Question about GE FUF14SVRWW Upright Freezer
Remove freezer door
How to remove the freezer door
Door does not stay sealed when closed.
first make sure there is nothing inside stopping the door from closing , the freezer should be level, and the door should swing close on its own free will. the door can be tweaked by bending it back into shape .or by setting the top hinge bracket, it should have three 5/16 bolts, that will alow you to ''square the door''. but most of the time it's something in the way of the door.. look close and remove some items that you think might be in the way, then remove some more
Aug 08, 2011 | Kenmore 7.5 cu. ft. / 212 liter Upright...
MY FREZER HAS FROST AROUND THE DOOR AND MOLD IS GROWING AROUND IT
You need to replace the door gasket. It's leaking air causing the frost.
May 04, 2011 | Whirlpool Freezers
THERE IS A GAP BETWEEN THE TOP OF THE MAGNETIC SEAL AND THE FRIDGE COMPARTMENT, THE DOOR CAN BE LIFTED UP, IS THE A SPACER AVAILABLE TO FIT TO THE BOTTOM OF THE DOOR TO COMPENSATE THE GAP. THANKS Frank...
Good day,
Just go to your local appliance parts house. They will have the shims you will need. Remove the top bracket, open the door slightly, and lift the door off. Install the number of shims necessary, and reinstall.
If it has a cam style bracket that helps close the door, replace it as well. It just bolts on, once the door is removed.
Nov 22, 2010 | Frigidaire Freezer Refrigeration White...
Door on new Kenmore freezer hard to open ... could this be a leveling problem? I wouldn't think it is an ice build-up problem since the freezer was only installed last Friday (9/24) and the ice maker is...
Check thoroughly for any obstructions, shipping tape, remaining pieces of plastic, in and around the doors, door frame, cabinet frame that the door contacts when closed, and around the upper and lower hinges. Do you hear any noises when opening or closing the door? Do you see the door rubbing on the inside liner as you open or close the door? Were the doors removed and replaced in moving? This last one, if it is the case, check the alignment at the upper hinges, loosen but dont remove the screws, and adjust the door away from center.
Sep 30, 2010 | Freezers
Defrosting
Remove all items place in cooler, this is going to be awhile.
Turn temp down for freezer thaw it. Placing towels in there to remove water from time to time. Star freezer back up with door closed. maintain usuage.
May 01, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
I would like to remove the door,The door has two screws holding the hindge on what type of screw driver do I need
most upright freezers have a 3/8" screw to hold the hinge to the cabinet. most also do not allow you to reverse the door so are you wanting to do something else by removing the door?
Jan 03, 2010 | Freezers
Re: danby upright freezer 20.1 cubic ft., model #
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Oct 13, 2009 | Freezers
Ice and frost
Excess frost especially near the door is caused by door gaskets being bad. The gasket should hold a dollar bill snug.
Another possibility is auto defrost failure. - Remove the cover on the rear inside the freezer to see if the coils are heavily iced.
Aug 13, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
GE FUF14SVRWW Upright Freezer Logo
71 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
John Tripp
John Tripp
Are you a GE Freezer Expert? Answer questions, earn points and help others
