Question about Amana NTW4600YQ Top Load Washer
Overloaaded then shook control doesn't work
Fills with water doesn't stop & lid switch doesn't lock
2 Suggested Answers
  • 464 Answers
SOURCE: Machine will not drain the tub or spin the
your problem still could be a bad lid switch not making. also, check your spin/agitate belt part #40053606. hope the attaced breakdown helps.250
Posted on Nov 08, 2009
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 28, 2016 | Washing Machines
W6444
make this steps and fix it. God bless you
Lid Switch Assembly
Enter your model number to see parts for your washing machine.
Help me find my model number
Water Inlet Valve
Main Control Board
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Jul 25, 2013 | Washing Machines
Water starts to pass through but then stops and error alarms start
see this causes and fix it. God bless you
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Oct 05, 2012 | LG Washing Machines
The water starts to come through then just stops and then alarms go off
Oct 05, 2012 | LG WFT1071TP Top Load Washer
My maytag epicz will run water and then just stop it lock and later get code f33
Oct 05, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Does not spin out clothes, keeps running in water as long as spin is enabled and does not follow cycle selected.
Sep 30, 2012 | Haier XQG50-QF802 Front Load Washer
Whirlpool 1000 w100 stops after filling with water
Sep 30, 2012 | Creda W100FW Front Load Washer
Agitator continuously on
see the diagram
Sep 30, 2012 | Frigidaire GLWS1233A Top Load Washer
Agitator starts wont quit
see the diagram
Sep 30, 2012 | Frigidaire Washing Machines
Washer stops at rinse cycle and give the ul code F1
Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Amana NTW4600YQ Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
