Question about Wilton Wedding Cake Decorating Fancy Fountain
Can't get my wilton fanci fountain to work
The pump won't draw water up
2 Suggested Answers
  • 12 Answers
SOURCE: i have a wilton wedding
Welcome to hotinshop.com, which is a nice and cheap wedding dresses, special occasion dresses supplier online...
Posted on Oct 24, 2012
Homedics Envirascape water lantern fountain
impellor stuck. not sure if you can get to it though
Jan 14, 2013 | Homedics Envirascape Rustic Illumination...
Pump will not prime.
Pump self primes after the housing is initially filled with water. Failure to do this will reslut in the unit not drawing up the water and could potentionaly damage the unit.
Aug 25, 2011 | Flotec Fp4332 1 Hp Convertible Jet Pump ()
My gfi reset everytime the savio pump plugin
I am assuming when you say GFI you are meaning GFCI, Ground Fault Circuit Interruptor. If the pump is throwing the smaller breaker on th plug than the pump is more than likly drawing too many amps for the plug. Make sure the GFCI outlet is rated for the same number of amps as the pump. That is a good sized pump and when it kicks on it draws a lot of power.
Mar 18, 2010 | Savio Water Master Solids Handling Pump...
I bought a pump for my fountain 4 months ago, it stopped working
This sounds like you should check your suction pipeing again and with fish be sure to get a screen for it. Then also check the impeller on the pump to be sure nothing inside it. You will need to open the pump to do this. If it has been working their is probally nothing wrong with the pump itself.
Dec 14, 2009 | Aqua Garden
HOW MUCH POWER
This circ pump draws .22 amps, and uses 25 watts and hour
(.025 kW/h)
Jul 17, 2009 | Premier 500800 1 3/4" Blue Hot Water...
Water fountaian will not work
The curcuit should be simple. The pump is the heart or this system it draws water to the pump(if it can't then the hose is plugged, or damaged) or the pump is bad. If the pump is working then it should be pushing water to its destination. if the water comes out the pump but wont or cant push the water to its destination then the impeller is bad.
Apr 26, 2009 | Beckett Water Gardening Beckett 7124110...
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
24HR working pump question
Utility Pumps: Utility pumps draw water through openings that screen out debris. When placing one into a pond, use a pump sock or other enclosure to reduce the amount of cleaning needed. If you use a pump sock, be aware that sock-like screening can cause a dry pump situation. Solids Pumps: These pumps draw water through a large opening and pump small debris through without clogging. For this reason, they can be placed into a pond without prefilters. Note, however, that this type is not safe for ponds with fish, frogs or other aquatic animals
Aug 27, 2008 | Little Giant Submersible Sump Pump, 1/4 Hp
Wilton Wedding Cake Decorating Fancy Fountain Logo
50 people viewed this question
Top Wilton Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Wilton Toy Expert? Answer questions, earn points and help others
