Question about Hotpoint Refrigerators
Hss251fmc ww hss251fmcww door wont close by itself any more was until last week feels really heavy like a bearing is bad do these have a bearing or something that wears out
5 Suggested Answers
refritech08
  • 149 Answers
SOURCE: RE: true T-49
check the hinge position it's probably off line
Posted on Aug 02, 2008
  • 1218 Answers
SOURCE: Main door doesn't close easily
You may well need to purchase those bottom end parts to correct your problem. But first.....
Spray the door gasket on the hinge side with a food compatible
silicon spray. (makes it slippery).
Remove the heavy items from the door, and loosen the screws on the top hinge and try to adjust the door for a better fit.
Posted on Nov 03, 2009
  • 572 Answers
SOURCE: Hotpoint HSS251FMC WW.
its not defrosting. makesure u check heater, bimetal and defrost timer.
Posted on Feb 12, 2010
  • 1891 Answers
SOURCE: Refrigerator Door does not stay closed until
the cams that close door either have cracked or warn oup replace the cams // they lift door and close them tight . a very common problem . and not too costly .. mm
Posted on Aug 11, 2010
I have a 1999 Dodge Ram and I have a deceleration jump/vibration at around 50-40 mph. When the brake is lightly applied it happens, when heavy brake applied it stops. I'm thinking front whell bearings
The front rotors are warped, the reason you feel it when lightly braking is because the pads are just brushing the high spots as they come by. Heaving braking will lock them in tighter and you will not notice it. They have to take the rotors off to turn them so they can check the wheel bearings at the same time and replace or pack them. Just have the rotors turned if they are not worn under the federal limits. If they are worn too bad you will have to replace them.
Sep 14, 2014 | 1999 Dodge Ram
Hygena Select 620 Diplomat oven
The last person who used the oven door as a shelf to rest a heavy roast has bent the bracket the hinges go in to.
A piece of dowel (broomstick) cut to the width of the oven and placed as a fulcrum in the hinges, gentle pressure when almost closed can bend it back into position, but that wont last.
>> Replace front frame or retention brackets
Oct 16, 2013 | Ovens
My dishwasher door wont shut
see this causes, and use the common sense. God bless you
When your dishwasher door has a problem, check these: Latch Springs Hinges Door seal Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch. Springs Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs. Hinges The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough. Door seal If your dishwasher is new--or if you have just replaced a door seal--the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 19, 2012 | Hotpoint 24 in. FDW60 Free-standing...
I have a 97 Sebring Convertible JX from Florida. I live in Canada. It is a great car. I do have water in the back, but have found the reason. It has approx. 115K miles on it. I hit an open sewer drain...
Knocking/ dragging feeling/worse when turning feeling it on driver side is most likely a bad cv joint/axle/wheel bearing on that side. Usually accompanied by a 'clicking' sound when turning wheel at low speed. This will produce a code 45 due to the drag on the transmission. Hope that helps.
May 23, 2011 | 1997 Chrysler Sebring
I have a 14 year old front loader machine (had since new). I want to know if it is worth the repair and parts cost to have it overhauled as it no longer cleans clothes sufficiently for my family of 5 (9...
You are very lucky for this to last so long. Most parts will be worn .Motor/ Drum bearings/suspension/pump....My advice is to renew as you could be throwing good money after bad as we say here...Good luck....
Apr 04, 2011 | Washing Machines
2006 Saturn, dome light turns itself on when it's parked.
The car might be "thinking" that one of the doors is ajar,
Check the spring switches in all the door frames to make sure that they are hooked properly, and doing their job. One way to do it is ( if the dome happens to be off) to close and open each door several times, to see if the bad switch stays open and turns the light on, even with the door closed
Dec 06, 2009 | 2006 Saturn ION
Door won't close wont lock closed
Check the following if you have problem with your doors:
1)The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
2)Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
3)The hinges are important to the door closing properly. If they're bent or deformed, you probably need to replace them. Once bent, only rarely can they be straightened well enough.
4)If your dishwasher is new or if you have just replaced a door seal the door may be difficult to latch for a week or two. If the tightness persists, though, try adjusting the latch, if it's adjustable. If it's not adjustable, there's probably nothing you can do immediately. But try running the dishwasher on the highest heat cycle to help the seal conform to the door. Otherwise, the seal should compress over time.
Sep 03, 2009 | Westinghouse Dishwashers
Refrigerator door not closing tightly
HI. thanks for your question. sometimes you put a lot of heavy jars in the door shelves . so i would raise the front of the fridge to help it close better. thanks
Oct 15, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Open Questions:
Refrigerators Logo
15 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
