Question about Steinel 02120 - Replacement Heating Element for HL2010E Heat Gun
Steinel HL 2010
No heat. Only 50 deg c
RETURN STRONG; NEW FILTER;DUAL FLAME STRONG; POOR HEAT. 4 HRS TO BRING TEMP UP 13 DEG; OUTSIDE TEMP 50 DEG. LP GAS CONVERSION
Are flames running the whole time? They could be shutting off and coming back on. Need to sit and watch if they are staying on. Sounds like u have flame going off.
Nov 02, 2015 | Heating & Cooling
Can my 1999 Cadillac Seville concourse overheat by mixing too much water with antifreeze??
Theoretically yes. Antifreeze has a higher heat capacity than water. Basically, a liter of antifreeze can hold more heat than a liter of water. I dont think it would be enough to cause an overheat though
May 20, 2015 | 1999 Cadillac Seville
Not sure the heat pump is producing enough heat
lower the fan speed to low and if you do not close your turns at 50 degrees Celsius then check the freon
Nov 04, 2011 | Heating & Cooling
I do not have the user guide for my A.O.Smith EES52 - a 50 gallon electric water heater, so my questions is; are there one or two heating elements in the tank? If two, where are they located and which...
Your water heater has two heating elements. The Two elements work in tandem to bring the water up to temp. then the top element keeps the water at temp. Here is a >>> link
Aug 19, 2011 | Water Heaters
What type of engine oil does a Peugeot 306 (1.6 petrol engine) need?
Engine oil specifications for Peugeot 306 1.6 petrol engine:
1. SAE 5W-40, API SH or SG, for temperatures between -30 Celsius deg. and +40 Celsius deg.
2. SAE 10W-40, API SH or SG, for temperatures between -15 Celsius deg. and +40 Celsius deg.
3. SAE 15W-40, API SH or SG, for temperatures between -10 Celsius deg. and +40 Celsius deg.
4. SAE 15W-50, API SH or SG, for temperatures between -10 Celsius deg. and +50 Celsius deg.
5. SAE 20W-50, API SH or SG, for temperatures between -5 Celsius deg. and +50 Celsius deg.
Jan 02, 2011 | Peugeot 405 Cars & Trucks
I have a gmpn-80 janitrol 90% eff gas furnace,it is only 15 months old,my condisation tray is melting and cracked do to heat in which case leaks water all over....why would this be happening?
Most likely the cause is that the furnace is firing too hot. When a furnace is installed and set up, the manifold gas pressure and fan speed has to be set by the technician so that the temperature rise through the furnace is a maximum of 50 deg F (i.e. if air enters the furnace at 68 deg F it come out no hotter than 118). The target temperature rise on any gas furnace is anywhere between 30 and 50 deg F. If the furnace runs too hot, either the manifold gas pressure must be turned down or the fan speed must be turned up to keep in this range.
Jun 28, 2008 | Heating & Cooling
Steinel 02120 - Replacement Heating Element for HL2010E Heat Gun Logo
414 people viewed this question
Top Steinel Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Steinel Kitchen Appliances - Other Expert? Answer questions, earn points and help others
