Question about Stairmaster 4600CL Stepper Blue Console Nautilus 4600 CL
After a few minutes will shut off and restart
ACT test goes above 2000
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
Check the battery - even if plugged into the wall, it may be causing your issue.
Posted on Dec 02, 2014
2010 Lincoln MKS Heated Seat on driver's side stopped working (Light in button turns off on its' own)
The most common cause of this problem is that the drivers seat heater grid is open or burned out. That is based on 25 years as a Ford dealer technician.
Feb 27, 2017 | Lincoln Cars & Trucks
My nb 1500 reads err1 after few minutes of walking
see the video and proceed inmediately. lube the rollers bearing.Of course , test a) input voltage motor if there are the motor need repair see my personal TIPS for motor help b) test the output voltage board for input voltage motor, if there are NOT the board is faulty.
Happy new year,. God bless you
Dec 31, 2012 | New Balance Balance 1500 Treadmill
1996 mustang dies and then will restart in a few minutes
Hello
The engine and transmission in this cars drive train are fully electronically controlled by a computer called the PCM (Power Train Control Module). Whenever a problem like this occurs the computer stores a record of the problem (there are of course some exceptions to this, like the fuel pump for instance) in the form of a fault code in its memory, to read these fault codes you must have the systems memory scanned with a special tool. Once the fault code(s) are read you then must perform the appropriate diagnostic testing to find and resolve the problem(s) DO NOT REPLACE ANY PARTS UNTIL THE DIAGNOSIS & TESTING IS COMPLETED.
Jul 06, 2012 | 1996 Ford Mustang
When it is cold it will start and run for about five minutes then shut off like you turned the switch off then it won't start again until it sits for a couple of hours. If I keep the rpm's up to about 2000...
First, if it is running that bad with the spitting and sputtering and all, the Check Engine light has GOT to be SCREAMING at you! If so, then that would be the first step. Get your engine computer scanned to find out why the Check Engine light is on.
If the Check Engine light is for some odd reason, not getting involved in this, I would still start with a scan and then watch the data stream to see what is going away to make the engine act the way it is. It sounds like you probably have a bad Crankshaft Position Sensor, but I would not go out and buy a new one before checking for other possibilities.
Please also review this article: What Else Could Be Wrong?
Apr 27, 2011 | 2000 Hyundai Accent
Maytag med5740tq0 that shuts off after running a few minutes. It runs fine and heats up, but then shuts off after a few minutes. If I hold the start button in it will run until I release it. After...
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse (part#7 in this picture). When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair.It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test the fuse for continuity before replacing, if the fuse is fine then check the thermostat (part#8) and thermal cut off (part#9) in the above picture. Please get back to me if you have any other questions.
Kevin
Apr 27, 2011 | Maytag Dryers
How to reset, plug or unplug my engine light on my 2000 dodge caravan?
you may disconnect the battery for a few minutes, but the correct way is to clear it with a scanner. Of course, resetting the light without the proper repairs, its just going to come back on, after the computer runs the tests and it fails.
Oct 04, 2009 | 2000 Dodge Grand Caravan
2000 olds Alero shutting off while driving
Check the 02 sensor and the ignition switc.
Oct 10, 2008 | 2000 Oldsmobile Alero
Stairmaster 4600CL Stepper Blue Console Nautilus 4600 CL Logo
322 people viewed this question
Top Stairmaster Exercise & Fitness Experts
zr800o1le
zr800o1le
Level 1 Expert
fordexpert
Matt Olenzek
Matt Olenzek
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
