Question about Canon imageRUNNER 7200 Copier
Imagerunner 7200 remove hard drive
Remove hard drive
3 Suggested Answers
  • 149 Answers
SOURCE: Where is the hard drive located on imagerunner
you have to remove the back of the copier and you will see a large metal box with a few screws in it. might even have a clamping device to hold the cover closed it should be in there. if it is not in there then it is on the back side of that metal box.. just be carefull if you have to remove it.
Posted on Jun 09, 2010
  • 149 Answers
SOURCE: Describe how to remove hard drive from canon
what you will have to do is remove the back cover.
then you will need to remove the thin metal cover laying flat cover on the back half of the copier just under the doc feeder. should be 3 screws.
then there is a metal box that holds the main controller on the right. if you open that you will see the IDE cable which will run up and out of that box and will run up under a thin metal plate that should be held in by 2 screws. if you remove those screws you should be able to see the hd .
if you can't get it out and or find it please call me it might be easier to explain. over the phone.
C & S Canon Copier Repair
(858)414-8475
Posted on Jun 17, 2010
Testimonial: "I was able to find the HD and now I am going to replace it. Thank you very much for the answer it was very helpfull. I even call the tech and he helped me out over the phone. FixYa I think you are doing a great service!!!!!"
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
HD detection error: the HD cannot be detected; the machine fails to turn ready;
If there is an error with the hard drive, you should have an E0602-000x error code. the only thing that you could try other than replacing the drive, is holding down "1" and "9" while turning on the power, and this will put the machine into a scandisk mode. this can take anywhere from 20 min. up to a couple hours to complete. will say "download mode" on the screen when it is finished. if this does not work , the hard drive will have to be replaced.
Apr 13, 2011 | Canon imageRUNNER 7200 Copier
IR 7200 HEATER SECTION SOUND, & NEARLY HEATER
You need to remove fixing unit and look for broken gears, bushings or security pins on fixing upper roller.
Aug 01, 2010 | Canon imageRUNNER 7200 Copier
Where is the hard drive located on imagerunner 7200 copier? Would like to remove it before disposal.
May 25, 2010 | Canon imageRUNNER 7200 Copier
Canon Imagerunner 7200 At the bottom of the screen it says "Finisher Can Not Be Used" Also says "Ready to Copy (Function Limited)"
touch the add func key then common settings scroll till you see limited functions mode touch it then turn limited function to off then turn copier off then on
Nov 18, 2009 | Canon imageRUNNER 7200 Copier
Imagerunner 7200 Error E0000532-0001-need help!
hello you have to check the stapler unit and exactly the door loock from bottom under the stapler unit
Nov 10, 2008 | Canon imageRUNNER 7200 Copier
Canon imageRUNNER 7200 Copier Logo
75 people viewed this question
old marine
old marine
