Question about Cub Cadet Garden
How to remove front wheel bearings
How to replace wheel bearings on 1811 cub
  • 24 Answers
SOURCE: replace front wheel bearings
The bearings in your car are pressed into a hub. If the part is available as an assembly, it can be replaced that way. Generally on a front drive car:
Remove wheels and brake calipers
If it is pressed in: remove the rotors, disconnect the drive shafts and remove the steering knuckle. Then the old bearing is pressed out and the new one pressed in with a machine shop press. If the bearing is part of the hub, that will be unbolted and the new one swapped.
On a scale of 1-10 difficulty, Id rate it a strong 7
Posted on Jun 20, 2008
  • 19 Answers
SOURCE: Replacing front wheel bearing
The brake rotor needs to be removed, drive shaft nut in center of hub then 3 bolts hold the hub assembly to spindle from back side. if it has abs unplug it then some work will need to be done with a hammer and chisel to work the bearing out of spindle and axle shaft from bearing
Posted on Oct 16, 2008
yjpete
  • 13 Answers
SOURCE: Front Wheel bearing removal
If it is a hub assembly you dont remove the bearing, its replaced as one piece. If the parts store sold you just the bearing you WILL NEED a press. There is no trick, you will only ruine the hub and bearing.
Posted on Feb 08, 2009
daves944
  • 1050 Answers
SOURCE: 2003 Pontiac Montana Front Wheel Bearings
Remove the wheel, remove the hub nut, remove the brake caliper and rotor, put your socket and extension through the hub flange onto the bearing retainer bolts, undo them, release the abs sensor connector if it has it, remove the bearing and hub flange as an assembly, put the new one on and go backwards from here. Torque the hub nut to 180 ft/lbs, your done.
Posted on Apr 08, 2009
blueextc3221
  • 15935 Answers
SOURCE: replacing front wheel bearing
  1. Loosen the wheel nuts and the center axle nut.
  2. Raise the vehicle and safely support it.
  3. Remove the wheel. Remove the ABS speed sensor if so equipped.
  4. Unclamp the brake hose from the shock absorber, but do not disconnect the line.
  5. Remove the brake caliper and hang it out of the way on a piece of stiff wire. Do not disconnect the brake line; do not allow the caliper to hang by the hose.
  6. Remove the brake disc.
  7. Place a dial indicator near the center of the axle hub, and check the backlash in the bearing shaft direction. Maximum is 0.0020 inch (0.05mm). If the backlash exceeds the maximum, replace the bearing.
    1. Usiung a dial; indicator, check the deviation at the surface of the axle hub outside the hub bolt. Maximum is 0.0028 inch (0.07mm). If the deviation exceeds the maximum, replace the axle hub.
    2. Install the disc and caliper. Tighten to 65 ft. lbs. (88 Nm).
  8. Remove the cotter pin and install the wheel. Lower the vehicle to the ground.
  9. Remove the lock nut cap. While depressing the brake pedal, remove the center axle nut.
  10. Raise and support the vehicle again and remove the wheel, caliper and disc.
  11. Loosen the 2 nuts on the lower side of the shock absorber. Do not remove the 2 nuts and bolts.
  12. Remove the cotter pin and nut from the tie rod end.
  13. Remove the tie rod end from the knuckle using a joint separator or equivalent.
  14. Remove the bolt and 2 nuts holding the bottom of the ball joint to the control arm and separate the arm from the knuckle.
  15. Remove the 2 nuts from the steering knuckle. Place a protective cover or shield over the CV boot on the driveshaft.
  16. Using a plastic mallet, tap the driveshaft free of the hub assembly.
  17. Remove the bolts and remove the axle hub assembly.
    1. Clamp the knuckle in a vise with protected jaws.
    2. Remove the dust deflector. Loosen the nut holding the ball joint to the knuckle. Use a ball joint separator tool or equivalent to loosen and remove the joint
    3. Use a slide hammer/extractor to remove the outer oil seal.
    4. Remove the snapring.
    5. Using a hub puller and pilot tools or equivalents, pull the axle hub from the knuckle.
    6. Remove the brake splash shield (3 bolts).
    7. Use a split plate bearing remover, puller pilot and a shop press, remove the inner bearing race from the hub.
    8. Remove the inner oil seal with the same tools used to remove the outer seal.
    To install:
    1. Place the inner race in the bearing. Support the knuckle and use an axle hub remover with a plastic mallet to drive out the bearing.
    2. Clean and inspect all parts but do not wash or clean the wheel bearing; it cannot be repacked. If the bearing is damaged or noisy, it must be replaced.
    3. Press a new bearing race into the steering knuckle using a bearing driver of the correct size.
    4. Place a new bearing inner race on the hub bearing.
    5. Insert the side lip of a new oil seal into the seal installer and drive the oil seal into the steering knuckle.
    6. Apply multi-purpose grease to the oil seal lip.
    7. Apply sealer to the brake splash shield and install the shield.
    8. Use a hub installer to press the hub into the steering knuckle.
    9. Install a new snapring into the hub.
    10. Using a seal installer of the correct size, install a new outer oil seal into the steering knuckle.
    11. Apply multi-purpose grease to the seal surfaces which will contact the driveshaft.
    12. Support the knuckle and drive in a new dust deflector.
    13. Install the ball joint into the knuckle and tighten the nut to 105 ft. lbs. (142). Install NEW cotter pin.
    14. Temporarily install the hub assembly to the lower control arm and fit the driveaxle into the hub.
    15. Install the knuckle to strut bolts, then attach the tie rod end to the knuckle.
    16. Tighten the strut bracket nuts to 203 ft. lbs. (275 Nm) and tighten the tie rod end nut to 36 ft. lbs. (49 Nm). Install the NEW cotter pin.
    17. Connect the ball joint to the lower control arm and tighten the nuts to 105 ft. lbs. (142 Nm).
    18. Install the brake disc.
    19. Attach the brake caliper to the knuckle and tighten the bolts to 65 ft. lbs. (88 Nm).
    20. Install the center nut and washer on the drive axle.
    21. Install the ABS speed sensor if so equipped. Install the wheel
    22. Lower the car to the ground.
    23. Tighten the wheel nuts to 76 ft. lbs. (103 Nm). Tighten the hub nut while depressing the brake pedal to 137 ft. lbs. (186 Nm) on 1988-91 models and 152 ft. lbs. (206 Nm) on 1992-97 models. Install the cap and cotter pin.
    24. Remove the protective cover from the CV boot. Check front wheel alignment
Posted on Apr 25, 2009
Is it possible to remove and replace front wheel bearings with out a press
In order to remove the front wheel bearings without press hub off the bearing and then the bearing out of the knuckle. To do the first step need a a Support Bridge.It is a special tool. Make bridge and use a general bearing pulled kit to replace bearings. use a "Front Wheel Drive Bearing Removal Adapters Puller Pulley Tool Set Kit" .To replace the bearing, remove front CV shaft taking care not to move the CV shaft too far out .
Nov 06, 2015 | 2002 Kia Rio
How do you replace a front wheel bearing
remove the wheel, remove the spindle dust cover and remove tho cotter pin and remove brake caliper and finally remove thr spindle nut,washer and inner bearing and finally the rotor. remove the dudt seal on the back of the rotor and finally the inner braeings.when you replace the bearings make sure that you replace the races and install a new seal on the rotor
Sep 03, 2014 | 1993 Ford Crown Victoria
How do I replace a front wheel bearing?
front wheel bearing is pressed into hub and has retaining clip on rear and then cv axle shaft comes through center and has a nut and keeper pin. Rule of thumb is to replace both front wheel bearings at same time. raise front of vehicle place on jackstands for safety remove front wheels remove brake calipers remove front rotors and cv axles remove steering hub assy from lower ball joint,tie rod end and struts take hub to shop and have bearing pressed out have new bearings pressed in reassemble front wheels in reverse order of disassembly.
Aug 03, 2014 | 2002 Mitsubishi Lancer
Cub cadet troubleshooting
?huh? Thats TOTALLY UNSAFE and really hard on the starter motor. Check out MTDPARTS.COM
Feb 03, 2014 | Garden
Cub Cadet Problems
Sorry it has taken so long to reply, busy time of year. It is very possible the wheel bearings are going bad, but you should notice it at all times. Some lawn and garden tractor front wheels are that way for steering. The John Deere lawn tractors are toed in for example. Wouldn't hurt to check the wheel bearings as well as the spindle bearings. They should all be greasable, and if the issue is better after greasing, you have found your problem. If not, let me know and I will see what else I can come up with, Daniel.
Oct 23, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Replace front wheel bearing
The front wheel bearing for your Impala is an integrated wheel hub/bearing/ABS.
The whole thing gets replaced. It should look like the one off my Bonneville; Bearing.
Remove wheel/tire. Remove brakes. Remove rotor. Remove axle nut. Press-out axle shaft*. Unplug ABS connector. Remove 3 bearing bolts.
*To press out axle, you may need a special tool from an auto parts store.
Don't forget to put the heat sheild back on during reassembly, and the axle nut need to be very tight.
After Bearing/hub removed:
Apr 21, 2011 | 2004 Chevrolet Impala
Replace front hub assembly.
Replacing the front wheel bearing/hubs can be a big job for the inexperianced. Briefly...
Remove tire/wheel
Remove brake caliper assembly, do not remove brake line.
Remove caliper bracket.
Remove brake rotor.
Unplug ABS sensor.
Remove the large axle nut.
Press axle out of bearing (may need special tool)
Remove the 3 bearing bolts and remove bearing.
May 19, 2010 | 2003 Chevrolet Impala
Does the front wheel bearing have to be machined
on that vehicle it,s replacement remove wheel remove brake caliper and pads remove brake caliper mount if you look on back side of spindle around area where axle comes thru you have three or four bolts remove bolts remove axle nut and hub bearing assembly comes off re-install in reverse order if this vehicle has 4 wheel abs unhook any wheel speed sensors
Mar 18, 2010 | 2003 Ford Explorer
How do you remove the front tire on Cub Cadet LT1045? Seems to have a plastic hub over bolts.
Thats a plastic dust cap.Remove it very carefully so not to damage it. Then under the plastic cap will either be a Cotter pin or and E clip remove what is there and slid the tire and wheel off the spindle. These are a bear to break down and dismount and or remount. Unless you have a mini tire changer. I use my huge vise and a shaft the size of the spindle.I use motorcycle or bicycle tire irons. ITs a hassle believe me.
Oct 19, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
14 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
