Question about Canon Office Equipment & Supplies
Canon Ir5050 printing to wrong tray
Sending file from As400 should print to tray 1 only prints to try 3
5 Suggested Answers
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
  • 135 Answers
SOURCE: Canon IR3035 Print orientation
you set the setting the way you want them, the go to additional functions/common settings/store and that should help
Posted on Apr 19, 2009
SOURCE: cant print on cd with canon mx850 printer
Those links might solve your problem:
http://damnprinter.com/105/the-five-easy-steps.html
http://damnprinter.com/176/tray-rejection-general-guide.html
How To Print on CD / DVD Tutorials on youtube
http://www.youtube.com/results?search_query=canon+cd+print&search_type=&aq=f
cheers :)
PS: Btw, info for others: For the Canon MX850 I was searching for the tray feeder itself! For this printer it is inside, i.e. look straight into the paper output and pull/open softly the black panel...
Posted on Sep 12, 2009
Evildice
  • 217 Answers
SOURCE: error 49.420c
ERROR 49.XXXX
A critical firmware error has occurred that caused the processor on the formatter to abort the operation. This type of error can be caused by invalid print commands, corrupt data, or invalid
operations. In some instances, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or specific software programs. Remove all EIO devices and firmware DIMM if installed. Restart printer. If error is gone replace each EIO device until error appears. Replace device which triggers error. May also be formatter.
Firmware updates are available for some machines at http://hp.com and clicking on the drivers and software tab. Also try printing from a different application. If that works go back to the first application and try printing a different file to determine if the problem is file related. You may need to reseat the memory DIMM's or replace the firmware DIMM or formatter board.
Posted on Nov 12, 2009
Canon ir 3300
Try the following:
1) check for toner levels (may need new cartridge)
2) check for paper on the tray
3) try printing a copy from that device.
Dec 30, 2013 | Office Equipment & Supplies
Ir3570 Takes Half Hour to start printing 3 pages - help!!!
Sounds like you have the wrong driver installed, go to canon website and download a new driver for the machine
Jul 06, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Cannot send a p rint job to pring labels from word to bypass tray with Canon 5000 copier Click on copier properties, click on bypass tray and then ok and print. Will not print fromt he bypass tray Ideas?...
If you can copy from the bypass, you should be able to print from it. It may be a setting in the print driver. Not the one you use through windows but the one installed in the printers folder in control panel. Check that it is not set to draw 1 - it should be on AUTO. Also, the document you are using has print settings of its own - check them as they will overide the tray you select. Select from within your document file - options - printer then look through those settings and anything telling the machine to print to a particular draw will make your job go there instead of where you ask it to.
Jul 09, 2009 | Canon imageRUNNER 5000 Copier
ZEBRA printing issues via AS400
*SAME
*WSCST
ZEBRA
*LIBL
*NONE
'10.27.9.21
Jun 26, 2009 | Zebra 105Se Thermal Printer
Apr 08, 2009 | Canon imageRUNNER 3035 Black and White...
Xerox 7232 and As400
016-799 is a printer paper conflict error. All you have to do for the AS/400 to print, is to make suree that tray 2 in the printer is set up to do landscape printing. There has to be at least one tray for portrait, and one for landscape in order for the AS/400 to print.
Mar 20, 2009 | Xerox Office Equipment & Supplies
Duplex printing problem
do you have to replese driver of printer for IR6000
Feb 10, 2009 | Canon imageRUNNER 5000 Copier
Can't print from bottom drawer, will only print from tray,
There are at least three possible solutions. The first two are simple the third is fairly complicated unlr=ess you can read a hex dump of a print file. 1) Use the front panel "Paper Menu" to select the tray. 2) Check the driver settings to make sure the driver is set to "Auto" or the correct tray. 3) Set the driver to "Print to File". When prompted to name the print file, name it "tray_fail". If you do not know how to read this file, send it to me at janddgasrepair@verison.net and I'll be happy to take a look at it and see I I can correct the problem. Don
Jan 16, 2009 | Lexmark Optra S 1855 Laser Printer
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
62 people viewed this question
old marine
old marine
