Question about Technics SL-1200M3D Turntable
Fuse location of technics SL 1200M3 turntable
Fuse of technichs turntable
    Champion:
  • Technics Expert
  • 271 Answers
Hi, you need to remove the platter and then unscrew the under platter cover to access fuses. Cheers john, Stylus City
Posted on Apr 04, 2014
  • 7 Answers
SOURCE: turntable technics sl-bd27
You have 4 wires coming from the needle pickup to the cables which connect to the amplifier/receiver. I would check the needle, the pickup unit, and the leads from the pickup to the cables. You can probably run a continuity test or ohm test for verification. If that checks, pickup and needle is your next step.
Posted on Dec 18, 2007
SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
Posted on May 21, 2008
SOURCE: Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Posted on Nov 09, 2008
djproaudio
  • 515 Answers
SOURCE: Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies to other brands as well - however this belt is only for the Technics models listed above:
  1. Remove the turntable platter off from the turntable
  2. Remove the old/damage belt
  3. Wrap the new belt underneath the turntable platter - you will see a small lip on the bottom of the platter. Wrap the belt around this lip.
  4. Put the platter back on the turntable
  5. The turntable platter will have small holes, rotate the platter until you see the motor, and the motor shaft.
  6. Pinch the belt, so that it wraps around the motor shaft
  7. Turn on and enjoy!
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Mar 27, 2009
hondo73162
  • 132 Answers
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
Posted on Nov 13, 2009
Technics sl dd33
The power supply of the turntable needs checking. It could be just a fuse or something more serious, such as a faulty transformer.
Mar 09, 2016 | Technics Audio Players & Recorders
No power when i turn on my mk3 turntable
Check the internal fuses. There are two. You have to strip the unit down to get to them.
This video will show you what's involved:
http://www.youtube.com/watch?v=CDYgjwdQ55s&feature=channel_page
Aug 17, 2009 | Technics SL-1210 Turntable
Hello Cliff,
Tony
Nov 15, 2008 | Technics SL-1210 Turntable
hello
Oct 09, 2008 | Technics SL-1210 Turntable
Technics 1200
Sounds like your transformer is blown. This is located underneath the turntable platter, right next to the main PCB (Printed Circuit Board). You'll have to have this replaced. I do not suggest replacing it yourself, unless you are handy with electronics. Otherwise, please take it to a service center for repair.
FYI, the part is located here (www.1200s.com), so you can purchase the part separately, then take it in.
We are the 1200s Experts!
DIGITAL ANALOG THERAPY
Jun 10, 2008 | Technics SL-1200MK2 Turntable
They wont turn on
Check the fuses. If the fuses are good, then it's the transformer that is shot. The fuses are located underneath the turntable platter. If your unit does not have any fuses, then the only problem could be with your transformer. You can PURCHASE A REPLACEMENT TRANSFORMER HERE.
Good Luck!
- Davis.
Jun 05, 2008 | Technics SL-1210 Turntable
Internal fuse
remove platter remove plastic cover main fuse is there
Jan 29, 2008 | Technics SL-1210 Turntable
Technic turntable SL-101
http://1200s.com/Store/PARTS-TECHNICS-TURNTABLES/c271_272_278/index.html
These guys are pros.
Nov 07, 2007 | Technics SL-1210 Turntable
Technics SL-1200M3D Turntable Logo
78 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
