Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Replace the wast toner for the samsung clx3175
Where is the waste toner located
    New Friend:
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and still the message will not go. I have a stack of work to do and am stuck as to what to do next! Help please
Posted on Apr 24, 2014
BondoFox
  • 40 Answers
SOURCE: waste toner tank full/not install keep displaying
The sensor for the waste toner tank is dirty or defective. The toner sensor is on the right as you look at the panel just below the liquid crystal display. There is a bump in the clear plastic just below the circular right vent port, that's where the used toner pours in. When you clean out the toner cartridge there is some residue left that makes the sensor think it's still full. Take a piece of paper towel and a small screwdriver (I'm told a bent coat hanger will work, too) and clean the inside of the sensor window inside the used toner cartridge (w/ access through the toner port). It looks like a little raised groove on the right. Just wipe it until it's clear on the inside. The sensor can now see through the window and you should be okay. Otherwise, the sensor may need to be replaced by an authorized Samsung technician. Let me know how it works out!
Posted on Jun 16, 2007
SOURCE: Dell 1235cn Laser All-in One Printer - Waste Toner Bin issue
Wash it out with rubbing alcohol and let dry. Apparently there is a light sensor that will throw up this error if the bin is dirty.
Posted on Nov 29, 2010
  • 3 Answers
SOURCE: I install the toner waste bin, but I still get an
There is photo-optic detector, clean two side emitor and receiver.
Posted on Jan 04, 2011
SOURCE: Replace/Install toner waste bin error
The toner box is probably full. The toner box is a clear box on the left side when you open the front cover. The box has the labels Y, M, C, and K on it. Pull it out using the tab at the bottom. find a place to empty it. You can do this by turning it upside down and gently tapping it. If the box is full some toner may be outside of the box causing the sensor to be blocked even after it is empty. You may want to clean the box, toner cartriges and inside the cavity with qtip, tissue paper (without lotion), or air.
Posted on Jan 05, 2011
  • 48 Answers
SOURCE: install/replace toner waste bin.
The waste toner is a large, clear plastic container on the left side of the printer when you look at it from the front. Here is the info and a picture from the Samsing website: http://www.samsung.com/us/computer/printers-accessories/CLT-W409/SEE
To remove and replace it, turn the printer off and wait a few minutes for it to cool, then open the front cover and look at the bottom left of the printer. There should be a clear plastic handle that you can pull the whole waste unit out with. Be carefull not to spill any of the toner; that powder gets everywhere. There will be a small green or blue plastic clip attached to the bottom of the waste container that you can pull off and clip onto the opening to close it.
Samsung of course wants you to replace the waste toner container with a new one, which you may have to do, but there are some printers that simply emptying the cartridge out will allow you to use it again. Be careful if you decide to do this though: toner is very dangerous to breathe in, so don't shake the toner around to empty it and get a facefull. Be gentle with it and make sure to dispose of the toner properly and put the cartridge back in and see what happens. If it works, great! You don't have to buy a new one. However, if you empty it and it keeps giving you trouble, you may just need to order a new one. The part number is CLT-W409, and most waste units cost under $20.
I hope this helps! Good luck!
Posted on Feb 15, 2011
Testimonial: "thanks it works"
It says replace a waste toner
The waste toner box is full.You have to replace it now.Replace the waste toner box with the new one or empty the waste toner box and fix it again.Your problem will be solved!
Apr 09, 2014 | Samsung CLX 3305 - multifunction fax /...
Where is the transfer belt in the clx3175
Dear,
First take out the toners
Then take out the waste toner container from the left hand side (usually supports toner cartridge on left hand side)Then pull the imaging unit (Green color drum sensitive to white light and touch of fingers)
After this u will find the transfer belt. U need to take carefully out. (there will be a small cable also attached to it).
Best Regards
May 01, 2012 | Samsung CLX-3175FW Multifunction Laser...
What solution for samsung clx3175 asking intall image unit
Dear ,
Kindly refer the following link,
http://www.samsung.com/us/computer/printers-accessories/CLT-R409/SEE
This imaging unit needs to be replaced after it complete its life (6000 color pages/ 24000 mono images)
To replace first you need to takeout the toners and waste toner container ( a transparent/black container on the left hand side)
after that you may take out the imaging unit.
after that put the new imaging unit.
put the waste toner container and put back the toners.
If problem persists please provide your feedback.
Best Regards
Apr 19, 2012 | Samsung CLX-3175FW Multifunction Laser...
Waste toner tank location
Open Front lid and find the waste toner tank left of the cyan cartridge. Just pull the vertical handle to remove it. After littering the waste toner make sure that transparent windows of the tank are clean. There is a light barrier.
Oct 23, 2010 | Samsung CLX 3160fn All-In-One Printer
Our office has a pretty new Samsung CLX-3175FW. Right now it states "REPLACE/INSTALL TONER WASTE BIN" I have no idea where that is located or what its function might be. Can you help me? No one else...
the toner waste bin in in the toner bay on the left hand side. It simply pulls out. You can purchase a replacement or just dump all the old waste toner out. It can be a little messy. It works with an "electric eye"
Sep 07, 2010 | Samsung CLX-3175FW Multifunction Laser...
HOW DO YOU CHANGE THE WASTE TONER ON SUMSUNG 2160 PRINTER
he 'Waste Toner Tank' is the gray colored part located to the left (If you're facing it) of the toners barrel. So all you need to do is take the Waste Tone Tank out, shake out all the waste tone from it and replace it.Then your printer should be up and running. Your other options is to buy a new one for about 12$ off the internet. If you need further assistance let me know.
Thank you,
Lee
Aug 25, 2010 | Samsung CLX-2160N All-In-One Printer
Waste Toner Tank
Please open the front cover( where the toner bottles are located). You will find a transparent "L " shaped box is the waste toner tank. You may pull it out and replace it.
Oct 27, 2009 | Samsung CLX 3160fn All-In-One Printer
My samsungclx-3160 all in one is asking me to replace/install waster toner tank?? it wont print now whats that
The waste toner tank may be full. Please open the front cover( where the toner bottles are located).
Oct 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Waste Motor Error message on Samsung CLP-500
This error is caused by the Waste Toner Motor 'stalling' - usually as a result of the Waste Toner Full message being ignored for too long, and the waste system becomming overful.
Usually best to replace the Waste Toner Motor assembly.
They are for sale on auction websites from time to time.
Sep 12, 2008 | Samsung CLP-500 Laser Printer
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
281 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
