiny. If they are dull, use a pencil eraser to clean the contacts. If you are still getting poor range you can try to reprogram the remotes to the OEM keyless entry system. The procedure follows.
Transmitter Code Programming
Note: The receiver (ETACS module) can save maximum two codes from the transmitter.
1. Apply the battery voltage to the terminal "6" of DLC (Data Link Connector),{see attached image}. The DLC is located on the left side rear of the engine compartment. The wire color for terminal #6 is red/black.
2. Turn the ignition switch to "ON" position.
3. While coding one transmitter.
Press the lock button of transmitter for 3 seconds over until the turn signal lamp turns off.
4. While coding two transmitters.
Press the lock button of one for 1 second while the turn signal lamp turns on, and then press the lock button of the other for 1 second over until the turn signal lamp turns off.
5. Remove the battery voltage, and then the transmitter code is re-saved on the receiver.
6. Check the operation of the keyless entry system.
If you still experience poor range, you may need the system serviced or the remote replaced.
Nov 09, 2010 | AutoCommand Remote Car Starter Add-On
Having issues getting the garage door opener to work after expecting the code
Are you having problems while using the remote transmitter, but not the local control? Try changing the battery in the remote unit. If the battery is new, the transmitter may be drifting it's output frequency somewhat causing poor execution. Do you have two transmitters and one works better than the other? Either have the poor transmitter checked by the dealer or buy a new transmitter--whichever is cheaper. Hope this helps!
Apr 05, 2010 | 2004 Jeep Grand Cherokee
Keyless entry remote quit working. Just purchased new battery. Now Spare remote does not work either.
Transmitter Programming Notes Transmitter Programming
  1. Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
  2. Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds . The locks will again cycle once.
  3. Repeat step #2 for each additional keyless entry transmitter.
  4. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Jun 17, 2009 | 2000 GMC Sierra
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Stanley 31164 Indoor Wireless Remote Control with Single Transmitter, White Logo
106 people viewed this question
Top Stanley Home Security Experts
Lawrence Oravetz
Are you a Stanley Home Security Expert? Answer questions, earn points and help others
