Question about Sony RDR-HXD860 DVD Recorder/HDD Recorder
Stuck in timer ready
Can not clear timer ready
How do I clear the timer fuction on my GE profile microwave
hi Donna.
this is all i could find out.
How to clear timer on GE microwave? Clearing the Timer on the Microwave. On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function. Review the Owner's Manual for model specific directions.
Clearing the Timer on the Microwave - Products - GE Appliances
products.geappliances.com/appliance/gea-support-search-content?contentId=16868 Search for: How to clear timer on GE microwave?
or this.On most GE microwaves the Timer function can be cleared by simply pressing the Clear button once or twice. On some models pressing and holding the Clear or Timer buttons will clear the function.
How to clear the timer fuction on my GE profile microwave Google Search
Nov 26, 2017 | GE Microwave Ovens
Irritrol rd 900
IT'S NOT THE TIMER: The hydraulics in the valve are stuck. Best solution is to purchases same valve and replace all the internal parts with the ones from the new valve.
May 15, 2013 | Irritrol RD900-EXT-R Rain Dial 9 Station...
Zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Apr 02, 2013 | Zanussi Dishwashers
How do I wire a intermatic ET 1125 c timer for BOTH LOADS TO COME OUT
10-22-12
ET1125 timer wiring:
Copy following link for clear illustration of wiring.
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html#1125
ET1125 timer is shipped with default 240Volt, selectable for 120-208-277V.
Timer is selectable for simultaneous or indenpendent programming so each load can be operated separately
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 22, 2012 | Hardware & Accessories
MDE5500AYW stuck on "39"
Hi, I believe you need a new timer switch. It is not a easy thing to replace so have a repairman look at it. Good luck.
Dec 26, 2011 | Maytag Neptune MDE5500AY Electric Dryer
The manual does not help. I'm obviously not understanding them correctly. I need step by step...all I want to do is have my lights come on from 7 pm to midnight every day of the week..they are not...
There is no repair for defective timer.
Sounds like the timer could have a conflicting program.
1) Good idea to test outlet with cheap circuit analyzer to make sure electric outlet is not causing problems for timer electronics.
2) Press reset button on timer face using toothpick to Re-set the timer
This will clear programming and then timer is ready to start over.
You can unplug timer from outlet while programming timer, so buttons and display are easy to see.
3) Open following link for clearly written instructions:
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
4) I suggest setting timer program1 ON at 7:00pm, and choose all-days-of-week
And then set program1 OFF for 11:59pm all-days-of-week
Setting to 11:59 pm instead of 12:00 may solve problem.
5) Open following link for Kitchler manual:
http://waterheatertimer.org/pdf/Kitchler-15558WH-timer.pdf
6) If timer will not program correctly, and electric circuit is clean, then timer is defective.
This timer has 1 year limited warranty against workmanship defect.
I always suggest buying timers at local store because returns are cheaper, and if timer goes bad two years later, you can buy new timer and return defect in new package.
Kitchler is same timer as sold by Utilitec at Lowes, and Westek at Target.
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 03, 2011 | Kichler PLUG-IN ACCESSORIES - DIGITAL...
When is ON the timer admit a water jet and after that the valve is closing even if the battery is full, the timer ON and the supply of water open. Thanks
Problem is not clear and timer not identified.
Open following link for Gardena resources including contact information for Gardena.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
If timer is cracked, then electric parts can get wet and stop working.
If timer valve is not closing, maybe the timer is broken or something is stuck in the valve.
Add a comment for more help
Upvote the help.
Also take advantage of fixya expert assistance live.
Jun 09, 2011 | GARDENA Water Timer
Machine will fill but not complete any cycle. suspect timer
If the washer will fill on all cycles except rinse, it indicates a cold water supply problem. (Cold water is what is used in the rinse cycle). This normally would be caused by a faulty solenoid on the water inlet valve. Here is a picture. The solenoid can be checked with an ohm meter or multimeter. If the solenoid reads zero ohms, it is stuck open and the inlet valve must be replaced. Hope this helped and best wishes.
Jul 28, 2009 | Kenmore HE3T Washer
Installation of part no. WE4M190 (timer) in GE gas dryer DPSQ475GT5ww
take off the back panel look closely at the timer you will see a tab that you carefully pull up a little and twist the timer off. to take off the knob in the timer opposite the knob there is a pin that you pull out and the knob will pop off.
Jun 10, 2008 | GE DBXR463GB Gas Dryer
Best but repleace bulb but red light still on
So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
Sony RDR-HXD860 DVD Recorder/HDD Recorder Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
