Question about GOURMET LIVING Shopko 12 Cup Programmable Coffeemaker NO COLOR, Size 12 CUP
Runs very slow
Coffee comes out very slow
Gaggia titanium coffee slow coming out of machine
Not sure it will work for you but Our Bunn has a flex wire to run thru the tube weekly , and if we do not clean that tube it might take 20 minutes to make a pot where when cleaned it does 12 cups in 3 minute
Nov 26, 2015 | Gaggia Titanium Espresso Machine
Coffee comes out very slow from saeco magic coffee machine
At the top of the grup ther is a metal filter that close up (with dirt) and the coffee runs slow. Unscrew it and clean it up.
May 02, 2014 | Saeco Magic De Luxe Espresso Machine
Water coming thru coffee maker very slow
If the spray head is clean and clear and you have run the spring the the brew tube till you can push it almost all the way in (leaving only 1/4") then it should not have issues.
Dec 29, 2012 | Bunn NHB Coffee Maker
My Delonghi EC750 coffee maker seems to be blocked
I would try to flush the line out with compressed air and hot water or pressure wash. You can also use hot pressurized water and vinegar.
Jun 09, 2012 | DeLonghi Coffee Makers & Espresso Machines
The "descale" notification continues to come on,
Here is a tip that I wrote that goes into detail about how to descale yourKeurig Coffee Brewer
How toDescale your Keurig Coffee Brewer
heatman101
Jul 31, 2011 | Keurig Platinum B70 Coffee Maker
The machine says "ready"
That Sounds like theres a blockage, most likely limescale has built up in the boiler. If you try descale now when water is only dribbling through, it probably wont work. Recommend strip down machine and unblock pipework and try get water flow to come back stronger, then try a descale cycle.
Mar 29, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
The coffee is very slow coming out.we have decalcified the machine many many times,taken the grindchute assembly out and cleaned it,and now we are running out of options Please help
Coffee coming out too slow could be a number of problems.
I'd start with the grinder and make sure it is set to the right settings. If the coffee's too fine it will cause the coffee to come out slowly.
Next it could be a dirty brew group. The internal part of the brew group has a glass ball inside of it which is used to during the infusion process. Take the ball out and make sure that area is all clean.
Restrictions in that area can cause the coffee to come out slower.
Your next possible scenario is the pump. Vibratory pumps do go bad from time to time, and a bad pump would cause the coffee to come out slow.
If its a newer saeco machine with the J style boiler, it could be clogged due to lack of descaling.
Slow coffee can be caused by any one of these issues. Usually it is the first one.... the grinder settings.
A tip is to never go under the 3 setting under any saeco machine as the machines for some reason cannot handle anything lower all that well.
Also remember these machines are ment to produce an "espresso like" coffee, and not traditional espresso. They are not capable of producing espresso that you would otherwise be able to make in a traditional handle machine.
Hope this helps.
Mar 29, 2011 | Saeco Vienna SuperAutomatica Coffee...
Very slow, 40 minutes to make 8 cups
Run a 50:50 mixture of cold water and white vinegar through the machine several times. Allow the mixture to cool off after each run and use a filter to catch the debris that comes out of the heater/pump. Run clean water several times to remove the vinegar taste. This works great on our old Mr Coffee and lasts for some time before doing it again. Hope this helps!
Sep 26, 2010 | Cuisinart DTC-975 Coffee Maker
Brew is slow coming; i have awire instrument but
you have to remove the "nozzle" where the water comes out. It is threaded in so it is easy to remove and re-install. Then run the wire cleaning tool right up the now exposed hole. That will clean it out. Hope I was able to help.....
Oct 15, 2009 | Bunn VPR Coffee Maker
Machine kaput
Try turning on the frothing wand ... the water light should reset once the water has come through.
Mar 14, 2008 | Gaggia Super Automatic Espresso Machine...
GOURMET LIVING Shopko 12 Cup Programmable Coffeemaker NO COLOR, Size 12 CUP Logo
24 people viewed this question
Top GOURMET LIVING Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a GOURMET LIVING Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
