Question about Homelite Mighty Lite Lawn Trimmer
Gas line installation on Weedwacker 18" 24cc
The gas line hardened and cracked up leaving the fuel filter shaking around in the gas tank. Where do I begin from here ?. I've already bought the fuel line ( one-eight inch looks like) now what?
  • 376 Answers
The hole in the tank is slightly smaller than the fuel line, else it would leak. So.. you can't push it in, you have to pull it in. I use a label tag wire (about 10" long), stick it through the hole and out the fuel cap hole. Snip the fuel line at an angle on the end, punch a hole in it then stick the wire through the line and twist it. Now you can pull the line through the hole.
Posted on Jun 15, 2009
My craftsman weedwacker 27cc curved shaft wont start and cant figure it out
I need to ask. Did you leave fuel mix in it for a long time? If so then the carburetor will need to be cleaned with a special cleaner. and not the spray can stuff.
Nov 24, 2014 | Craftsman 27cc 2Cycle Full Crank Curved...
On a homelite model 26 bv blower Does the gas tank filter connect to anything
The filter fits on the end of the fuel pickup line inside the gas tank. If you see the filter just rolling around in the tank it probably has hardened or damaged fuel lines. Size them up and get replacement lines online or at your local outdoor equipment retailer.
Oct 06, 2014 | Homelite Garden
How to change my gas line on a 17 inch 25cc gas weedwacker trimmer/edger
basically this is a very simple thing to do as long as you have purchased the correct size of hose. Before removing the fuel line from the tank remove it from the carburetor. then you need a small bent wire or something like it to fish the filter out of the fuel tank. When you have that done you need to remove the filter and just pull the fuel line out. When you install the new line in the tank you need to snip the new fuel hose at an angle to help in the ease of re installing it. Once you get it started you can either reach into the tank with needle nose pliers and pinch it so you can pull it back into the tank. Or you can just twist it in a circular motion until it feeds itself into the tank. The rest is common sense. Install the fuel line filter and put it back into the tank then suck a little gas up the line so the carburetor don't have to do it. that'll prime the line and make it easier for the trimmer to start.
Jun 29, 2014 | Craftsman 25cc Gas Line Trimmer
Craftsman 25 cc Weedwacker
Look for air leaks in the gas line and around the carb , a bad gas cap will not let any pressure build up. It could be that too. Check also the fuel line and filter inside the tank. replace if needed.
www.ereplacementparts.com has parts for craftsman or the online Sears Stores.
Nov 01, 2017 | Craftsman Garden
I have a Craftsman's Gasoline Weedwacker model 358.791580. The weedwacker wouldn't start after priming and choking. I observed the fuel filter inside the gas tank unattached because the fuel l
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, oo
Jan 18, 2012 | Garden
My Homelite trimlite trimmer will only run in the choked position. When I switch the choke lever to run it dies. What could be the problem
Could be a dirty fuel filter or cracked fuel line. The filter is usually inside the tank. You should be able to take the cap off and turn the unit upside down and shake it so that the filter drops from the tank. If not then grab it with a pair of needle nose pliers. If changing the filter or replacing the lines doesn't work, the carburetor might need to be cleaned.
Apr 18, 2010 | Homelite Mighty Lite Lawn Trimmer
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
http://www.ordertree.com/modelinfo/PWE/BC2400-Gas-Trimmer-Type-6/75.BC2400-Gas-Trimmer-Type-6.1.59.1.html
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Lou
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
Saw idles and then quits like it is running out of gas
Check the muffler for plugging. Check the fuel lines for cracking, hardening, or other decay. Check the diaphragm in the carburetor for hardening or cracking. Make sure the carburetor mounting screws or nuts are tight. Check the filter at the end of the fuel line in the fuel tank for plugging. Increase idle speed slightly. Adjust L carburetor adjustment a little CCW. Hope this helps!
Feb 16, 2010 | Garden
Gas line cracked and nipple fell back into tank ..how do I remove gas tank to replace gas line and nipple????..ryobi 725r trimmer
Empty the tank by dumping into a can or something. Shake the trimmer around until the "nipple" falls out. Get a replacement fuel line and follow their instructions. When yoou put the tube back into the tank, have something that you can guide the line through the hole with. I used a small hex wrench. If you cut the tip of the tube at a sharp taper, it will be much easier to start through the hole. You might think of replacing the return line as well. You should not have to remove the tank if you expose the carb and remove the air filter...Good luck...Lee
Aug 02, 2009 | Ryobi Garden
Craftsman weedwacker keeps dying
If the weedwacker runs OK on 1/2 choke or even better on full choke then most likely the cause is the carb gaskets are stiff and can no longer pump the fuel. Of course make sure the fuel lines are are the right ports (return and supply). While you have the carb apart clean all of the passages with carb cleaner.
Apr 16, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
214 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
