Question about HEWLETT-PACKARD Compaq 610 Notebook
Fixed disk parameter table or bios error compaq
Tengo un problema q es fixed disk parameter table or BIOS error system halted que puedo hacer
Deberías tener ciertas habilidades técnicas para resolver este problema, no es sencillo lo mejor sera que lleves tu computadora con un especialista el error que te marca es un error de la memoria del BIOS la encargada de iniciar tu sistema operativo(windows) llévala al técnico.
Suerte.
Aug 25, 2011 | Compaq Armada M700 Motherboard
Fixed Disk Parameter Table or BIOS Error Okay, so I was browsing around the web the other day. My notebook completely locked up, and I had to hold in the power button for 10 seconds to do a hard shut down....
Remove the hard drive and see if you get the same symptom. It should boot, then go into the BIOS and see if it recognizes the RAMs. Re-seat the RAMs if it doesn't boot - if you have two circuit boards - try one at a time. The motherboard can also be your problem.
Jan 21, 2011 | HP Compaq Smartbuy 5102 166 GHz Intel Atom...
Turn on notebook compaq nx6120, always 3 beeps and message "Fixed Disk Parameter Table or BIOS Error" and the low line is "System Halted", And another, i remove the HDD from my notebook in order to...
You should have gone into your Bios pages first.Press F2 whilst booting,learn how to to configure these pages,use the "tab" button to navigate and arrow keys ,Save and exit or restore to factory defaults,learn how to use these pages to enable correct boot sequence--good luck!
Davey Snake!
Oct 23, 2010 | HP Compaq nx6110 PC Laptop
It clicks alot when it's booting and i can't get it to turn all the way on. It says fixed disc parameter table or bios error system halted
It seems as if your hard drive has failed or is going to fail. When you hear a clicking noise like that with no CD in the system that is usually what the cause is.
May 20, 2010 | Compaq Armada M700 Notebook
Bios Issue/Hard Drive Upgrade
i have installed a 60gb hdd into an m700 without even having to stuff with the bios...
Xp sp2 allows you to install larger drives then the bios reccomends.
Feb 18, 2009 | Compaq Armada M700 Notebook
'03 compaq presario x1000
On a desktop pc u hear continuos beeping it's something to do with da ram so try replacing the ram or reseat the ram for help go to compaq.com
Nov 11, 2008 | Compaq Presario X1000 Notebook
Laptop not booting
system bios is not set on auto find of hdd or you might have to enter parameters yourself for hdd
or just corrupted files which requires a compaq driver setup disk some compaq are like that
can boot off sys. disk
May 09, 2008 | HP Compaq nx6310 Notebook
Boot up failure
Fixed disc is refering to your hardrive and the fact that it has been unable to read a bad sector on your hard drive, that sector probably being where the boot.ini file resides. You will have to get the drive checked out, by means of an 2.5" ide to usb powered connector, which will connect to another pc's usb port to enable you to perform a disk check and a repair if possible of the bad sectors, or take to a local repairer where they should have the required adapters.
Aug 21, 2007 | Compaq Armada E500 Notebook
HEWLETT-PACKARD Compaq 610 Notebook Logo
57 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
