Question about HP Photosmart C7280 Laser Printer
My HP Photosmart C7280 does not recognise refilled cartridge.
After the original cartridge ran out I replaced it with a refilled one. When I try to print a message comes up saying that the ink level is depleted and to replace the cartridge. Is there any way round this or do I have to buy the expensive HP cartridges?
p.s. In the product section it does not give me the correct option for my printer. It is a HP Photosmart C7280 All in One.
    Guru:
  • 224 Answers
Yes that is because when you get a cartridge refilled then what may have happened is when you gave a print command some of the ink may have splattered onto the ink spraying sensors(usually happens with refilled cartridges on any printer).Its because of the heat generated with which the ink nozzles cannot handle as the ink that is sprayed from refilled cartridges is a little more than regular original ink cartridges.Dip a cotton swab in water wipe the copper contacts on the cartridge.Then wipe around the place where the cartridges sit and also wipe the carriage rod which is inside the printer (metal rod)along which ur spraying mechanism(carriage) moves. If this does not resolve your issue call in to hp at 1800-474-6836 and you can purchase original cartridges that are just for 11 dollars each.........or you can purchase a combination pack which will be cheaper
Posted on Jun 16, 2009
Printer officejet pro 8600 cartrige 951 is full but printer thinks its empty. how to reset printer
use only new cartidge. Its the best thing you can do if you want your printer work fine with no trouble.
Mar 31, 2014 | HP Officejet Pro 8500 Wireless All-In-One...
HP C7280 will not print with new black cartridge
HP C7280 REPLACED ALL CARTRIDGES - STILL WILL NOT PRINT
Sep 25, 2012 | HP Photosmart C7280 All-in-One Printer
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
Run out ink error warning message
are using a refilled cartridge?
if yes, install an actual brand new one.
are you using an official cartridge that you've had laying around for a while?
the cartridges expire so check if your cartridge has expired and replaced accordingly.
Mar 29, 2010 | HP Photosmart C7280 Laser Printer
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
I have a HP C7280. When printing the text is very light. Like it has a clog or something. Ran alignment and it says alignment failure. I run the head clean. and it still prints super light.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 04, 2010 | HP Photosmart C7280 Printer
One of the cartridges (NEW) will not work. says it is low on toner. What???? Have replaced this twice, still wont work
try use original hp spares, and must be more than one.(6 in all). change them all is printer bug.
Jan 16, 2010 | HP Photosmart C7280 Printer
With new cartridge indicates low ink level,
The ink level gauge may not work properly with refilled cartridges. Because of this, you might get low ink message after refilling. To install the refilled cartridge you might need to override the ink level gauge. Overriding the ink level gauge disables the printer’s ink level tracking feature, but allows you to use refilled cartridges. To override the ink level gauge, please check your printer reference guide. After disabling the ink level tracking feature you should check the ink level visually and as soon as the ink level gets low you need to refill the cartridge. You do not want to try to print with an empty cartridge. Trying to print with an empty cartridge may damage your print-heads.
otherwise you will have to replace the cartridge .
Oct 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
HP Photosmart C7280 Laser Printer Logo
568 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
