Question about NorStar T7316E Corded Phone
Is the nortel 7316 analog?
Should it work with a digital line? no dial tone on box of phones.
  • 192 Answers
No, the T7316 set is digital, this is the reason why you cannot just take it home and have it work. Two different styles of signalling. The T7316 set only works with Nortel Systems.
Posted on Jun 16, 2009
Where do i look to see why machine isn't calling out to verify card
first check the phone line it self. take all phone lines out of the credit card machine, and unplug the power to machine. now take a telephone with a phone line attached and plug that into wall as if you were making a call on that phone. check for dial tone. if you have a dial tone, make a call. do you require a 8 or 9 to dial out? you terminal may not recognize that.
also if you do have dial tone do you use digital or analog phone lines? you need analog for terminals. if you have a fax line you can connect the terminal to fax via phone line. if this does not work contact phone co and ask what type of lines you have, you can also connect most terminals via Ethernet.
Jun 08, 2014 | VeriFone Omni 3730 Aka Vx510 Credit Card...
We are unable to reset the password to the Nortel BCM50 phone system. We just ordered new 7316 E Nortel phones, but cannot get this feature to work. How do we proceed?
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Nov 02, 2012 | Nortel T7316E 2-Line Corded Phone
Why won't the phone come on when I connect it to the outlet?
it depends on which phone you have sometimes a phone may not have one.
Apr 15, 2010 | NorStar Meridian M7310 Phone
Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
I have a used Nortel Networks T7316E and for some reason when I plug it in to the phone line at home I get no dial tone and the light at the top and the three buttons on the bottom (headset)(Mute) etc......
The Nortel 7316 set is propriatary which requires the nortel system in qrder to work., The pulsing lights are the set reacting to the standard line voltage.In order for it to work in your house you'll have to install the nortel phone cabinetand then attach the set(s) to it.
Jan 19, 2010 | Lands Phones
Just plugged caller id box in to panasonic kxt7420
There is no such thing as correctly plugging an analog caller ID box into a digital phone line.
CID display comes from a TD-193 card mounted in the Key Service Unit and it only displays on Panasonic system display phones designed to work on a TD system. The only system that passes CID through to stations is a TA-824 and certain models of TDA-s that have special analog extension cards.
You can use the analog box, but you have to bring the line from in front of the system to the CID box.
Carl
Nov 11, 2009 | Panasonic KX-T7420 Corded Phone
T7208 flashing light-no dial tone. Is there any hope?
sounds bad to me.
Is the light flashing really quick? Or is it like when you have a voicemail and flashing...
You may have plugged the set into an analog port, where the set is getting too much power and that is one reason why it could be flashing like it is.
Plug another set, that you know is working into the same jack, this will tell you if the jack is set up for your digital phone or for an analog phone.
Aug 13, 2009 | Nortel Business Series Terminal T7208 -...
Meridan 7208 help please
Dear sheryl498,
Your phone is designed for a PBX (Private Branch Exchange) unit like the Compact ICS or the 6x16 TCU that was at the office. It is not compatible with regular POTS lines or standard home lines.
Jul 29, 2008 | Nortel Meridian M7208 Corded Phone
Can't dial out
What are you getting when you try to dial out? Sounds or display wise? How are you dialing out? Do you access a line, dial 9 from intercom? The dial tone is probaly the phone system generated dial tone. With more information, I can help..
Oct 25, 2006 | Nortel Meridian 9417CW 2 Line phone
NorStar T7316E Corded Phone Logo
464 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Oloyede Monsuru
Jose Ma DM.
Jose Ma DM.
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
