Question about Dell XPS Computers & Internet
Servic light number 9 illuminated when laptop is on
2 Suggested Answers
sweetyanne
  • 68 Answers
SOURCE: After being turned on the screen goes black and the lock key with the number 9 is illuminated ablove the keyboard
It is better to run the dell diagnostics, when you see the dell logo keep on tapping f12, then choose utility partition and do an express on your system.
Posted on Nov 04, 2008
What button do I use to retrieve code?
The following procedure will work for RCR311, RCR412, RCR420, RCR612, RCR812, RCR815, D770 and other similar models.
Code Retrieval
Step 1: Press and hold the component key (TV, DVD, etc.) whose code you wish to retrieve. The illuminated ON/OFF key turns on. {Some models like the RCR450 have a LED indicator light in place of the illuminated ON/OFF key.}
Step 2: While holding the device key down, press and hold the INFO key. The illuminated ON/OFF key will turn off.
Step 3: After holding down both keys for 3 seconds, the illuminated ON/OFF key turns back on.
Step 4: Release both keys. The illuminated ON/OFF key remains lit.
Step 5: Starting with the number 1 key, press and release each number key on the keypad in the following order: 1 to 9, then 0. The number that causes the illuminated ON/OFF key to blink is the first number of the code.
Note:
TV codes begin with the number 1
VCR codes begin with the number 2
DVD codes begin with the number 3
Satellite receivers and cable boxes, codes begin with the number 5.
Step 6: Repeat step 5 until you have retrieved all 4 numbers in the code.
Step 7: After the fourth number is retrieved, the illuminated ON/OFF key blinks briefly, then turns off.
Note: To exit the Code Retrieval Mode, press and release the "GO BACK" button at any time.
Hope this helps.
Feb 25, 2011 | RCA 3-Device Universal Remote
I lost the code book to the remote>can you send
Try the following procedure:
Code Retrieval on the RCA RCR312WR 3 Component Remote Control
1.Press and hold the component key (TV, VCR•DVD, SAT•CBL) whose code you wish to retrieve. The illuminated ON•OFF key turns on.
2.While holding the component key down, press and hold the INFO key. The illuminated ON•OFF key turns off.
3.After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
4.Release both keys. The illuminated ON•OFF key remains on.
5.Point the remote directly at the component for which you want to find the codes. Then, starting with the number 1 key, press and release each number key on the keypad in the following order (1-9, then 0). The number that causes the illuminated ON•OFF key to blink is the first number of the code. As you find each number of the code, write them down for future reference.
Note: All TV codes begin with the number 1; all VCR codes begin with the number 2; all DVDs, the number 3; and all satellite receivers and cable boxes, the number 5.
6.Repeat step 5 until you have retrieved all four numbers in the code.
7.After the fourth number is retrieved, the illuminated ON•OFF key blinks briefly, then turns off.
8.To exit the Code Retrieval Mode, press and release the GO BACK key at any time.
9.If you press an invalid key during the Code Retrieval process, the remote will not respond. If you do not press a valid Code Retrieval key (TV, VCR•DVD, SAT•CBL, INFO, GO BACK), Code Retrieval times out after 15 seconds. The illuminated ON•OFF key blinks four times, and then turns off.
Hope this helps.
Feb 24, 2011 | RCA RCR312W Remote Control
Macbook air how to illuminate keyboard
It should only illuminate in low light. If you want to override this original configuration, you need a program like LabTick http://labtick.proculo.de/
If it still does not illuminate, the problem is in laptop's hardware and you should take it to an Authorized Apple Service Provider.
-juuko
Nov 19, 2010 | Apple MacBook Air
Is there a web site that will let me see the fuse locations and what each fuse does.
715b237.jpg Ford Taurus fuse block diagram
The standard fuse block. Fuses: 1 - a stoplight / a turning movement signal / the alarm signalling; 2 - a window wiper washer; 3 it is not used; 4 - front illumination, a parking light, a sound signal; 5 - the electronic block, the switch of heating of a rear screen, rear illumination; 6 - a washer and a rear screen wiper (versatile person), electric window regulators of radio and an illumination headlight; 7 - it is not used; 8 - hours, the tape recorder, internal illumination, the mirror electric drive; 9 - the defroster engine / the air air conditioner; 10 - a high beam; 11 - radio, a cassette tape recorder; 12 - ignitions, the relay of a sound signal and the sound signal; 13 - panel board illuminations; 14 it is not used; 15 - a stoplight, a lamp of illumination of number board and a body; 16 - memory devices of the block of devices; 17 - blocks of electronic devices, compressor clutches; 18 - precautionary light signals / a buzzer of seat belts.
Oct 27, 2010 | 1995 Ford Taurus
What does setting 3x9x40 mean?
3 x 9 indicates that the minimum magnification is 3 times normal, and the maximum is 9 times normal. The last number (40) indicates a 40mm objective lens (the one furthest away from your eye). This is an indicator of the scopes ability to gather light from the environment. The larger the objective lens, the better it can gather light, and the brighter the view appears.
Sep 12, 2010 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
It has a code of PO742. It feels like you are
P0742 Torque Converter Clutch Circuit Stuck On
TSB #00-07-30-007A: Whine Noise in Park or Neutral, Service Engine Soon or Service Vehicle Soon Lamp Illuminates (Replace Drive Sprocket Support Bearing) - (Jan 30, 2002)
Subject: Whine Noise In Park Or Neutral, Service Engine Soon or Service Vehicle Soon Lamp Illuminates (Replace Drive Sprocket Support Bearing)
Models:
1999-2000 Buick LeSabre, Park Avenue/Ultra, Regal, Riviera
1999-2000 Chevrolet Lumina, Monte Carlo, Venture
2000 Chevrolet Impala
1999 Oldsmobile Eighty Eight
1999-2000 Oldsmobile Intrigue, Silhouette
1999-2000 Pontiac Bonneville, Grand Prix, Montana with 3.4L, 3.5L or 3.8L Engine (VINs E, H, K, 1 -- RPOs LA1, LX5, L36, L67)
and Hydra-Matic 4T65-E Transaxle/Transmission (RPOs MN3, MN7, M15)
This bulletin is being revised to add the Chevrolet Impala to the models affected. Please discard Corporate Bulletin Number 00-07-30-007 (Section 07 - Transmission/Transaxle).
Condition
Object
(1) Transmission ID Location
(2) SRTA Tag Location
(3) Hydra-Matic 4T65-E SRTA Tag
(4) Model Year (9 = 1999)
(5) Control Number
(6) Transmission
(7) Serial Number
(8) Julian Date
(9) Calendar Year (9 = 1999)
(10) Model
(11) Hydra-Matic 4T65-E ID Tag
(12) Model Year (9 = 1999)
(13) Line Built (1 = Line 1; 2 = Line 2; 3 = Line 3; 4 = Line 4)
(14) Transmission
(15) Julian Date
(16) Shift Built (A = First Shift; B = Second Shift; C = Third Shift)
(17) Model
(18) Serial Number in Base Code 31
(19) W = Warren Plant
(20) Hydra-Matic 4T65-E
(21) Model
Some owners of the above models equipped with a Hydra-Matic 4T65-E transaxle with a Julian Date prior to 0045 may comment on a whine noise in PARK and/or NEUTRAL or a Service Engine Soon or Service Vehicle Soon lamp that is illuminated. Upon investigation, a DTC P0741 or P0742 may be found.
Cause:
The above condition may be due to drive sprocket support bearing fluting and/or bearing failure.
Correction:
Replace the drive sprocket support bearing. Inspect the channel plate and drive sprocket for any abnormal wear, Turbine shaft for cut seals and/or nicks, and chain for excessive play due to failed bearings.
Important:
When installing the new bearing, the part number MUST be visible (facing upward). Before installing the drive sprocket, lubricate the bearing assembly with J 36850 assembly lubricant.
Refer to the 4T65-E Unit Repair Section for the installation procedure.
Service Part Information:
Part Number: 24214158
Description: Drive Sprocket Support Bearing
Parts are currently available from GMSPO.
Its possible that you can use a voltmeter to test for power and ground at the TCC solenoid connector and also resistance across the solenoid. The scan tool is helpful in pulling the codes, commanding the TCC on and off and monitoring the state of command while driving.
Hope help with this (remem,ber comment and rated this).
Apr 20, 2010 | 2000 Chevrolet Monte Carlo
Dell latitude D520 will not start up
The board not holding power,
this can be first chk the RAM press it tight.
the next is chk smps output.
Aug 17, 2009 | Dell Latitude D800 Notebook
I had that happen to me with my Dell as well... If you're comfortable with taking a laptop apart.. you'll need to detach the screen ribbon, clean it with rubbing alcohol, and then reattach it. This should do the trick..
Jun 02, 2009 | Dell Latitude D400 Notebook
Nov 01, 2008 | Dell Latitude D400 Notebook
Keyboard
I believe it's the num lock that is causing that locked 9 to illuminate on your keyboard
Oct 06, 2008 | Dell R6053 Keyboard/Multimedia Control...
Computers & Internet Logo
14 people viewed this question
Alun Cox
