Question about Panasonic TOUGHBOOK CF-18 Tablet PC
Pansonic toughbook not displaying external monitor
Can't get external monitor to work
My touchscreen goes so dim I cannot see the display
may be problem with your display backlight hardware problem
Jun 29, 2014 | Panasonic TOUGHBOOK CF-18 Tablet PC
How can I fix Toughbook
If you screen was dimming on your Toughbook, then try to
attach an external VGA monitor when the Toughbook is
turned off, then power on the external monitor,
then power-on the external screen.
If the external screen works, then you may have a bad
inverter if you TB is 2007 or before.
If the TB is 2008 or 2009 or later, then probably your screen
is NOT LCD with an inverter but instead LED. Which means
that you have to replace the entire LED screen.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Apr 16, 2014 | Panasonic Toughbook Tablets & eReaders
External vga display doesn't work
Check external monitor settings on Fijitsu.
Jul 03, 2017 | Fujitsu Siemens Stylistic ST5022 Tablet PC
Panasonic TOUGHBOOK CF-18 Took out HD to reload windows as it would not load but stuck at the safe / last known good config etc. Loaded XP onto HD via an ACER laptop and reinserted it into ToughBook -...
I think your actually having issues getting it to run on the toughbook because it uses different drivers for everything from the Acer computer. If you press F8 while booting up you can choose the option "Disable automatic restart (of system errors or something)". Then when the machine boots up you should get a blue screen giving you an error code like "IRQ_EQUAL_TO_OR_GREATER_X Error: 0x0000005f. You could try to see what the message is trying to tell you to resolve it but the error msg would likely point to the driver that its trying to load that's most likely different from the toughbook you have. I'd suggest getting an external cdrom/dvdrom and install windows from a disc onto the toughbooks hd while its in that toughbook machine.
Dec 21, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
My monitor display has rotated itself 90 degrees counterclockwise and I do not know how to return it to it's normal position. What do I do to return it to it's normal "Landscape" position?? I have a...
on the front of the toughbook there are 4 small buttons, the 3rd from the left which has a right angle symbol with a double headed arrow in it rotates the screen 90 degrees each time you press it. this is probably how you got it like that in the first place.
Aug 05, 2009 | Panasonic Toughbook-19 Tablet PC
Connecting to data projector
CONNECTING VIA VGA CABLE,RIGHT CLICK ON THE DESKTOP SELECT DISPLAY,
CONNECTING EXTERNAL DISPLAY,
MIRROR ON ALL DISPLAYS
WALLA AND BOB'S YOUR UNCLE
HOPE THAT SOLVES THE PROBLEM.
Jul 03, 2009 | Fujitsu Stylistic ST4110 Tablet PC
HP Compaq 2710p: External monitor does not display anything
The display properties indicate the hardware is working, so it's likely just a setting.
On HP/Compaq models you will see a picture, usually on the F4 key that looks like a screen with two lines beside it.
You need to hold down the Fn key(bottom left) and then push the F4 key at the same time to cycle between LCD, external or both.
If it is a newer model, a menu will pop up when you do this asking if you want to duplicate the LCD on the external, switch to the external or extend the desktop onto the external. Select the appropriate setting or continue holding down Fn while pressing F4 to cycle between the settings to the one you want.
If you have re-installed the computer at some point with anything other than the factory recovery set this may not work and I will have to give you a longer set of instructions.
If this works please rate this as fixed, if not reply back and indicate what version of windows you're using and I will post the instructions for the "long" way.
Chris
May 26, 2009 | Compaq 2710p Tablet PC
Panasonic cf 18b toughbook,touch screen do not work,help
goto your device manager and then find your display driver and update it. Dont search for it, manually locate the driver being in the location where you extracted the driver. Then update. and bingo!
Feb 18, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic touchbook cf18
When I touch the touch pad my screen display goes off. it comes on sometimes by itself or when touch pad is touched. I have connected the toughbook to an external dispaly and can work no problems. help
Oct 22, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
41 people viewed this question
Top Panasonic Tablets & eReaders Experts
Paul Wang
Mike
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
