Question about Kenmore Elite 45986 Front Load Washer
I get an error message dl then f washer will not start for kenmore elite front loader
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 16, 2010
Kenmore elite model # 110.45088400. We set a cycle, washer starts beeping and reads F then blinks to DL. We hit pause to clear then try to restart while it makes clicking sounds and it continues to read...
'DL' stands for Door Lock error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 24, 2011 | Kenmore Elite 45986 Front Load Washer
We have a Kenmore Elite Quiet Pak 4 Washer that we have had for 5 years. It has been flashing F11 and DL back and forth for months. We had a tech come out (not sure he knew what he was talking about) and...
The symptoms are pretty specific for the F11 code on the Whirlpool Duet front loaders and clones (Kenmore Elite and KitchenAid):
If the washer starts to fill but the drum NEVER moves, your MCU is bad
If the washer runs through most of a cycle and then gives the F11 before (or during) a rinse or spin cycle, then you have the CCU relay problem.
If you are interested in having me repair your CCU for you, I offer that service on eBay (website coming soon). My username there is "jhagner"
Thanks
Aug 19, 2011 | Kenmore Front Load Washer
Kenmore Elite Washer
Door lock error replace the door lock switch
May 16, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Eric
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Error message
Hit cancel the amount of minutes will stay the same and then hit the start button again.
May 13, 2009 | Kenmore Elite 45986 Front Load Washer
What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
